X-Band angle
Hello everyone,
I am wanting to limit the angle that the xband can sense.
At the moment it is acting something like this:
I wan't it to be like this:
(Sorry for the poor illustrations)
I was thinking lead sheeting on five sides of it, but that might be a bit impractical.
Any ideas?
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
Any ideas?
Thank you
·Now wanting to learn Spin· Thanks for any·
Sam
Would this block the signal?
Post Edited (kf4ixm) : 4/27/2010 12:38:04 PM GMT
Something like the attached drawing, with the X-Band module behind it?
Actually, if im looking at this right, that design would actually block the signal. from looking at the module pdf doc, it looks like there are four radiating elements on the module, the four squares near each corner. i would try taking the screen, rolling it up like a sheet of paper into a circle (think of a pringles can), a wavelength multiple bigger radius than the antenna area, and a couple multiples in length. Don't laught at my quickie picture, [noparse]:)[/noparse] Being that the elements are square, you could use either a circular pattern or a square pattern.
Post Edited (kf4ixm) : 4/27/2010 1:09:19 PM GMT
Thank you kf4ixm
It still detects slight movement just to the side of the module, but only like 1 cycle.
I have attached a few photos of my test setup. The Module is held in there with anti-static foam.
N.B. -- "Anti-static foam" is conductive.
Gained: The signal is directed.
Lost: From what I can see there is no loss in signal strength (range) or anything else for that matter.
I have not had any problems with antistatic foam conducting low voltages in the past. I certainly wouldn't have anything > 12V in contact with it.
It was the only thing that I had to hold the Module in the can.
Well, since it's all you had, I guess that's OK.· Afterall, we do·live in challenging times.
I think you meant "blimey", a feigned (in your case, obviously) exclamation of surprise, not "blarney", the Irish gift of gab. And what's with your mostly content-free posts lately?
Post Edited (Phil Pilgrim (PhiPi)) : 4/29/2010 3:35:38 AM GMT
All I've asked, content-stokedly, is: where's the data, where's the science?·
It's the "audio sensor" with·the ADC on the output of (essentially) a comparator, all over again.
And I did mean blarney --
Function: noun
Etymology: Blarney stone, a stone in Blarney Castle, near Cork, Ireland, held to bestow skill in flattery on those who kiss it
Date: 1784
1 : skillful flattery : blandishment
2 : nonsense, humbug
Post Edited (Phil Pilgrim (PhiPi)) : 4/29/2010 3:17:23 PM GMT
Oh,... lol.
Not all problems in life have to be proven with mathematics and tabulated results.
I too would classify your replies as "Snide commentary".
You and Phil and I don't care who else can call names till the cows come home.
As long as you are happy then you're happy, I guess.· I don't care.
There's science and there's religion.· If there is/are no data, no "mathematics or tabulated results" as you so proudly and freely acknowledge,·then it's not science.
Electronics isn't a faith system.
Shawn Lowe
When all else fails.....procrastinate!
Ok, I'll bite...
Well, look up the term waveguide as related to rf. there's enough data and calculations associated with antenna design and waveguide properties to make your kidney's bleed if you care to research the mathmatics. Simply put, an rf signal can be guided and even amplified through the use of a carefully designed radiating element, or in this case, a properly designed groundplane, which acts as a mirror for rf. (like the outer elements of a yagi antenna or a quad)
The only data that's needed in this problem is the wavelength of the rf energy, which, as stated, is 1.1 inches for the 10.525mhz. these measurements are crucial for properly propagating rf into a directional beam of energy into a space, where if not properly designed will induce SWR (Standing Wave Ratio) of higher that 1:2 or even higher, 1:1 being an optimal antenna, back into the transmitter and eventually cause it to overheat and fail, especially at high power outputs. But i don't believe this this will be much of an issue for these modules.
Yes, i am a Ham, i've designed and built many antennas both for transmitting and recieving.
Post Edited (kf4ixm) : 4/30/2010 3:14:02 AM GMT
I worked·with I-J band travelling wave tubes for 8 years.· I know a thing or two about waveguides, VSWR, return loss, insertion loss, power in, power out, and BS rolls downhill.· I've requested information, "data", none has been presented because there isn't any.·
Just Believe!
Then how about actually HELPING someone with questions they have rather than degrading them for trying something or giving unrelated opinions about the approach they're taking. If you have that much experience, then you were qualified to give CG an answer to help him with his project, but instead, you didn't. what "data" do you require? you sound like you already know EVERYTHING!
There's no support for the claim other than a professed result achieved.· Not because I say so, the OP says so.· Period.· Fine.· Gosh, am I ever sorry to have disturbed your little camp meeting.· I think this is where you say a prayer, pass the offering plate and sing a closing hymn.·
OK?
I haven't denigrated anyone.· Someone asks a question and I ask a question in return and I'm a bad guy?· Well, fine, so be it; if I'm a bad guy then make the most of it.
Somehow I think I'm not going to get a free x-band detector.
