free 3d printer
Makerbot is giving away a 3d printer($750 Value) free to the person that comes up with the coolest design.
blog.makerbot.com/2010/04/14/makerbot-giveaway/
Awesome! I definitely need that...
MCU Projects·- my new site where I will be posting all projects, code, etc.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
SD Card Adapter·- Add extra memory to your next Propeller project with ease!
i have made the beenie(use or make your own). can anyone figure out how to make the blades? the axel is a 5mm diameter.
By the way, check the free version of Alibre...
Not to be a pain in the Smile and hijack the thread, but your sig image reloads are killing my cache. Aren't images in sig's against the forum rules?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
If it is against rules of real problem I can get rid of it.
Don't worry about it. I've blocked it locally. Problem solved.
I don't get the requirement.Could you explain it better?
I made parts for rapid prototyping in the past (stereolitography), but the requirements were different..
Lots of propeller based products in stock at affordable prices.
Hey Scope,
can you recommend any particular books that are good for learning sKetchup? Or maybe indicate ones that are NOT so good?
thanks!
I'd recommend getting comfy with using groups and components early on. Basically, these tools allow the management of geometry and have similar characteristics but your job of geometry creating & editing will be much, much easier when using groups &/or components.
For example, when you create a table, make a leg into a component - pattern it, then change one leg and they all update. Also, components can quickly & easily be sent to and imported from from storage (hard drive, USB drives, & so forth). If you ever wanted just one table leg to be different, you can make the component "unique" which maintains the component property but that leg won't update when any of the other table legs change.
Yeah - perhaps here's another useful link (I hope this link works):
forums.sketchucation.com/viewtopic.php?f=79&t=12706&sid=06add70d7596826da8492bdb22c7da03
I can't recommend any books - I'd enjoy writing one. I am a contributing author for an AutoCAD book - I've been using AutoCAD since 1986, I've been Autodesk Certified to teach it for many years and, I really loathe AutoCAD (no typos).
Post Edited (Scope) : 4/16/2010 9:30:22 PM GMT
That's very interesting. I've wondered how AutoCAD users regard Sketchup and whether or not it's actually worth learning. When you write the book on it, do post a notice here.
·http://www.amazon.com/s/?ie=UTF8&keywords=sketch-up+for+dummies&tag=googhydr-20&index=aps&hvadid=3280299341&ref=pd_sl_74zv5r1wwj_b
Jim
Also - all educators can receive a SketchUp Pro version free - fill out the paperwork, it's really easy. Some of the Pro features are very nice but not 'essential' in order to have a most remarkable 3D CAD tool.
Window --> Model Info --> Units
When you use the line, you can click in one spot and then just type in the number for the length. I just now found that out; you can also do an n-gon this way.
sketchup.google.com/training/videos/familiar_with_gsu.html
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
It's Only A Stupid Question If You Have Not Googled It First!!
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
Might try and print it on my makerbot just out of interest.
It is currently in the mail.
make it as 2 pieces. this will allow the top to actually spin and make it possible to print. Will have to change the angle of the blades though to something a little more vertical.
