Multicolor LEDS block?
Hi guys I bought these LED blocks someone posted the link and I bought a few,, I have attached the data sheet it pretty worthless, but here is my question its suppose to be red/yellow and green leds I can get the green to flash by randomly poking around for the pins since I cant figure out the real pin out, but how do I get thew other colors I tried changing the voltage and the polarit but nothing what am I missing thanks
The only thing I could garner from it is that each cell has 3 LEDs, but the connection diagram is incomprehensible. I took a quick look around the InterWeb for this part and the two "examples" found were just as poorly written.
Cool idea though.
DJ
I presumed (won't use assumed 'cause I already look like one) that there were multiple colors per cell, mainly because there weren't words telling me otherwise.
(smiles)
DJ
but when you look at the ad from MJP it gives you a sense that you can control the color of each LED it would have been really cool if I could but in the end there are a few reds a few yellow and a lot of greens.
Dave I found the one online where a guy used 5 of them to make a display he posted a lot of pictures and the project looked awesome but no schematic or diagram. I bought a few other LED packs some have less than the others but they are very bright I wanted to make a kind of TV display out of a bunch of them I saw a program about the big screen TV's at the football stadiums and each cell is an LED its really cool how good it looks from far away but they showed it up close and you can see each LED
Thanks again
Memories huh
I think your are mistaken, the LED module is mulitcolor (3 color) in fact the LED module has Red LEDs & Green LEDs, and yellow
color, when you light on the LEDs Red+Green=Yellow. I am quite sure about that, as I have some kind modules almost like yours,
I have use them at some multicolor projects as well. Try again and look at PDF schematic, it would not make sense to make a kind
of LED module, by mixing some Red & some Green or Yellow!!! Would it?
At the end, everything will became Electron...!
The first LED upper from left will ligt as:
Red =··Pins·22 & 23
Green=Pins 22 & 24
Yellow=Pins 22 & Pins 23+24
Post Edited (electrosys) : 2/24/2010 12:56:43 AM GMT
I admit that sheme at PDF file & modules data is kind of confusing! It looks not like a multiplexing but rather a kind of Charliplexing maybe, again, if I am not mistaking, because by closer look at your modules data (attached PDF) I find out that your module looks some differnts from the LED module that I have (attached image) try to work a liitle more with the module, you will soon find out & search internet for some better data.
Good luck
Don't infer or impute, just read; let the scales fall from your eyes.· Minds are like parachutes -·they only work when they are open.· You can't fight this year's war with last year's battle plan.
The modules were fab'ed for a particular customer, he wanted those colors and·in that arrangement; deal, kids.
(smiles)
DJ
How about basic stamp pong? Two momentary pushbuttons for each player and score is kept on the top row of multicolored LEDs???
Sorry, I would have bought them too.... multicolored displays.... Wow.
"puff"...... Smile, there went another one.
