PSB: Now Shipping! $89 intro price — Parallax Forums
RaymanRayman Posts: 16,457
edited 2011-04-09 10:29 in Propeller 1
These are full size system boards for the 4.3" touchscreen TFTs that I'm selling...
Update:· Units are shipping!· Low $89 for introductory price (LCD sold seperately).
Used LCDs are still $18 and you can get a new one with a PSB board for $30.
Product Page:· http://www.rayslogic.com/Propeller/Products/PSB/PSB.htm
Post Edited (Rayman) : 1/28/2010 10:37:05 PM GMT
1496 x 1122 - 801K
1496 x 1122 - 932K
    edited 2009-12-06 18:59
    Looks great! Congratulations...
    Would you mind sharing the 3M part number for that SD connector? That seems solderable by mere mortals...
    Rayman said...
    Just finished testing out the second prototype yesterday and everything works, only flaw was a missing wire so that the PS/2 mouse connection can be replaced by a USB connector. You can see I soldered in jumper wires to fix the prototype and it actually works... You can just plug in a mouse to the USB connector and have it work (assuming the mouse is PS/2 compatible. This just saves you from needing the green adapter.).
    Anyway, just took the plunge and ordered 50 boards. Should arrive just before Christmas.
    If anyone is still interested in a bare PCB, let me know and I'll come up with a price...
    www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
  • JRetSapDoogJRetSapDoog Posts: 954
    edited 2009-12-06 19:31
    That's hot!· So you've got the LCD and VGA out on the same board.· Are they on the same Prop pins?· I think another of your threads said that was the plan.· Is it this case that one would use only one at a time?· If so, can one keep both plugged in at the same time?· Does one need to take any precautions in switching between output devices?·
    You've also got composite video, which is quite convenient.· Where's the jumper you mentioned to permit using a USB connector?· I think I see a small jumper snaking diagonally off the lower-right corner of J12.· Avoiding the green/blue adapter USB-PS/2 thingy would be nice.· What are the three vertical resistors over by the composite connector?· Are they for video, as in the standard design?· If so, maybe·the unpopulated R19 is for audio.· I'm curious as to why they are·axial devices as opposed to surface mount.· Also, I see composite video output pins over on J9, so, if·using them, one would provide their own resistors off board?
    Do you still have the USB-232Serial chip on board?· Perhaps U2.· But I noticed that you have added·a PropPlug header compared to your PSM board.
    Anyway, really great-looking and functionally-rich board!· Congrats on your newborn.· It's a board!· Thanks for the update.
  • RaymanRayman Posts: 16,457
    edited 2009-12-06 20:32
    Bill:· Here's the Digikey part# 3M5646CT-ND
    JRetSapDoog:· Yes, LCD and VGA share pins, so you can only have 1 at a time.· Yes, there's an FT232RL...
    I'm using non-surface mount for all the optional things that use the 8-free pins (TV, keyboard, mouse).
    edited 2009-12-06 21:05
    Good to know. Thanks! Ah...FT232RL, right, I was too lazy to look it up, lol.
    edited 2009-12-06 22:54
    Thanks! I am ordering some right away...
    Update: Argh, they are out of stock!
    Rayman said...
    Bill: Here's the Digikey part# 3M5646CT-ND
    JRetSapDoog: Yes, LCD and VGA share pins, so you can only have 1 at a time. Yes, there's an FT232RL...
    Post Edited (Bill Henning) : 12/6/2009 11:10:01 PM GMT
  • mikedivmikediv Posts: 825
    edited 2009-12-07 02:20
    Ray I would defiantly want one , will they be available with the screen and bare board or complete???
    edited 2009-12-07 12:08
    Not sure yet... May do bare PCB, fully loaded and a low-cost, "lite" version...
  • Jim FouchJim Fouch Posts: 395
    edited 2009-12-07 15:55
    I'd be interested on 3-5 in an assembled w/o screen config, as I have a few screens w/o breakout boards.
    Jim Fouch
    FOUCH SOFTWARE
    edited 2009-12-07 16:23
    Ok, I'll think about how to do that... May use Gadget Gangster for complete sets and sell boards w/o screens myself...
    edited 2009-12-07 16:37
    I would like one fully loaded with everything including the touchscreen display.
    Check out the Propeller Wiki·and contribute if you can.
    edited 2009-12-07 20:14
    You know Roy I am with you I would like a complete one with screen I have enough stuff to solder and wire wrap , This board would make an awesome controller for a project I am working on Ray knows his video stuff ..
    Ray do you know if anyone has ever found a way to interface a PDA screen I have so many old color PDAs Dell Axims , Compaq my cell phone now has more features but they did have really nice color touch screens
  • lessanlessan Posts: 1
    edited 2009-12-07 20:46
    I might be interested in a complete one depending on the price. What are you looking to get for one of these?
    edited 2009-12-07 23:27
    Unfortunately, I'm paying the price for using ExpressPCB... They're terriffic for their standard 3.8x2.5" boards, but these large boards are a lot more pricey... I'm probably going to have to charge something like $15 for a bare PCB...
  • Nick McClickNick McClick Posts: 1,003
    edited 2009-12-07 23:48
    Once you order your boards from ExpressPCB, you can send them an email (I believe it's sales@expresspcb.com and ask for gerbers for your design. The charge is $60, but it might be worth it.
    Propeller Forums RSS Feed!
    Gadget Gangster - Share your Electronic Projects
  • kerrywkerryw Posts: 61
    edited 2009-12-08 00:52
    I'm interested in buying 1 maybe 2 also. Do you have a rough estimate of the parts costs if fully populated?
    Kerry
    "Heaven help me Marge, I'm just not that smart." - Homer Simpson
    edited 2009-12-08 00:58
    I'm hoping for $150, but don't know for sure yet...
    edited 2009-12-08 01:04
    $150 would be a great price, assuming that is fully loaded with the display.
    Would it also include all the soldering and whatever other assembly? (I'm a programmer, my soldering skills are sad.)
    edited 2009-12-08 01:50
    I'm thinking of doing all the SMT stuff and providing those through-hole parts in a bag. I'm not sure everybody will want those through-hole components, which is why it's done that way to begin with... Those things use up the 8 free pins, which some people may need for other things...
    But, I've seen Gadget Gangster do some soldering if people need it...
    edited 2009-12-08 01:51
    Actually, that $150 (if I can do it) would be for a "like new" display. Would be ~$12 cheaper with a "used" display...
    edited 2009-12-08 08:28
    I can handle thru hole, but I'd pay a little more to get one fully built, because like I said my aim to to do programming on it. So, I don't mind if it uses all the pins up for stuff on the board.
    I do understand that many folks would prefer the option, but I prefer to avoid soldering if I can. I do use the breadboard for experimenting though. I love my PPDB!
    edited 2009-12-09 14:16
    Bill Henning said...
    Bill:· I'm glad you asked about that...· Looks like they're out of stock everywhere!· Digikey claims they'll get more in a week...
    But, I'm not taking any chances.· I found that Allied Elec. still has some, so I just·ordered 50 from them...
  • OakGraphicsOakGraphics Posts: 202
    edited 2009-12-10 23:51
    Looks cool. I would be interested in 2 or 3 of them myself. Bare PCB or maybe the lcd connector attached. something like that. smile.gif
    edited 2009-12-10 23:52
    by the way - how are you mounting the lcd to the pcb? double-sided tape?
    edited 2009-12-11 00:17
    Yep, double sided tape... Seems to work pretty well.
    edited 2010-01-03 22:41
    PSB boards are in!· Parts are in...· Now, just need to find some time to put a few together...
    1496 x 1122 - 617K
    edited 2010-01-03 22:47
    How does $89 for an assembled board (without display) sound?
    (non-surface mount parts to be provided in a seperate bag)
  • wjsteelewjsteele Posts: 697
    edited 2010-01-03 23:57
    Scratch that... I just sent you an e-mail.
    Bill
    Post Edited (wjsteele) : 1/4/2010 12:11:13 AM GMT
  • Luis DigitalLuis Digital Posts: 371
    edited 2010-01-04 01:42
    Rayman said...
    I hope the children are very smart like you. When they have 8-9 years create an account on the forum. Learn to Propeller IV. smile.gif
    edited 2010-01-05 02:20
    Just finished the first board [noparse]:)[/noparse] But, it didn't work [noparse]:([/noparse]
    Turns out, I put in a AD723 ntsc encoder where the FTDI usb chip is supposed to go...
    Fried my USB hub when I plugged it in!
  • James LongJames Long Posts: 1,181
    edited 2010-01-05 04:15
    Rayman said...
    Ouch......hope that was an external hub.
    I hate when that happens. I've done similar before.........I stomp around for an hour saying words that I shouldn't say.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
