Call for Clarity from Chip or Beau — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2009-12-08 01:59 in Propeller 1
@Chip or @Beau,
These two questions need answers. Please address them.
    1) What is the maximum rise and fall time for a Propeller pin as an output with a small capacitive load? 2) What is the time between setting the outputs and getting the inputs on two consecutive instructions?
1) The Propeller Datasheet does not specify the maximum rise/fall time. This is key information.
2) Consider the example below. How many ns pass between setting the output at inst 3 and reading the input at inst 4?
con
  _CLKMODE      = XTAL1 + PLL16x
  _XINFREQ      = 5_000_000
pub start
  cognew(@entry,0)
  repeat
dat
entry   org 0
        or    dira, #$ff ' inst 1
        mov   outa, #0   ' inst 2
        mov   outa, #$ff ' inst 3
        mov   data, ina  ' inst 4
        jmp #$
data    res 1
  • LeonLeon Posts: 7,620
    edited 2009-12-04 17:29
    Quite a lot of manufacturers don't supply those sort of data for ordinary outputs, probably because it depends on the load, so they are in good company. I've often seem such data for pins used for I2C and SPI, though.
    Leon
    Amateur radio callsign: G1HSM
  • jazzedjazzed Posts: 11,803
    edited 2009-12-04 17:39
    Most manufacturers show a reference load design in their specifications. The data is important, answers MUST be made available.
    BTW: The new avatar picture is cool. I've seen the story of it before.
    Post Edited (jazzed) : 12/4/2009 5:46:04 PM GMT
  • RaymanRayman Posts: 15,967
    edited 2009-12-04 19:10
    Here's what it actually looks like:
    http://www.rayslogic.com/propeller/Programming/RaysStuff/80MHz.JPG
    edited 2009-12-04 19:28
    @Rayman,
    Gee, I've only ever used a 1GHz LeCroy at work and that was a GE Capital rental I'm sure [noparse]:)[/noparse]
    How long is your ground wire/pin? The over-shoot does not appear nominal ....
    From that, it looks like the fall time is around 2ns. Is there a test load?
    This is very helpful, but of course does not replace a published specification from Parallax.
    Thanks for your trouble.
    edited 2009-12-04 19:53
    There's enough info in the datasheet to infer the figures you're looking for. Looking at the DC characteristics section, we see that when driving a 10mA load high, we can expect the output voltage to be at least 2.85V when Vdd = 3.3V. This is a 0.45V differential. Divide that by 10mA, and we get a source impedance of no more than 45 ohms. From the AC characteristics, we see that the pin capacitance is typically 6pF, so the RC time constant without a load is 0.27ns. Adding external capacitance (other ICs, test leads, etc.) will cause this time constant to increase. The sink differential with a 10mA load is 0.4V*, so the time constant for a falling edge will be a little less.
    There may be other factors (e.g. gate capacitance of the output drivers, which is not external-load-dependent) that could increase the rise and falls times, but this will give you a quick, back-of-the-envelope characterization.
    *I thought the output drives were supposed to be symmetrical, but apparently they're not quite.
    Post Edited (Phil Pilgrim (PhiPi)) : 12/4/2009 8:01:41 PM GMT
    edited 2009-12-04 20:04
    Is 0.27ns rise/fall a realistic number? What would be maximum tLH and tHL unloaded?
    This may be a step toward resolving question 1. Question 2 requires Chip's attention.
    edited 2009-12-04 20:08
    jazzed said...
    As I recall, this was looking at a prop pin with 500-MHz probe with no load...
    I imagine it would·look a lot better if there were a resistive load...
    edited 2009-12-04 21:43
    jazzed said...
    No, of course not. In any real-life circuit, you'll have to consider PCB pad and trace capacitance and inductance, along with whatever load is connected. Plus, the 0.27ns figure is a time constant, not a rise/fall time. For the latter, you need to specify limits as a percentage of Vdd (e.g. 10% and 90%), which will provide you a multiplier for the time constant. But you should be able to obtain a ballpark figure for rise and fall times using the inferred source/sink impedance, along with your real-life load capacitance.
    edited 2009-12-05 00:20
    This thread is referring to the thread...
    SRAM speed - is 10nS possible ???·· http://forums.parallax.com/showthread.php?p=860477
    Question 2 needs further definition.·Below is the example code used...
    con
    pub start
      cognew(@entry,0)
      repeat
    dat
    entry   org 0
            jmp #$
    data    res 1
    What I believe jazzed is really asking is... (I will make these questions 3, 4 & 5)
    3. With reference to the beginning of the R clock for "inst 3", what is the time delay until 'outa' pins are stable?
    4. What clock cycle are the ina pins sampled in "inst 4"? (Is·it·the "e"·or the "S" clock cycle?)
    5. With reference to the beginning of the "e" or "S" cycle in 4 above. What is the time delay until 'ina' pins are sampled? What is the minimum setup time required before the 'ina' pins are sampled?
    This will allow us to determine (in addition to taking circuit loading etc into account) what the fastest SRAM access can be. We can then determine if multiple cogs can help getting access faster, and the impact of overclocking.
    Thanks in advance.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    edited 2009-12-05 00:50
    Cluso99 said...
    4. What clock cycle are the ina pins sampled in "inst 4"? (Is it the "e" or the "S" clock cycle?)
    first reply in http://forums.parallax.com/forums/default.aspx?f=25&m=262581 (if you believe him that is)
    Can you assume for the moment that sampling ina is the same as sampling phsx? Then consider this code fragment:
    mov     phsa, #0     ' 1: SDeR
    mov     frqa, #1     ' 2:     SDeR
    mov     temp, phsa   ' 3:         SDeR
    Now the value for frqa becomes active (i.e. is used 1st time) during S of the sample instruction (3). So in case sampling happens during e you'd expect 2 being stored in temp, which is exactly what happens. I did similar tests with a duty cycle counter and sampling ina, same result.
    edited 2009-12-05 01:05
    kuroneko: Thanks for the link. I already thought what you had said made sense as I know the waitpxx instructions wait in the "e" cycle. I was wanting to make sure from the guru, since we are asking other timing questions. It doesn't hurt to make sure.
    edited 2009-12-05 01:31
    So the answers appear to be:
    Given a careful design with limited number of loads (< 32pf total), 45 Ohm impedence, and 2.4V/3.3V at 72%, the rise/fall time for an output pin is close to 1.9ns.
    Approximately two clock cycles pass between setting to a register and getting from a register on back to back instructions. In the example 5MHz xtal1 and PLLx16, this translates to about 25ns.
    edited 2009-12-05 01:55
    Steve (jazzed):
    I hope you have not taken my comments the wrong way - it is an externsion to your questions, not meant to hijack or criticise. There are great minds working on this and together we will all benefit once we understand the timing limitations within the prop.
    The reason I asked the extra questions is we then can understand how we can use "other" methods to improve the access. Your Q2 does not give us that, but we can derive that from Q3, 4 & 5.
    And yes, I would believe that our summation of 2) is that the minimum time would be 25nS, being the clock cycles of "S" & "D" in the 'ina' read instruction. We cannot include any time in either the "d" (which is the "R" cycle of the 'outa' instruction) or the "e" ('ina') instruction. The proviso here is that the "e" does not require setup time preceeding the clock and Chip will hopefully answer this.
    As you can see, while memory speed helps, we can gain much more by overclocking than we can by increasing SRAM access. But every instruction we can save helps.
    edited 2009-12-05 02:18
    No Ray (Cluso99), your comments are not taken the wrong way. You are just being a "careful engineer" whose questions are valid.
    I would like simple answers to my simple questions though from the authority on the subjects at hand. I figured Parallax has more chips to characterize than any of us, so they are in a position to measure timing with respect to calculations on given loads. Having data match calculations over a large sample size would be best. We can infer all we like, but in the end it is Chip's responsibility to his customers to produce data that satisfies.
    All the answers sought are especially meaningful when trying to project correct operation in the "worst case" scenarios where timing stacks up in a bad way which can lead to RMA inventory stack up (which no one wants) for high volume product (which everyone would like). Useless inventory is an evil expensive.
    I think we are on the right track and the light at the end of the tunnel is getting bigger because there is an exit coming rather than another train. Fingers crossed [noparse]:)[/noparse]
    edited 2009-12-05 02:24
  • cgraceycgracey Posts: 14,289
    edited 2009-12-05 06:07
    EDIT: INA is read during the Read Destination cycle, not the Read Source cycle as stated in this posting. Sorry for the confusion.· -Chip
    I recall that the external pin transition occurs over ~.25ns, unloaded. Before the transition occurs, though, there is ~2ns of internal delay from the cogs (w/series OR gates) to the pin-driver MOSFETs.
    The cog executes an instruction in four cycles:
    1) Read Instruction N (ALU result N-1 settles during this cycle)
    2) Write Result N-1
    3) Read Source N
    4) Read Destination N
    Note that INA is read during the Read Source cycle. Results are written three cycles later. When doing back-to-back read-modify-write operations on DIRA/OUTA, you are dealing with an internal register, only, so there is no pin-load dependency. The tightest timing occurs from an OUTA/DIRA write to an INA read (XOR OUTA, MASK... TEST MASK, INA WZ), where the pin must transition and be read back within ONE clock cycle, minus internal propagation delays of perhaps ~4ns (another ~2ns of read-back delay).
    Chip Gracey
    Post Edited (Chip Gracey (Parallax)) : 12/6/2009 5:22:30 AM GMT
    edited 2009-12-05 06:36
    Chip Gracey (Parallax) said...
    Thanks Chip.
    So an OUTA/DIRA write to an INA read output to input window is what exactly? Is it "clock-6ns" or is it "clock-2ns" ?
    edited 2009-12-05 06:41
    It's a clock cycle minus ~4ns (~2ns for cog--->pin, then ~2ns for pin--->cog).
    Chip Gracey
    edited 2009-12-05 06:50
    Bummer. Ok, at least that is settled. Merry Christmas Chip.
    edited 2009-12-05 07:49
    Chip: Thankyou for your reply. Can I just confirm·this timing diagram?
    *3··Time from start of "R" cycle to valid data out at the pins
    For the purpose of working out a realistic value, I have added the .25ns for ideal rise/fall time and a further .25nS for possible loading, plus your internal gate delay of 2ns which gives ~2.5ns
    *5a Time from start of "S" cycle to valid data read from the pins·(latched)
    *5b Data setup time until pins are internally sampled (latched)
    I presume from your comments, the setup time is included in *5a above and so will be the same ~2.5ns
    *7 Minimum Access Time
    Based on the above times, this will be 12.5ns - 2.5ns - 2.5ns = ~7.5ns
    1168 x 379 - 45K
    edited 2009-12-05 08:03
    edited 2009-12-05 08:04
    I don't know what to say, that's in the face of all evidence.
    DAT             org     0
    entry           mov     dira, #1
                    movi    ctra, #%0_00110_000
                    movi    frqa, #%0001_00000
                    movi    phsa, #%1110_00000
                    mov     outb, ina
                    or      outb, #%1000_0000        ' indicate result ready
                    wrlong  outb, par
                    cogid   frqa
                    cogstop frqa
    Pin 0 is the output of a duty cycle counter, preset to %01110. So the pulse is expected after 2 cycles (%01111, %10000). phsa gets written in R therefore the first increment can only happen during the S cycle of sampling ina, so in the setting above the pulse occurs during the D cycle. How is it then possible that I catch the pulse with the above code fragment (assuming it's sampled during S)?
    Post Edited (kuroneko) : 12/5/2009 8:20:18 AM GMT
    edited 2009-12-06 05:10
    STOP THE PRESSES!!!
    The pins are sampled on the Read Destination cycle, not on the Read Source cycle, as I first stated.
    Though the Read Source cycle is used to read a possibly-required source register, the·Read Destination·cycle is used to multiplex in the final source value from either the source register that was just read, the PAR,· the CNT, the INA, the PHSA, the PHSB, or the literal value specified in the opcode. At the end of this cycle, both the source and destination values are ready to be·fed into the ALU.
    Thanks for pointing this out, Kuroneko. I wasn't remembering how this worked, exactly.
    Chip Gracey
    edited 2009-12-06 05:16
    Let me say from the outset, we are trying to prove Chip's information by writing a test program. I am sure Chip will not mind us doing this. Who knows, together we may find some new ideas in the process.
    kuroneko and I have been having a discussion offline to try and prove this and work out the timing (without a high speed cro). I suggested we bring it back online to enlist some other ideas as to why we are seeing·different results to those expected. Perhaps we are making some incorrect assumptions or just plain coding errors.
    I will let kuroneko post his code test results. Basically, this is where we are up to...
    Since we know that the output to the pins occurs somewhere in the "R" cycle (say 2.5ns after the "R" begins") we can use this as our reference? However, we can only assume it is valid sometime within the "R" cycle, not at the beginning of it.
    Now, lets think about the reading. Chip said it is necessary for the pins to be fetched in the "S" cycle because it may be operated upon in the "e" cycle. This makes sense, now I think of it, because otherwise it would not be ready at the start of the "e" cycle, which it must be.
    It is entirely possible that the "S" cycle only latches the input pins at the end of the cycle. If we presumed that, and the fact that the output pins were only stable sometime during the previous "R" cycle, how would we test for this??
    Alternately, if the pins·were sampled in the "e" cycle, they must be ready for the ALU at the start of the "e" cycle meaning that allowing for internal gate time delays, the pins·would in reality be sampled in the previous cycle (i.e. the "D" cycle). How would we test for this??
    edited 2009-12-06 05:17
    Chip, our posts clashed. Thanks for that, I am just digesting it now. [noparse]:)[/noparse]
    Postedit: Thanks Chip. Middle ground. As you can see, I realised that the pins had to be ready for the ALU at the beginning of the "e" cycle.
    Are they infact latched into the ALU? I presume they are otherwise a change during the ALU cycle could upset things.
    Post Edited (Cluso99) : 12/6/2009 5:23:56 AM GMT
    edited 2009-12-06 05:25
    That sounds slightly better :) However, the data sheet says that writing phsx voids any accumulation for this cycle. So - referring to my example - as the result of S phsa gets incremented to 15, as a result of D it becomes 16 (overflow). Assuming sampling pins and making results available are tied to the same clock edge, how can I sample the pulse during D when it only becomes available as a result of D?
    Edit: To comment on the test program Cluso99 mentioned. I started 2 cogs which synchronise on a given cnt value. The move cog will then set a number of mask bits from high to low. The read cog will execute a nop first (to cover the time taken by the mov) then sample ina. The whole process is done 4 times with the difference that the read cog will leave the waitcnt 0..3 clock earlier than the move cog.
    Furthermore, a clock cycle is considered to start with low followed by high, the rising edge being responsible for sampling and/or latching. This may be an invalid assumption but should be valid to get my point accross. Only in the case for a delay of 3 can I see mask high being sampled.
    576 x 344 - 13K
    edited 2009-12-06 05:39
    Some elaboration:
    Source Read cycle -
    source register is read from cog RAM and value is latched on the rising clock edge
    Destination Read cycle -
    destination register is read from cog RAM and value is latched on the rising clock edge
    source value is mux'd from source register, PAR, CNT, INA, PHSA, PHSB, or literal, and latched on the rising clock edge
    Instruction Read cycle -
    Next instruction is read from cog RAM and value is latched on the rising clock edge
    source and destination values settle through ALU
    Write Result cycle -
    ALU result is written to cog ram on the rising clock edge.
    So, in the case of INA, it can be changing up to the rising clock edge of the Read Destination cycle. Everything happens on rising clock edges. All timing can be considered from rising clock edge to rising clock edge.
    Chip Gracey
    edited 2009-12-06 05:47
    kuroneko said...
    That sound slightly better [noparse]:)[/noparse] However, the data sheet says that writing phsx voids any accumulation for this cycle. So - referring to my example - as the result of S phsa gets incremented to 15, as a result of D it becomes 16 (overflow). Assuming sampling pins and making results available are tied to the same clock edge, how can I sample the pulse during D when it only becomes available as a result of D?
    Kuroneko, I don't understand your question. Could you please restate it another way?
    If you write PHSA, the new value gets mux'd into the PHSA flipflops' inputs, instead of the accumulation.
    Chip Gracey
    edited 2009-12-06 05:50
    Cluso99 said...
    There are internal S and D flipflops (32 bits each) whose outputs always feed into the ALU. So, as soon as they are both updated on the rising clock edge in the Destination Read cycle, the ALU is being fed with static data.
    Chip Gracey
    edited 2009-12-06 06:01
    Sure, ...
    mov     outb, ina
    in the Result cycle of the phsa movi (rising edge) phsa is set to #%1110_00000<<23. This means that the next rising edge (S of mov) brings the value up to %1111_00000<<23, the following rising edge (D of mov) causes an overflow which outputs the DUTY pulse.
    You also said that ina is latched with the rising edge. My point is that it shouldn't be possible to sample the pulse with the rising edge of D when the rising edge (of D) generates the pulse in the first place. So only the rising edge of E could possibly sample that pulse (i.e. the phsa preset is chosen so that ina catches the value). The test program will report %1000_0001 to the caller when run with the given presets.
    Code relisted for ease of use.
    DAT             org     0
    entry           mov     dira, #1
                    mov     outb, ina
                    wrlong  outb, par
                    cogid   frqa
                    cogstop frqa
    Post Edited (kuroneko) : 12/6/2009 6:25:32 AM GMT
    330 x 92 - 2K
