LED Grid Issue - Solved, thanks — Parallax Forums
CassLanCassLan Posts: 586
edited 2009-11-30 16:03 in Propeller 1
*** Update ****
As it turns out, I neglected to place a % symbol in the OUTA commands when attempting to clear the screen
Thanks for the responses.
Working Properly:
http://www.youtube.com/watch?v=gylFS5L2bLI
Hi all,
Working on a desktop clock for myself comprised of a 7x5 led matrix.
Made from a hacked USB Proto board, and a DS1302.
Presently I've just been working on getting some scrolling animations going, at which point I would like to make a character driver for this display..and then get the time/date displaying.
I'm having a wierd issue where whenever I start to do fast updating of the LEDs, I get a ghosting effect, and some LEDs come on that should not be on.
They come on dimmer than the intended LEDs, but are still visible. I have tried clearing all LEDs before lighting up the next one, thias does not help.
Does anyone have any idea what this could be or how to solve it?
Video showing 3 collumns having this effect while attempting a Saw-tooth animation
http://www.youtube.com/user/casslan#p/a/u/0/MVm2h0DEcGI
NYC Area Prop Club
Prop Forum Search (Via Google)
Post Edited (CassLan) : 11/29/2009 10:15:38 PM GMT
  • LeonLeon Posts: 7,620
    edited 2009-11-29 20:28
    Schematic?
    Leon
    Amateur radio callsign: G1HSM
  • JonnyMacJonnyMac Posts: 9,824
    edited 2009-11-29 20:47
    Leon's correct, a schematic would be helpful. In similar projects I always clear the current column before going on to the next to prevent ghosts -- maybe that will help.
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-11-29 20:50
    Looks like it could be a hardware problem. Soldering flux can be a bridge - clean it. Shortcut anywhere?
    Try it in slow-motion. I mean switching the LEDs at a speed you can follow with your eyes. If it's a problem in the program you should see that. If you set pins high/low one after another you can measure what you get on the display.
  • CassLanCassLan Posts: 586
    edited 2009-11-29 21:24
    I have put up a Schematic of the LED Portion, Rvalues are 47Ohms.
    Also some pictures of the Board.
    Mag, I am trying to pin-point the exact circumstance to which this occurs.
    Rick
    NYC Area Prop Club
    edited 2009-11-29 21:33
    In your code you light several LEDs in one column at the same time. You are aware that this type of code will result in columns which are darker than other columns? The more LEDs are lit in a column the darker it will be.
    edited 2009-11-29 21:51
    As it turns out, I neglected to place a % symbol in the OUTA commands when attempting to clear the screen. That solved it.
    Thanks for the responses. I uploaded a vid of it working properly but youtube is taking forever to process it.
    Mag,
    Yeah I am aware of that, I'm really just starting this project with the hardware portion complete now I will venture into the coding that will allow me to time the single LED lighting that will yeild a smooth look.
    I'm trying to end up with some code that will take my row/collumn data blocks and safely light only one LED at a time but will populate the entire display to appear on.
    I'm not too sure of what the delay between switching LEDs should be.
    Then beyond that, I'm hoping to write some code that will alter the once static row/collumn data blocks with dynamic data to do scrolling...etc.
    I dont think this is worth doing until the proper display driver (lighting one LED at a time is done)
    Should I plan the timing to assume that all 35 LEDs will be used? This would keep the speed constant I guess.
    NYC Area Prop Club
    Post Edited (CassLan) : 11/29/2009 10:16:19 PM GMT
  • jazzedjazzed Posts: 11,803
    edited 2009-11-29 21:54
    Hey Rick! Good to see you post here. Cheers.
  • Jay KickliterJay Kickliter Posts: 446
    edited 2009-11-29 22:47
    Thanks for sharing.
    I was just working on a similar project when I read your post, 8x8 LED's. I'm attaching what I have so far.
    I'm back in town (Queens), still having Gotham Prop Club meetings?
    Jay
  • mikedivmikediv Posts: 825
    edited 2009-11-29 22:48
    cassLan very cool thank you for sharing
    edited 2009-11-29 23:39
    Jay
    I live 2 miles south of the "original" Gotham, Notts. the locals call it " Goat-um". Its main claim to fame is that they all pretended to be mad so that the King wouldn't travel that way ( in cas he got "infected" ). This meant that it wasn't a royal route and the road maintenance tax wouldn't be levyed.
    Style and grace : Nil point
  • HughHugh Posts: 362
    edited 2009-11-30 14:47
    Toby Seckshund said...
    Jay
    Perhaps someone ought to tell them that they can stop pretending now... smilewinkgrin.gif
    Hugh - the thinking woman's Geoffrey Pyke.
    Jay,
    Its been off, but coming back [noparse]:)[/noparse]
    Rick
    NYC Area Prop Club
