CPLD based VGA and memory controller. Respinned !
A few days ago I said that I was working on a CPLD based VGA and memory controller for the propeller. The idea is that the frame buffer memory is handled by the CPLD and the propeller can read and write it and takes care of generating the sync, pixel clock and enable signals. The pixel clock has to be two times the actual pixel clock.
It has a 512Kx8 15 ns SRAM
So possible modes are: 320x240, 512x384, 640x480 and 800x600 (maybe) all of them with 256 simultaneous colors using a 3:3:2 R:G:B DAC.
Interlaced memory and video access to the SRAM is transparently done with the CPLD.
(The old single CPLD board is gone) The new board uses 2 CPLDs and is shown below. A Wiki page has also been created at propeller.wikispaces.com/Propeller_CPLD
Enjoy
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Post Edited (Ale) : 10/14/2009 10:07:43 AM GMT
Enjoy
The CPLD part is devided into 2 CPLDs, the bigger one (XC9572) has the address control portion and the small one handles the data bus.
The big CPLD soft is shown here in Verilog. Together with a simulation.
Post Edited (Ale) : 10/14/2009 9:53:36 AM GMT
Style and grace : Nil point
I'm playing with some simple memory controller with read and write autoincrement. While it does not require much registers it does logic. Work in progress.
Although I'm not an expert on CPLD or FPGA's I'm doing exactly the same at this momment, but just using Altera line.
I 'm trying the design it with my DE2 board, and I found that the full controller feets into the CPLD quiet pretty.
I calculated that i will need about 400 or 500 LE for all project and it's fine for a EPM1270 CPLD.
How many LE's have the CPLD that you're using ??
Mines pretends to be 640*480 24bit true color, maybe using 3*512KBx8bit RAM and a ADV7123 DAC for VGA out, & parallel comunication with the pchip in 8 bit bus.
My problem at this momment is the four layers PCB cost, somebody here ask me $78 (USD) each one, for a minmun quantity of 20 pcs, they are crazy !!!
I hope you get it early, my purpose of this, is not for sale at this momment, instead for a customer work.
I would choose for your first option.
Regards.
Alberto.
Envio editado por (BTX) : 10/2/2009 12:58:47 PM GMT
4 Layers ? 78 USD each for 20 pcs ? It looks expensive. Are you sure you can not get it down to 2 layers ?. I can get 22.5 Euro each board for 25 pieces, plus 19 % VAT
I'd love a board like that... Even if it is not full color, 16 bit would do fine.
I think your CPLD is a tad bigger than the one I used. If the 980 macrocells the y cite are right... well that is more than 10 times this puny little 72 mc.
Hey...chose another CPLD,and do the complete board in SMD, QFP for the pchip, why not ?
Your board looks amazing anyway.
PS: For 16 bit color, don't you need a 16 bit data wide SRAM better ?? just one posedge clk to get a RGB pixel data.
Regards.
Alberto.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
A 16 bit SRAM is the way to go for 16 bit color. I agress but only if you get a 512kx16. I think 512kx8 are cheaper but they use more board.
mctrivia: Adding VGA makes your board much more interesting!, especially if you try for the price range I mentioned, anything more expensive is not for hobby :-(.
I would like to get DVI working but don't think that 2 feasible at this time.
If you have a reflow oven or toaster oven I can sell blank PCB also They are not to hard to assemble.
Can you do that?!
Sounds a very interesting concept. The problem with the standard prop is you can have VGA and slow ram, or you can have no VGA and fast (direct access to all address/data pins) ram. But interlacing - well that opens up all sorts of possibilities. I presume this is only possible in CPLD - not using discrete logic chips?
www.smarthome.viviti.com/build
I do not have experience with Altera tools or chips, but I think a FPGA is cheaper with similar density to the CPLD you want to use but they consume more energy, are not instant on (does it matter ?) and may need an extra voltage and cost a fourth of the price or so.
Dr. Acula: It is a matter of right memory speed (< 15 ns) and CPLD density.
Let's see how much I can squeeze.
The bigest difference is the FPGAs need a second device to load the programming into them at startup.
yes the EPM1270M256C5N is expensive at $33 but it requires no external parts to support it(other then a lot of bipass caps).
It is a 1.8V core voltage but the RAM i am using is also 1.8V so I need the lower voltage rail anyways.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I find BGA is much easier to hand assemble then large quantity TQFP chips. The MBGA package is a little finer pitch then I would like but that shouldn't be to much of a problem with proper planning in the PCB design.
I'm interested in how you manage to get the results you do. Do you stencil or hand apply the solder paste?
lt's not particularly silly, is it?
for bga chips no stencil or solder is needed. the pads are solder. you only need to put flux on the board place the chip in the right place(which if you use small vias under each pin you can feel where the right place is) and reflow it.
I have been afraid of using QFN and BGA due to not being able to see the solder joints... but if it is that easy... hmm... thanks for the hint!
I am looking forward to seeing your new design - I liked the old one, but I could not justify putting $250 modules into Morpheus [noparse]:)[/noparse]
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Pcb are a little more because of tight width spacing requirements.
If you give me header info I can try to make my module directly compatible with it.
That way people could use your module to add memory to Prop#1 on Morpheus, and also to the Prop on my Propteus board...
There are two 10 pin female headers with standard Parallax Protoboard pinout:
EXP1=(+3.3,GND,P0-P7)
EXP2=(+3.3,GND,P8-P15)
They are mounted on the same place on Morpheus and Propteus.
I'll send you exact dimensions later today.
All of P0-P15 are potentially available on Propteus, and P0-P11 can be used on Morpheus (with the 23K256 removed, as it would not be needed with a big memory module installed).
I'll make sure that Largos will support your board.
I've also been thinking of a SDRAM/CPLD module, but I won't have time to attack it for quite a while - besides, you are thinking bigger (EPM1270 + mobile SDRAM) than I was.
Right now it looks like you have +3.3,P23-P16,GND
If you changed that to P23-P16,GND,+3.3 you would be compatible with: Parallax Proto boards, ucontroller.com and my expansion headers...
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
You wouldn't get one of those on a eval board for $50 either (I did ask for some goodies, got none. If only I had something to do with students, apart from mending their trails of disasters. Hey-Ho.
The WebISE soft is really not nice (It remembers me to the "M$ Programmer's workbench") but the newest version has some more friendliness: It dos not crash anymore in the schematic editor when you click on the background after moving a wire!
I have several starter kits that lay (sort of) unused on my desk, so I'd prefer not to get another one unless it is free
I'll go back to you when I get some work done.
There, I said it.
I have not looked so hard into this but they are cheap (starting at 8 dollars) and small and look like they have enough oomph and pins and threads etc to take care of RAM glue logic and VGA generation. With the bigger chips there is capacity enough left over to also provide an Ethernet interface and IP stack, and/or USB, and/or whatever the Prop is not quite up to. For free almost comes the holy grail of multiple high speed Prop to Prop links.
I'm not saying the average Prop user should be exposed to the XMOS, it should just be there providing whatever services. Like any other Ethernet, USB, random gizmo chip.
I'd like to see RAM interfaced to the Prop using 8 pins multiplexed for address and data, maybe only two pins for control. For example a byte write to a 16Mb RAM space could look like this:
xor outa, wr_pin 'Transition indicate a write operation mov outa, address 'Low 8 bits of address out in low pins shr outa, #8 'Middle 8 bits address shr outa, #8 'High 8 bits address mov outa, data_byte ' Output the data byteFrom the edge on wr_pin the external device starts clocking in the address and then the data.
Read along the same lines.
Access to Ethernet or whatever functionality would be through the memory address space rather than using up more Prop pins.
Leaves loads of free pins on the Prop to do what they were designed for.
Leon
Post Edited (Leon) : 10/3/2009 1:07:10 PM GMT
Using an XMOS to provide video/memory to the propeller... is not what I want. Not that it can't be done. I mean it is quite easy but beyond the point. Adding SDRAM to the XMOS (already done, not by me) and using it for VGA would be more appealing.... but having a propeller in the mix brings... nothing. The XMOS has better IO, more performance, memory and nice links integrated in the assembly language.
I'll keep looking for a solution here.
