Prop 40-pin Dip Out of Stock Everywhere!
Wow!
No available 40 pin DIP props until November! [noparse]:([/noparse]
Mouser and Digikey are out as well.
I suppose I'll have to start using the LQFP in my projects.
Also, IIRC, Fry's Electronics has DIP's still available online.
Hey! I'm Adam.
But YOU can call me ziplock.
Blog: braindrink.wordpress.com
"The only problem with the gene pool is that there is no lifeguard." -David Gerrold
Searider
Gadget Gangster - Share your Electronic Projects
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
I think it'd be fascinating to see a photo-diary follow a chip from Fab to warehouse.
lt's not particularly silly, is it?
How did this happen? Either there's a problem in the supply chain, inventory management, or somebody bought a truck-load of DIP Props. If it's the latter then Parallax should put a DIP version of the PropII on the roadmap.
Cheers, David
In Sweden it is some DIP40 props still available.
http://www.lawicel-shop.se/shop/
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
I would also caution you on a Fry's order. They have them but they will come in various stages of pin mangeling, from mildly bent to flattened and twisted together. Even a few cents of foam in the pack would have helped but I guess they can't spare it at $13.00 a chip.
It seems all of my projects have gravitated towards using the Prop.
In fact my PIC Kit 2 programmer has been relegated exclusively to light logic analyzer duty.
_____________________________________________________________
http://kokosplace.50webs.com/Vec Multi/Vectrex_Multifunction_Box.htm
http://www.parallax.com/Store/Microcontrollers/PropellerChips/tabid/142/CategoryID/18/List/0/SortField/0/Level/a/ProductID/332/Default.aspx
FF
Propellerpowered's had them in stock for the last month. There's one left and I'm negotiating for dozen more.
Jeff
Digikey has lots.
Dead link, Nick.
