Stepper motor controller
I have a box of bipolar stepper motors that are marked for .9A, and I need a controller for them. What should I be looking for in a controller and where can I get one cheap? Is the .9A a requirement or would a 750mA controller work, just with less power.
http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/CategoryID/35/List/0/Level/a/ProductID/375/Default.aspx?SortField=ProductName%2CProductName
in "Single Motor Double Current" mode, but you would only be able to run one of your motors from this board.
http://forums.parallax.com/showthread.php?p=798556
The MOSFETS will handle 3 Amps @ 60 Volts
joobloo237, the circuit hover1 suggested work well and can use most general purpose transistors capable of handling the voltage and current of the motors.
Another trick with stepper motors is to briefly switch to a higher voltage for starting/accelerating the motor. Very easy to do with unipolar steppers.
The simplest method of turning power to the motor off is to have a high side driver between the positive supply and the center taps of the motor winding as shown in the attached block diagram. The Hold voltage and diode is optional and the hold voltage is lower than V+. This allows you to use a higher voltage to drive or accellerate the motor and a lower voltage to hold or drive it at lower currents.
