Electronics Supplies Catalog GURUS wanted
i am looking for a female header that is .1 inch pitch. 2 rows by 5 position. I will be mounting a Board on 3/4 standoffs over a Parallax Pink module and want to put it on the underside of the board so that it will connect the two boards. Any ideas how to start the search?
It's Only A Stupid Question If You Have Not Googled It First!!
I have been back and forth with samtec China all night
Of course you caould instead order from any of several suppliers, but sometimes it's easier to make what you want out of what you can get.
· -- Carl, nn5i@arrl.net
Have you tried www.allelectronics.com
They have a lot of surplus headers, SIP's,DIP's etc.
_______$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Molex 0.75", 2x5 Stacking Header P/N: 0877971001
Molex standard 2x5 Header Receptacle P/N: 0901512110
Datasheets attached for both.
Andrew Williams
WBA Consulting
I have a bag full of them - AllElectronics.com. If I can dig the packing slip from out of the PILE of packing slips I have here I will get you the P/N. I bought these specifically FOR the PINK's little 10 pin bundle. They fit nicely and press-fit onto a 10 conductor ribbon cable, looks professional and works great.
Dave X
RCSC-10 RIBBON CABLE CONNECTOR 10 PIN FEMALE $0.35 ea
Here's the exact address: http://www.allelectronics.com/index.php?page=search&search_query=RCSC-10&x=17&y=12
Made for this application exactly. Hope this helps you.
Dave
