FPGAs, CPLDs, and PSoCs
... still trying to get my head around these devices.
Recently, Leon mentioned the Xilinix Spartan 3·(Digilent has a starter kit·was ~90 USD, currently·~120 USD)...
Hands-on is usually·better, would you all recommend getting a starter Spartan 3 (or whatever), the·online docs, and just dive in?
Or any·book recommendations, something a bit more advanced than say a "Programmable Gate Arrays for Dummies"?
Re books - due to changes and advances, should·the book's·publication date be later than some specific year?
thanks for your advice
- Howard
[noparse][[/noparse]EDIT: Added "PSoC"]
Post Edited (CounterRotatingProps) : 7/31/2009 3:52:04 PM GMT
- Howard
users.ece.gatech.edu/~hamblen/book/bookse.htm
I have a copy of the first edition and was able to do nearly all the exercises on a small FLEX10K10 device on a PCB I designed for myself.
The Digilent kit is still good value, Xilinx used to sell it themselves. The Spartan 3 is an old device and I wouldn't use it for a design, but is OK for learning purposes.
A simpler way to start is with a CPLD:
www.geocities.com/leon_heller/pld_starter.html
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I was hoping you'd chime in here.
It seems like the Altera's are more expensive than the Xilinx devices, pound for pound so to speak?
If you needed to do some generic design (not necessarily heavy on mem, or dsp), but something that would be both good to learn on and actually use, what would you recommend?
Is it a false dichotomy to be concerned about starting with a particular manufacturer's device and being stuck with a development tool set that might not be applicable to a wider set of devices? (It's my understanding that there are programming tools that are good and others that are PITA's.)
Designing with FPGAs, I've read (perhaps on your pld_starter pages), require attention to time/throughput issues more than CPLD's - or is that putting it too simplistically?
thanks for your time,
- Howard
I'd get the S3 kit, you will find more applications for it that you can download.
It doesn't really matter what you start with, as VHDL and Verilog are the same whatever chips you use. The Altera software is much easier to use.
With FPGAs you need to spend a lot more time sorting out timing issues for critical applications. For simple stuff it might not matter.
Leon
Good! The Altera boards are indeed expensive. I'm pretty comfortable dealing with a new, foreign software platform... is the Xilinix way so much worse as to steer you away from their less costly kits and eval boards?
RE the (FPGA) kits: each board seems to support a particular family, but I'm not clear if a kit necessarily supports all chips within that family. Take the recommended Spartan 3 (S3) for instance. It comes in 3, 3A, 3A DSP, 3AN, 3E, 3XL flavors (at least). Clearly the DSP version is bigger (484 CSBGA --- and if that's not a monster, how about 676 FBGA? [noparse]:)[/noparse]. Yet the other "3's" may have similar size packaging.
Let me guess the reply: something along the lines of ... aside from the ancillary/special functions (e.g. DSP, CAN) it doesn't matter which one because the underlying principles are the same?
RE: the CPLDs - they have X number macro cells and Y number of of gates. Is it correct that what you learn on a small one, like the XC9536, will apply in any case to larger devices, such as the Coolrunner-II XC2C512's (512 macro cells and a beefy 12,000 gates)?
I think the answer on that is also, yes?
OK, one more ... RE the programming languages. I've been contrasting VHDL and Verilog and I really don't see enough of a difference to swing me towards one or the other. Once you have a substantial amount of experience under your belt, which one would be preferable? Or is it really application specific?
- Howard
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
· Search the Propeller forums (via Google)
- H
The Hamblen book's also out in a fairly new edition ... both editions focus on Altera's platforms.
Amazon searches for books on Xilinix platforms shows them to be more expensive, it seems - but most of all these types of books aren't cheap.
@Cluso - I've spent several hours last night and this morning reading up on PSoC devices. (I won't have had you not mentioned the Avnet S3+Cypress PSoC combo. --- It's all your fault [noparse]:)[/noparse])· But I forgive you because these PSoC's are so very cool.
Are you able to exercise that Cypress chip on the board fully, or is it really limited to just doing the boards USB-to-FPGA interface? (The docs I've found so far are unclear on that...) The kit does come with the MiniProg thing... so I assume you can noodle with the PSoC. If so, this kit is a real deal, even if these devices are older. The original one sold for only ~38 USD !
- H
There are Avnet and Xilinx forums, but nothing is like the prop forum.
Clusso is there a decently priced CPLD kit available anywhere? I looked at the Xgamestaion but for almost 200 bucks not sure if its sort like my Hydra and geared toward gaming????
Is there anyone software package you guys can recommend for the 3A XCS400A Kit ,, did I read the documents correctly is there add on options for this kit as well?? Thanks
The Hamblen book's VHDL code as far as I can tell isn't tied to any specific Altera specific product - most of it is non-hardware specific code(he also has a lot of it on his website so you can download it and check it out on Xilinx's s/w). The only thing close to that is his use of the UP1 board built in VGA port and such on a few projects. That can easily be changed to work on a Xilinx chip/board. I didn't have much of a problem getting it to work on my Max-II CPLD's.
Mikediv:
As far as CPLD's go here are a few kits:
For Altera's MAX-II's. Cost $69.00
http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=39&No=215
For Xilinx's XC and CoolRunner (both can had for about $40.00) and are availible from Avent as well
http://www.xilinx.com/products/boards_kits/cpld.htm
And the Max-II and Coolrunner are much more capable than that CPLD used in the Hydra.
The Avnet Spartan kit uses Xilinx's standard and free design software which is included in the kit. There is other design software available but its very, very expensive.
Of course not - welcome aboard! We're on a parallel course here as your question on CPLD's and waltc's reply answered my next questions before I asked [noparse]:)[/noparse])
waltc> The Hamblen book's VHDL code ... isn't tied to any specific Altera product
Thanks, that does indeed make it more suitable for learning.
... been reading up on Xilinx's Coolrunners - they look like a good starter and are pretty flexible.
For the XC's, don't forget Leon's DIY board posted earlier.
[noparse][[/noparse]EDIT: @Cluso - thanks for the clarification.· The PSoC's are really interesting as they mix analog and digitial, in fact, their other name is "Mixed Signal Arrays", AFAICT.· For what we all do around here, these devices seem to offer cool possibilities.]
cheers
- H
Post Edited (CounterRotatingProps) : 7/27/2009 6:02:28 PM GMT
I went to http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=39&No=215
as you suggested but just want your opinion before I commit.. I have also ordered the· Avnet Xilinx Spartan 3A XC3S400A kit
I am not sure if these two kits are similar or if they are both something seperate that I should buy to learn CPLDs and FPGAs??
When I was reading up·on the MAX II Micro Kit - $69 it talks alot about it being the biggest CPLD but then also talks a lot about learning FPGAs??
I just do not have enough knowledge about this subject to make an informed decision so any help is very much appreciated I have ordered the Spartan 3A XC3S400A and it is on its way but was waiting to order the other kit until I can get some help thanks guys
Post Edited (mikediv) : 7/28/2009 12:37:51 AM GMT
the Xilinx Spartan 3's an FPGA and the Altera MAX II is an CPLD. They do share some common concepts - see Leon Heller's "Starter" link second post from the top.
- H
It's a very nice device.
Leon
I wasn't trying to be cheap but they both looked like they did the same thing as far as learning goes and the 35 dollar kit came with a 16X2 LCD display
I cant wait to get started with both and worse case for another 50 bucks I can just buy the larger CPLD kit
Has anyone looked over or bought the Xgamesation is its purpose to teach game programing or CPLDs?
@Mike - can you post a link to the $35 kit that has the LCD, please?
cheers
- H
Now you will have to decide on Verilog or VHDL language. FWIW I have chosen Verilog. It seems to suit my needs so far.
COOLRUNNER-II LOW POWER/COST STARTER KIT Lead Free: Yes
RoHS: Yes
Green: Yes NCNR $39.00 $39.00
Subtotal:
Tax:
Shipping:
Total:
$39.00
$3.24
$15.00
$57.24
You can see the kit was 35 dollars then tax then shipping but still with the 2X16LCD and the included software what a deal
Oh darn I just now really looked at the invoice they charged me 39 dollars for the base price but when you hit add to cart it states 35 dollars????? I thought the 39 was with tax but still a good deal
And if you don't mind where can I download Xilinx ISE software
Post Edited (mikediv) : 7/29/2009 6:26:45 PM GMT
Leon
Leon
Leon
if you google enough you'll find those answers. (Leon's encouraging you to learn how to fish :-P· --- in my case, PSoC, I think he's expecting me to beach·a whale [noparse]:)[/noparse]
http://lmgtfy.com/?q=VHDL+or+Verilog+with+CPLDs+and+FPGAs.+You+can+also+use+schematic+input.&l=1
Still not clear *where* you bought that kit - was it via Xilinx or Avnet?
@counterrotatingprops
I got mine through Avnet since I dont think Xilinx sells directly to the public, though it was $39
http://avnetexpress.avnet.com/store/em/EMController?langId=-1&storeId=500201&catalogId=500201&action=products&N=0&mfr=XLX&hrf=http://www.xilinx.com/products/devkits/SK-CRII-L-G.htm&term=SK-CRII-L-G
XESS is also good for tutorials and app notes, they are definitely work checking out:
http://www.xess.com/design_examples.php#XESS_Examples
Also check out these links:
http://members.optushome.com.au/jekent/FPGA.htm#Section5.1
John Kent's page on using FPGA's to build microprocessors also has some good links to tutorials and such.
http://www.fpga4fun.com/
Simple to complex projects using VHDL - the basic ones can adopted to fit Coolrunner or MaxII.
http://www.retroleum.co.uk/electronics-articles/
A 16mhz Z80 based retro computer that uses a Spartan FPGA. What makes it so interesting he documents the development and evolution of this project from using CPLD's to FPGA's.
Its pretty awesome I have not dug into it but it comes with the 2 boards 1=2X16 LCD 1=Coolrunner eval board that has 4 7 segment displays and a blank 8 pin IC socket I dont know what is for yet. It also comes with a 9V battery clip, and a real nice USB retractable cable its really long over 3 feet
Thanks guys for all the help Clusso will let you know what I think as I dig into it
Hey Benty maybe we can collaborate since you have the same kit. I am brand new to this but it all seems very fascinating
Oh forgot I bought mine from Avnet in AZ but ordered online it came very fast 3 days since I ordered it if anyone wants the address just pm me.
