TLC1543 ADC not getting data
Hi
I am trying to get an ADC to work (TLC1543). The signal is coming from a small preamplifier with a microphone on it. The problem is that I get only zero bits out. It's 10-bit so should be able to pick up the slightest of voltages.
Datasheet attached. I wired it like this:
I am trying to use "mode 1" from the datasheet. Here is the code:
Thanks for any help.
Don't worry. Be happy
Init: addr = %0000 ' Select input A0 ReadADC: HIGH cs ' Start measure PAUSE 2 LOW cs ' Activate TLC1543 PAUSE 1 SHIFTOUT dat, clk, MSBFIRST, [noparse][[/noparse]add] ' Send address SHIFTIN dat, clk, MSBPRE, [noparse][[/noparse]bits\10] DEBUG BIN10 bits,CR PAUSE 1000 GOTO ReadADC
SHIFTIN commands?
The ADC needs 21 usec to complete the conversion.
phil
I found some code that worked for a 12-bit ADC, and it works for this one! The following code works for the 1543 (it's a miracle!):
ADch VAR Nib ' selects AD external channel 0-10 result VAR Word ' result, 12 bit A/D conversion demo: ' to show off the subroutine below. 'DIRS=$FFFF ' makes all Stamp pins outputs to start 'OUTS=$1000 ' makes all pins except ADC chip select low to start LOW ADcs DO GOSUB ADwake ' makes a dummy conversion to initialize converter FOR ADch =0 TO 10 ' specify one of 11 input channels GOSUB ADread ' get millivolt data from that channel result = 14464 ** result + result ' convert count to millivolts. DEBUG DEC ADch,": ",DEC result,REP 32\5,CR ' display, use extra spaces to clear garbage NEXT GOSUB ADsleep 'NAP 1 DEBUG HOME ' repeat the demo LOOP ADread: ' entry point to give result as count from 0 to 4095 LOW ADcs ' select chip SHIFTOUT sdo,sclk,MSBFIRST,[noparse][[/noparse]ADch<<8\12] ' mode, left justify ADch SHIFTIN sdi,sclk,MSBPRE,[noparse][[/noparse]result\12] ' get result, 12 bits HIGH ADcs ' deselect chip RETURN ADsleep: ' entry point to put TLC2543 to sleep LOW ADcs ' select chip SHIFTOUT sdo,sclk,MSBFIRST,[noparse][[/noparse]$e\4] ' command=$e HIGH ADcs ' deselect chip LOW sdi ' keep this pin from floating in sleep RETURN ADwake: ADch=$b GOTO ADread▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
