WAITPEQ questions [ WAITPEQ now working ] — Parallax Forums
HarleyHarley Posts: 997
edited 2009-06-20 20:58 in Propeller 1
Chip Gracey would know, and some others should be able to explain what's happening internally during a Propeller instruction.
1. For the WAITPEQ instruction, does any document explain the operations during each of the '5+' system clocks (version 1.0 manual)??
2. And, does this imply that every 5 clocks these operations REPEAT??
ViewPort indicates proper values on the I/O lines, yet my use of WAITPEQ doesn't work. Just hangs (the 'pause'?), never a match. Works for single-bit compares, but not for multiple bits.
Harley Shanko
Post Edited (Harley) : 6/20/2009 12:07:33 AM GMT
    edited 2009-06-17 20:00
    Harley,
    Can you post your code?
    BTW, the 5+ means that if the condition is already met when the instruction executes, it takes five clocks. Beyond that one clock is added for however long it takes to get a match. So the granularity is one clock, not five.
    edited 2009-06-17 20:02
    Hi Harley,
    how should we say what you are doing wrong without seeing a single line of code ?
    If the foum-members shall be able to give an answer you have to prive detailed information about your code
    best thing is to attache your complete code and add a comment to the lines of code where the waitpeq does not work
    best regards
    Stefan
  • HarleyHarley Posts: 997
    edited 2009-06-17 20:19
    Sorry, about not including the code, I was just wondering about what the instruction was doing internally to understand things better. Here's this cog's code, with some 'test' instructions to mark timings for ViewPort use.
    BAbusRd       andn      OUTA,INTR1msk           '  set A21/pin 26 to LO level
                  or        DIRA,INTR1msk           ' set /INTR pin to output
                  wrlong    zed0,PAR                ' ensure PAR clear on entry ???
            andn  DIRA,BAbusMask
            or    DIRA,TestMsk2               ' also set A20/pin 25 to Output
            andn  OUTA,TestMsk2               '   and LO level
    :loop   'xor   OUTA,TestMsk2                 ' added for visual view in VP
            andn      OUTA,TestMsk2
                  rdlong    BAcomp,PAR wz           ' test if valid BP + BM1 value (noon-zero)
            if_z  jmp       #:loop                  ' wasn't, continue to loop
            or        OUTA,TestMsk2                 ' TEMP test use
            nop   ' stretch for viewing; ViewPort cannot display events during
            nop   '  first several hundred nanoseconds after trigger
            nop
            nop   ' 8 x 50 nsec/ = 400 nsec HI
            nop
            nop
            nop
                  waitpne   BM1mask,BM1mask         ' wait for BM1 at LO level
            andn      OUTA,TestMsk2
            waitpeq   BM1mask,BM1mask         ' wait for BM1 at hi level
            or        OUTA,TestMsk2                 ' set HI A20/pin 25 (VP pos sync)
    '        nop   ' 2* x 50 nsec/ = 100* nsec HI                                 ????
    [img]http://forums.parallax.com/images/smilies/tongue.gif[/img]eqWait      xor   OUTA,TestMsk2                 ' added for visual view in VP
                  mov       INAtemp,INA                ' get,
                  and       INAtemp,BAbusMask          ' mask,
                  xor       INAtemp,BAcomp wz,nr          ' and compare
            if_nz jmp       #[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]eqWait        ' I TRIED TO MAKE A WAITPEQ TYPE INSTRUCTION HERE
    '            waitpeq   BAcomp,BAbusMask        ' wait for breakpoint match
            andn      OUTA,TestMsk2                                                 ' TEST
    ' '             or      OUTA,INTR1msk           ' output pos. pulse on A21/pin 26 to Pod
                  wrlong    zed0,PAR                ' clear PAR after a BP event
    '              andn      OUTA,INTR1msk           ' return to LO level
            andn      OUTA,TestMsk2                 ' TEMP
                  jmp       #:loop                  ' loop forever
    ' PASM instructions take 4 system clocks, except RDLONG, WRLONG (7..22) and WAITPEQ (6+)
    ' Initialized data for 'BAbusRd'
    BM1mask       long      |<16                    ' mask for BM1 (A16) event $0001_0000
    'BAbusMask     long      $0001_FFFF              ' BM1 + 16 Z80 addr bits mask
    BAbusMask     long      $0001_001F              ' BM1 + 16 Z80 addr bits mask    TEST
    TestMsk2      long      |<20                    ' temp VP 'marker for this cog  TEST
    INTR1msk      long      |<21                    ' mask for 'INTR' on A21/pin 26
    zed0          long      0                       ' to clear a 32-bit register (PAR)
    ' Unitialized data for 'BAbusRd'
    BAcomp        RES       1             ' SBPt 'breakpoint' value to compare w/BAbus value
    INAtemp       res       1
    Harley Shanko
    edited 2009-06-17 20:22
    I don't have my documentation handy, but I believe the first 4 system clock cycles of the WAITPEQ/PNE are the same as for all instructions. There's an instruction fetch, operand fetch, execution, and destination store. The WAITPEQ/PNE then has a clock cycle where the wait condition is tested. If false, that cycle is repeated. If true, the next instruction fetch cycle begins.
    edited 2009-06-17 20:46
    Mike Green said...
    That's what I'd expect, except I've yet to get WAITPEQ to work with other than a single bit compare. Not what's needed, for sure. I have 3 cogs in two Props that I've been hoping to get operational, but this one instruction has been a terrible struggle.
    Thanks for the opinion, Mike.
    Harley Shanko
  • AleAle Posts: 2,363
    edited 2009-06-17 21:03
    We checked some time ago, last year, and those wait instructions take 6 or more cycles, not 5.
    Btw, I also never got multiple bit match to work.
    Visit the home of pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-06-17 22:18
    Thank you Ale.
    I wasn't too concerned whether it was 5 or 6 clock times, though closer to 0 clocks would be desirable, of course, as I'm trying to replace some TTL functions in firmware.
    Good (really BAD!!!) to hear that others have had problems with multiple bit matching. There must be some sort of unwritten 'trick' for this instruction to work properly. I wish Chip & company would provide a good example of how to really use this neat instruction, exactly what I need. hint, hint. yeah.gif
    Somebody said...
    Harley Shanko
    edited 2009-06-17 22:29
    Phil,
    Rereading your comment, if the first 4 clocks are involved with setting up the condition, how does the instruction take into account the following INx values if the first doesn't match? It seems it would have to at least again read INx and mask it to compare with a desired match, no?
    It seems it has to evaluate the INx value over and over each time, not just the first INx value seen on entry to WAITPEQ
    Somebody said...
    Harley Shanko
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2009-06-17 23:29
    Mike Green said...
    Here's a question I've had for a while, with all of the WAIT... commands: (maybe my logic is wrong anyway, but...) say your code is executing on cycle 1...5...9...13...etc. you add a wait and it pauses the cog for 7 cycles, so now the next code executes on 20...24..28? Am I right? or does it continue on the previous cycle rhythm (of course then it would matter that it executes in "5+ cycles")? Anyway I think I already answered my own question, but I'd like to hear it from you (or someone who knows).
    April, 2008: when I discovered the answers to all my micro-computational-botherations!
    edited 2009-06-17 23:38
    Here is a link that may help.
    edited 2009-06-18 00:16
    Bobb said...
    Correct, one exception though, hub instructions are bound to a 16n+m grid, i.e. if you don't get it right you have to wait (or rather the instruction takes longer).
    edited 2009-06-18 00:21
    Thanks Phil,
    From Chip's comment, it appears that the whole sequence would have to repeat to get Mask anded with INx, then State compared against that result which would change over and over, else is a static INx state. So internally it would have to appear to 'jump' back to Chips step 0) from 3) if no match, thus my program always hanging up in the WAITPEQ instruction. Or am I understanding what has to be happening?
    I sure would like to get this one pesky, but valuable instruction operational. yeah.gif
    Chip said...
    The COGs go through the following state sequence, advancing each clock cycle:
    0) read source N
    1) read destination N
    2) read instruction N+1
    x) any wait cycles go here (0...infinity clocks)
    3) write destination N (N=N+1, goto 0)
    So, the source is read 3 cycles before the destination result it written. This timing scheme gives the ALU two clocks in which to settle after I, S, and D have been read.
    Harley Shanko
    edited 2009-06-18 00:42
    No. The read of, and compare with, INA are all done during the wait period. Each read/compare takes one cycle. It's not a normal source fetch. Remember, the source is the mask, and the destination is the compare value. They only have to be fetched once. The read of INA is not part of that sequence.
    edited 2009-06-18 01:15
    Phil said...
    Ah, OK yeah.gif , now that makes sense. Read of s-field, of d-field, and of instruction is done ONCE, and the comparison does NOT involve a read, but a direct comparison of the INx each clock time there after. Is that better? (Wish the manual had been a bit more detailed in spots.) Thanks. It helps some to understand this portion of WAITPEQ, but don't yet find what it takes to get the actual asm instruction to function.
    Harley Shanko
    edited 2009-06-18 01:43
    Harley,
    Are you sure that the value being read into BAcomp is long-aligned in the hub? If it's declared as a word, it might not be. Moreover, even it it is a long-aligned word, you'll be getting extra garbage in the 16 msbs.
    Don't forget the the two lsbs of par are always zero.
    edited 2009-06-18 06:15
    Phil said...
    BAcomp is long aligned. I've used PASD to single-step through this cog many, many times to ensure such items are proper. And PAR contains the proper value. That is what gets me; seems everything is proper, but wish there were a way to 'peek inside' WAITPEQ and see what's not right.
    Unless this cog's code, listed above several messages, has a subtle error, it seems it should work OK. I'm not giving up as I'm certain there are some who DO have working WAITPEQ. Hanno's ViewPort makes use of it, for one.
    Thanks for providing some ideas and clues, Phil.
    Harley Shanko
    edited 2009-06-18 07:01
    I have used waitpeq correctly, but only for 1 bit.
    If you do not get anywhere, I posted code about a year ago that scans and stores the 32 I/O pins each clock cycle - uses 4 cogs interleaved. I think Jazzed Propalyzer may now do a better job. The link is in his signature.
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    · Search the Propeller forums (via Google)
    edited 2009-06-18 16:17
    Harley said...
    Okay, good. The point I'm slowly getting at is this: waitpeq compares the anded part of ina to the entire compare value. If there are one bits in the compare value where none exists in the mask, waitpeq will wait forever, regardless of what's on the pins. I'm sure you know this (as your simulated waitpeq illustrates), but the one thing we can't see from your listing are the actual values coming in from the hub for BAcomp. Your TEST value ($0001_001f) for BAbusMask makes me a little suspicious, since it has fewer ones than the one that's commented out. If BAcomp were ever equal to $0001_0020, say, your waitpeq would never terminate.
    edited 2009-06-18 16:44
    Phil said...
    I used the mask $0001_001f only to reduce the number of bits to compare with.
    Bit 16 is a 'strobe' for the lower 16 bits, 0000...FFFF, and the compare value is the result of a 0000..FFFF value ORed with a bit 16 ONE before passing it into this cog. So only when bit 16 is a ONE is it a valid time to compare. I've read the WAITPEQ asm instruction a jillion times and still cannot understand why it doesn't seem to want to work with multiple bits. I thought maybe it was an endian problem, but looking with PASD it all looks proper. So why doesn't it work. I'm losing hair over this dilemna. I'm at the age when baldness is acceptable, but don't want to go that way. yeah.gif
    I read the messages in your 'WAITPEQ Timing, Setup & Hold Times, etc.' posting. Interesting, but was hoping for some 'light' on my problem.
    Harley Shanko
    Post Edited (Harley) : 6/18/2009 4:50:28 PM GMT
    edited 2009-06-18 17:14
    Harley said...
    That's the point I was trying to make: it doesn't reduce the number of bits to compare with. The comparison, after masking, is made with all the bits in the compare value. If there are any "one" bits in the compare value that aren't matched with "ones" in the mask, the waitpeq will always hang.
    Harley, what are some typical values for BAcomp that are causing trouble?
    edited 2009-06-18 19:53
    Phil,
    Right now the hardware test circuit is only running in a loop from 0004h .. 0014h. That was why I had a 'test' mask of 0001_001F. Full mask is 0001_FFFF.
    But unless BAcomp is 0001_0000, no comparison occurs. That single bit only operation.
    1. I wonder what the purpose of the Z-flag is using WAITPEQ? Seems this would occur if 'pause' state on exit the istruction had the Statebits of Zeros corresponding to ONEs of Mask bits. A known state, any way, prior to entry of the WAITPEQ
    2. From all comments, it appears all the hardware exists to do a comparison of State and Mask ANDed INx each clock cycle in/during the pause state. True? Cool, if so.
    Harley Shanko
    edited 2009-06-18 20:19
    I didn't ask this before, but does $0001_0000 reflect an actual pin state? IOW, is pin A16 actually going high to trigger the breakpoint?
    1. 'Seems like it would always exit with Z set if wz was specified, since the compare has to be "equal" at that point.
    2. Yes.
    Post Edited (Phil Pilgrim (PhiPi)) : 6/18/2009 8:35:39 PM GMT
    edited 2009-06-18 22:13
    Phil said...
    Yes, this is a buffered Z80 M1 signal (BM1), so when valid (= ONE) is when the address of an instruction is valid.
    Strange how Hanno's ViewPort can capture and display all these lines and validate the actual addressing on the lower 16 lines.
    Harley Shanko
    edited 2009-06-18 22:22
    I assume you're inverting the /M1 output before the Prop sees it, right?
    edited 2009-06-18 23:05
    ANYONE WITH WAITPEQ EXPERIENCE, PLEASE COMMENT ON THIS 'GEM
    I've removed (hopefully) all my 'test' code so this should be easier on the eyes/mind. Why might this hang at the WAITPEQ?
    BAcomp is a 16 bit value ORed with bit 16 a ONE. The ':loop' waits for a 0001_0000 .. 0001_FFFF value to be passed from SPIN. Then the 'fun' should begin; that is a match should occur. With this Mask only 0001_0000 .. 0001_001F are monitored for testing.
    What am I not doing right? ViewPort sees the correct values on the lower 17 lines!!
            andn  DIRA,BAbusMask
            andn      OUTA,TestMsk2
    Harley Shanko
    edited 2009-06-18 23:18
    Harley, I don't know what to say. The reason it's hanging is because you're not getting a match. A couple posts ago, I asked what a typical, troublesome value for BAcomp would be. That's the information we're missing. Also, I wanted to verify that you are, indeed, inverting /M1 to pin A16.
    Can you show us the program that feeds values, via par, to the code you've posted above?
    edited 2009-06-18 23:46
    I took the sample code and basically dropped it on the demo board. It runs in the monitor cog waiting for $00010007. A trigger cog will issue that pattern after a 4 sec delay. After 4 sec waitpeq will find a match and indicate that to the main program (turning on LED P23..P20). I know that's not exactly helpful, we've been there before, but it proves that waitpxx itself does what it's designed to do.
    edited 2009-06-19 00:38
    @Phil,
    I thought I mentioned the range of EPROM values, the lower 16 bits; they are 0004 .. 0014 in the test circuit. None of those ever match with what's passed in PAR. Using PASD I can step through this cog's instructions and see what's being picked up via PAR and stored in BAcomp. That is working fine. And, YES, BM1 is /M1 inverted; that is seen via ViewPort. That's been OK for many moons.
    Here's the Spin code. Prop#1 send commands and data to this, Prop#2.
    '*  Control_2Prop2  v 0.1      *    mod  3:25 pm  18 Jun.2009
    '*  (C) 2007 h.a.s. designn    *
    '*******************************  ViewPort = v 4.1.1 , PASD = v 0.3 latest versions
    CON
      _clkmode      = xinput + pll16x
      _xinfreq      = 5_000_000     ' ext. clock @ 5 MHz on pin 30 from Prop#1, PLL=16x
      Prop_Tx       = 22            ' Data to Prop1, pin 27/A22
      Prop_Rx       = 23            ' Data from Prop1, pin 28/A23
      Prop_Baud     = 115_200       ' for Prop1 <=> Prop2 communications
    '  maskF0        = $0000_00F0    ' 2nd lsb nybl mask                    WHERE USED ???
      BM1 = 1 << 16                       ' Kuroneko code
      time = $1FB                       ' Kuroneko code
    VAR
      long stack[noparse][[/noparse]250], rxpin,  txpin, c, rxbyte, rxcheck, txbyte
      long PodCntl, SBPt, CmdP2, CmdVP, id, dataReg, statReg, keyReg, AdDaStReg
      long triggermask, triggerstate, NyblReg, BAbusReg, n, Prop2Reg, INTRPT, BAid
      long  storage                       ' Kuroneko code
    OBJ
      PropSer       : "FullDuplexSerial"     ' for Prop1/Prop2 serial communications
      vp            : "Conduit"              ' transfers ViewPort data to/from PC - ver 2.0
      qs            : "QuickSample"          ' VP captures INA, variables, +1 cog @ 20 MHz
    '  dbg           : "PasDebug"    '<== use for PASD debugger (MUST include .binary file)
    '  Prop#2: handles BAbus address comparator, interrupt 'logic', other Pod i/f signals.
    '  Connects to Prop1 via rx/tx pins, and both Props connect to a 'Pod' board.
    '****email lc/37cc594a*****************************************************************
    PUB Main|frame[noparse][[/noparse]400]
      vp.register(qs.sampleINA(@frame,1))  '1 cog samples INA at 20 MHz = NEW VP commands
      vp.config(string("var:io,PodCntl,SBPt,CmdP2,CmdVP,id"))           ' VARs to display
      vp.config(string("lsa:view=io,timescale=500ns,trigger=io[noparse][[/noparse]16]r"))  ' init lsa.display
      vp.config(string("edit:SBPt(mode=text),CmdVP(mode=text)"))        ' VARs to edit
      vp.config(string("start:lsa"))
      vp.share(@PodCntl,@id)  'share memory from 'PodCntl' to 'id'  END of VP init <<===
      PropSer.start(Prop_Rx, Prop_Tx, %0000, Prop_Baud)      ' sets comm w/Prop1
      id := cognew(@CntlP2,@CmdP2)      ' sets up Control pg#2 'logic' for CntlP2; CmdP2@PAR
    '  id := cognew(@entry,@CmdP2)      ' this sets up Control pg#2 'logic' for PASD
      id := cognew(@BAbusRd,@SBPt)      ' SBPt value @ PAR for BAbusRd
    '  id := cognew(@entry,@SBPt)       ' set up logic for PASD
      BAid := id                        ' save cog# for SBPt stop/restart
    '  id := dbg.start(31,30,@entry)    '<---- Add for PASD Debugger <<===
    ''PUB init
    '  storage := BM1 | $ABCD                       ' Kuroneko code
    '  id := cognew(@trigger, @storage)                       ' Kuroneko code
    ''  id := cognew(@entry,@storage)       ' set up logic for PASD
    ''  repeat
      repeat  ' Main Loop ************ deals with signals between Prop#1 and Pod *********
        if (c := PropSer.rxcheck) <> -1      ' check for Prop#1 command and data
          Prop2Prop1                         '(Pod i/f via assembly rather than Spin cogs)
    PRI Prop2Prop1             ' process Prop #2 commands from Prop#1
      if (c & $C0) == $C0           ' test if is a valid 'Control Pg 2' command
        CmdVP := c                  ' save copy for Viewport use
        CmdP2 := c                  '  if so, set variable CmdP2 (asm picks up in 'Cmd')
      case c
        $80 :                       ' used during Init; transfers 'title', Chipver and #cogs
          PropSer.tx(c)             ' echo that command value for Prop#1 'handshake'
          waitcnt(8000_000 + cnt)   ' wait about 100 ms  IS THIS TIMING RIGHT (below too) ???
          PropSer.str(@title2a)     ' send first text 'title' to Prop#1
          waitcnt(800_000 + cnt)    ' wait about 10 ms                            ???
          PropSer.str(@title2b)     ' send 2nd 'title'
          PropSer.tx(CHIPVER + $30) ' send ChipVersion
          PropSer.tx(id)            ' send #cogs used
        $81 :                       ' looptest Prop#2
          PropSer.tx(c)             ' echo command
          repeat
            c := PropSer.rxcheck    ' check for loop test value
          while c == -1
          PropSer.tx(c)             ' return 'loop test value'
    ' $82 : ' - unused
        $83 :                       ' returns Breakpoint address to Prop##1
          SBPt := $0001_0000        ' set bit 16 true -- get ready to set Breatpoint value
          repeat                    '
          while c == -1
          SBPt := SBPt | (c << 8)   ' store HI byte of BreakPoint register
          repeat
          while c == -1
          SBPt := SBPt | c          '  add LO byte
          PropSer.tx($83)           ' let Prop#1 display BPt bytes held in Prop#2 (comment out to 84)
          c := (SBPt >> 24) & $FF   ' get ms byte, return to Prop#1; now return as 4 bytes
          PropSer.tx(c)
          c := (SBPt >> 16) & $FF   ' get 2nd ms byte
          PropSer.tx(c)
          c := (SBPt >> 8) & $FF    ' get 2nd ls byte
          PropSer.tx(c)
          c := SBPt & $FF           ' get ls byte
          PropSer.tx(c)
        $84 :                       ' returns Pod control bits
          PropSer.tx(c)
          c := INA                  ' get Prop#2 pin states
          PodCntl := (c >> 24 ) & $7      ' only get lower 3 bits of ms byte
          PropSer.tx(PodCntl)       ' send to Prop#1
    ' $85..$8F and $92..$FF codes unused; codes $000 ,, $6F for D/K communications
        $90 :                       ' returns $90 code and a count each time D/K RUN pressed
          PropSer.tx(c)             ' echo '90' code
          PropSer.tx(n)             ' send 'count', then increment it
          n++
        $91 :                        ' unused
          COGSTOP(BAid)                                     ' stop that cog
          waitcnt(40_000_000 + cnt)                         ' wait about 1/2 sec  ???
          BAid := COGNEW(@BAbusRd,@SBPt) ' sets up Control pg#2 'logic' for CntlP2; CmdP2@PAR
    '************************  End of Spin code, next Assembly  *************************
    DAT           ORG       0
    @ Kuroneko,
    I wonder if there is any difference between true input signals and a cog which applies values to your setup's output pins? I'd hope not. These input signals are supplied from TTL logic through 220 Ohm resistors, YES, low to minimize RC rise/fall time degradation and delay.
    I tried your code which output values but didn't get matches as I'd hoped. I'm glad you could get the sample code to work. I'm stumped, honestly.
    Harley Shanko
    edited 2009-06-19 01:34
    Harley,
    It looks like SBPt is the value that gets sent to BAcomp, am I correct? What I see, though, is SBPt becoming non-zero ($0001_0000) before its value is fully-formed. As soon as that happens, your breakpoint program will seize upon it and look for that value. In this case, it will be looking for an address of zero, which is not in your stated range of $0004 to $0014.
    What you need to do is compute your breakpoint value using a temporary variable, then assign it to SBPt.
    edited 2009-06-19 01:49
    Somebody said...
    You are correct about SBPt being sent to BAcomp. That value in PAR gets zeroed IF and after WAITPEQ exits. Do you mean what's in PAR will be reflected back to SBPt? The loop at the top of asm code awaits another user input.
    In use there is a keypad which the user keys in the breakpoint value. That gets sent from Prop#1 to Prop#2 to form SBPt.
    Harley Shanko
