Troubleshooting the Propeller chip
I got my prop plug connected to the chip and EEPROM and peripherals, but it doesn't work.· Could it be my prop plug and not the chip?· I have a feeling it is the plug because I also put the chip and EEPROM on a breadboard and it didn't work...
Thanks.
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
Post Edited (Vaati) : 5/1/2009 11:01:20 PM GMT
Thanks.
Can you post images of your setup .. What board are you using ?.. What is the error ?
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Thanks.
Under 'Device Manager' does the PropPlug show up under 'Ports' when the prop Plug is connected to the USB Cable ? Remove it and reattach it to see if it enumerates ..
See attached Image.. Can you confirm the Wiring is as per attached simple example ?
Can you confirm that the Propeller IC is functional ?
·- I assume the board·was powered when you 'Hit F7' !
John
Post Edited (QuattroRS4) : 4/30/2009 3:12:09 PM GMT
Thanks.
@Vaati - That should indicate that the Prop plug is found and the drivers are installed correctly - Is the Prop Chip Ok ?
Can you review and confirm the suggestions outlined in my previous post.
John
Also, I know that the propeller and EEPROM chips do NOT warm up.· It just seemed that way because my hands were cold.·
Thanks.
If you build the circuit on bread board as outlined in the attachment on my earlier post and leave out the 'optional' sections. This would be a 'bare bones' setup. Please ensure that you have good VSS and VDD connections - these are 'on both sides of the prop' not shown in the illustration !
So leave out the EEprom and crystal .. when you are sure it is correct - try F7 to see if it finds the prop.
John
Post Edited (QuattroRS4) : 4/30/2009 4:16:42 PM GMT
Thanks.
Incidentally when you said '..and tried my best to wire it correctly'· - am I to assume that there may have been a mishap at this point ?
Also - Prior to connection to the prop can you confirm that you do actually have 3.3v·!
John
Post Edited (QuattroRS4) : 4/30/2009 4:26:17 PM GMT
Thanks.
Thanks.
Thanks.
What operating system are you using ? XP or vista 32/64 ?
John
John Twomey
Rick
@Vaati - Can you post an image of your 'Bare Bones' set up ? Did you measure the 3.3v between VSS & VDD ?
John
Thanks.
John Twomey
Thanks.
John
Thanks.
Can you post a pic of your bread board setup .. just as a last·shot at it·..
John
I've been following your troubles since your homebrew PropPlug thread, please post pics of your bread board setup as its much easier for some (like me) to spot check wiring on a breadboard rather than a pcb with a top/bottom. I have my own Prop setup in a breadboard, ready for comparison.
I hope you get things going soon.
Rick
Thanks.
Thanks for the Pics, I was really hoping to see a wiring mistake, but I looked closely and I dont see one. If your hardware is all working you should def be able to hit f7 and identify the prop.
Rick
Thanks.
Like the attached image ... except the port no. will represent whatever port is assigned to your Prop Plug.
John
