Puzzling Problem-- Home-made Serial to Propeller
I got a Propeller Development Pack (http://www.gadgetgangster.com/grab-a-designers-pack/36-submit-project/87-get-a-designers-kit.html), the Propeller chip, and the EEPROM about a week ago.· I intended to make a Serial to Propeller (http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf) with it.· The images of the circuit are in the following posts, as well as a discussion as to what is amiss.· I hope all who wish to do so post·their thoughts and opinions.
Thank you.
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
Post Edited (Vaati) : 4/26/2009 10:10:04 PM GMT
Thank you.
what is resistance between 3.3 and ground
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
3.1415926535897932384....
Parallax Engineering
13v is why it is warm. if you have 3.3 there is no short. try measuring voltage at each 3.3 v pin on the pin.
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
Is there any chance you could post a picture of top/bottom of the board?
I expect that Nick will be responding to this thread soon, and it would
help all of us if we could see your setup. (Perhaps spot something)
As for grounding the unused serial lines, no don't do that. There should
be a single ground connection that should be made. Does your homebrew
prop-plug work on another board?
OBC
New to the Propeller?
1. DO NOT PANIC. As it used to say in the front of my old Yamaha maintenance manual "Repair of Yamaha motorcycle requires great peace of mind". Better to build something one day, check it the next day and run it the third day.
2. Check all your connections a few times, which I'm sure you have.
3. Check all your connections again.
4. Power the thing up and check power supply is correct in all the right places and NOT in any places it should not be. If you have a DIP Propeller in a socket it's as well to power up with the chip removed and check power comes to the correct pins and no others.
5. You will want to know if any serial data arrives at the Prop from the PC. In the absence of an oscilloscope here is a good trick my dad taught me when I was a teen: Connect a small radio/PC speaker or some cheap headphones to the Props Rx pin via a capacitor say 1uF and send a pile of data from Hyperterminal or such on the PC. You should be able to hear if anything arrives at the Prop. If you have a LED and a resistor (1k say) you could try connecting that to see if anything comes.
6. No idea about GadgetGangster boards but on my board I have a DIP Prop in a socket so I can remove the Prop and connect the Rx pin back round to the Tx and loop the data back to Hyperterminal. Again the headphone trick can be used to follow the signal back through the circuit.
7. Check something is happening on the Props reset pin, a LED and a resistor are handy here.
7. I first started my Prop with no crystal attached, the PropTool should still be able to find it.
8. Come back when you have done all the above.
2) The RS232 to 3.3V TTL adapter you've cited does work most of the time. It's marginal in terms of the voltages supplied to the RS232 interface. The +3.3V works for many RS232 ports, but not all. RS232 also requires a source of negative voltage and the adapter uses DTR's idle voltage for that. Try your board with a different serial port if you can. Recheck you wiring and your cable.
That or something is going on with your serial circuit. Older RS232 ports seem to be less accepting of 3.3v. Or you might have mis-wired something. Again, though, a multimeter would really help you to troubleshoot.
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Post Edited (jazzed) : 4/23/2009 7:01:40 PM GMT
P31: 3.27v
Res: 3.22v
I think that's exactly what I got, so...
Is that good or bad?
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
Added: Static voltage measurements you provided do not give much useful information.
--Steve
Post Edited (jazzed) : 4/23/2009 7:40:26 PM GMT
What is connected to pin 1 (square pin)?
I'll post other problems if I see them.
--Steve
--Steve
