Cool that regulator !
Here is a trick I use to cool the 5v reg on the proto board. Make a roll of 10 pennies and tape them together leaving the top and bottom uncovered. Then balance the roll on the regulator and you have a simple $.10 temp heat sink !
Earl
Earl
What is your input voltage?
OBC
New to the Propeller?
Awesome!
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Now if you have .10 of copper pennies you have more than .10 worth of copper.
OBC
The money it would cost to manufacture one is more than what it would cost to build one OUT OF MONEY!!!!
The government should make pennies out of steel entirely or dump them.
I won't go deep into this; this forum is not for political discussions!!
Go to any pool supply or a place that sells Hydrochloric Acid(HCl). Get a plastic container, pour a cup or so of acid into it. Get some pennies and make a TINY nick on the edge of each one so that you break the copper plating. Then get the pennies and put them in the acid for a couple of days. What's left? Hollow copper pennies...
Barometer
RC RX
Ping Module
Compass
Nunchuck
GPS Unit
XBee at 25mw output
Pretty soon, the reg out is gonna die !!!!!!
YES ...The Pennie roll gets VERY warm...Don't put in pocket ....
I have been able to achieve this with 4 days in vinegar. Imagine how long it would take with Hydrochloric Acid
Earl
Edit at 6:42
See the penny roll ???
Post Edited (Ole Man Earl) : 4/20/2009 12:42:40 AM GMT
You call that messy? Dude, you have no idea.....
http://futurlec.com/Heatsinks/TO220S.shtml
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
· -- Carl, nn5i@arrl.net
But what are the final chemical products of this reaction? What's a suitable way to dispose of them?
I certainly wouldn't want to put anything like this down the drain, and I'm not sure the garbage man
would take something marked "copper and hydrochloric acid experiment waste".
I noticed that your copter is very close to my design, how do you orient it? ( x ) from the front or ( + ) ? I ask because I did a bit of looking into using the + design for very fast maneuvering of angles @ 90s ie hard left, hard right, hard forward, hard back. I eventually went with an x design with 2 motors cw, and the other 2 opposing corners going ccw. I am interested with your use of electric engines. I am using 4x Erickson FE120's, I get about 42lbs of thrust and she can can off like a rocket! I am to the stage now where she can hover level and slowly change directions but no high speed anything, except for takeoffs! she gets out of radio range in about 23 seconds of full throttle, max altitude clocked right now is only 9k feet but that's a software restriction. Tell us more about your please, I love to hear alot about other peoples projects and see if I can maybe avoid an expensive goof of my own !
Jimmy
Hydrochloric acid HCl.· There's lots of this in human barf (your stomach produces it to digest food).· Perfectly safe in the drain, as long as diluted.
Baking soda for neutralizing the acid when you're done.· Use this just as a rinse after dumping the acid and washing everything off with a hose.· If you pour it directly in the acid, it will react quickly and possibly cause acid to fly around.
Cupric chloride.· This is very soluble in water.· There will be very little of this anyway; if the HCL attacked the copper the process wouldn't work.· If you have any copper pipes you run a little down the drain daily.· Your water heater probably is connected by copper pipes.
Sodium chloride (from the neutralization of hydrochloric acid with baking soda).· That's common table salt.
Zinc chloride.· If you have galvanized pipes you run a little of this down the drain daily.· Not to worry.
Hydrogen gas H2 (from the reaction between HCl and zinc).· It's the bubbles produced in the acid.· This is flammable and can explode, so do the experiment outside on the patio to avoid collecting hydrogen in the house.
Carbon dioxide (from the neutralization of hydrochloric acid with baking soda).· Perfectly safe.
Be sensible and don't spill HCl where it will burn you or damage your clothing or household furnishings, and it will be pretty safe.· Don't breathe the fumes, which will have HCl in them too.· Wash everything with a solution of baking soda in water, or at least rinse it off thoroughly in running water,·before taking it back in the house.
Post Edited (Carl Hayes) : 4/20/2009 9:50:37 PM GMT
Sill haven't tryed the heat sink; but fanning them out to get more surface area out of them sounds like a good idea.
It is strange that what has naturally existed on earth for thousands of years is now believed to destroy the planet
