MOSFETs AGAIN
hmlittle59
Hello All,
I had to step back an take a breather and look up more info, trying to under stand this part. Everyone seems to have there own spec.(FairChild,Vishay..etc) and the Voltages seem to be all over the place. I thought I was set with P-chan. enhanced and my logic was 180 deg. out. Everyone's explanation and my thought/logic was just clashing. I think I'm almost cleared of mental block so hear I go again. AS before, I currently have a BS2e directly driving a NTE R56(Normally Open) Solid State Relay($3.50)(5vdc 2sec). This works as I wanted, but I'm looking to replace the NTE part with a (5v, 3+ AMP) cheaper part.
This time around I think that I may have found the correct part. This is for ya'lls review and comments so correct me were I'm wrong. I've ordered parts to test out Vishay part (N-chan 844-IRL630SPBF) from Mouser.com. Another part that looks close is FairChild(ND6060L). Some of the symbols on the Data sheet I can figure out but others make no since.
The voltages are any were from (2.5, 4.5,5.0, 8.0,10.0, 20.0, 25.0, 30.0....100, 200, 300), I mean com on guys this was driving me crazy trying to wade thru. Why so many?
I will try and attach a simplified schematic from ExpressSCH, let me know if its viewable or should I take a picture?
I want to Pulse(BS2e 5vdc one time for 3 sec.) the Gate causing it to conduct from the Drain to the Source, this will act as a momentary push button switch shorting 5vdc to Gnd. activating the motor. Also I've seen resistors either on the Drain to load or Source to load. Taking the BS2e LOW turns off the Mosfet. A resistor in series and resistor to grd are connected to the Gate. Now is my logic correct???
thanks to all
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
Post Edited (hmlittle59) : 4/19/2009 5:25:00 AM GMT
thanks to all
hmlittle59
ExpressSCH appears not to be able to do either...GREAT!!! Let me redo it in DipTrace
hmlittle59
Also, if you have a graphics program, like Corel PhotoPaint, some CAD apps will let you select and copy drawings, or portions of drawings, to the clipboard. PhotoPaint has a "New from Clipboard" function that automatically generates an image file from the clipboard that can then be saved in a multitude of graphics formats.
Post Edited (Phil Pilgrim (PhiPi)) : 4/18/2009 3:14:51 AM GMT
Dave
In other words for the IRL630 I would not run it much above 100V Vds, 5V Vgs, and 3A Id, and even at 3A continuous current it would need a good heat sink to dissipate the 3.6W of power and keep the temp reasonable.
I used the downloaded and used the program you suggested and it seems to have worked great. I've attached a simplified version of the Circuit I'm trying to get working, hope this will help to clarify any confusion.
thanks again Phil for the program.
PS. I edited this file to attach the Simplified drawing of my Question/Problem/Steep Learning Curve!!!
thanks again
hmlittle59
Post Edited (hmlittle59) : 4/19/2009 12:32:58 PM GMT
Your schematic doesn't make any sense.· You show +5 going directly into the MOSFET.· This will blow the MOSFET the first time you turn it on.· I think what you're trying to say is that the one input to the motor unit is 5 volts when the control is open.· Are you driving the motor directly, or are you driving a conroller?· Do you have any idea what the current requirements are for motor controller input?· The MOSFET you selected will probably do the job, but it may be an overkill for the application.· You may be able to use a much smaller transistor, but you would need to know the current requirements.
Dave
Of course, I could be wrong? (It must be noted most of my MOSFET research has been SMPS related)
Don't make the resistor too small or you'll get high frequency oscillation. Don't make it too big or the mosfet will turn on too slowly. Both of which are bad news.
The Motor and Electronic controls are in a unit already(Not my Unit), I've tried checking the current but the Electronics senses this an activates the unit. I called the company and they said it was around .5 Amp., I'm just replacing the Momentary Push Button switch with a Electronic switch and BS2e. I can see were I may need a resistor on the Drain side to protect the Mosfet. The Mosfet is only acting/replacing a Momentary switch.
Presently when the switch is pushed, 5vdc is shorted to grd inside the unit, I guess that's why they have the current so low already.
thanks
hmlittle59
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 4/20/2009 1:38:52 PM GMT
Dave
Remember I'm replacing the switch, it was just there for show ONLY, also I don't understand the diode. My understanding of the N-chan. Mosfet the Gate is Pulsed with 5vdc which will conduct(Drain to Source), causing a shorting of 5 vdc to grd(simulating pushing of a switch) to the Motor Unit itself. I stream line the schematic some more...any thoughts please.
thanks
Opps.. forgot to attach the file
hmlittle59
Post Edited (hmlittle59) : 4/21/2009 12:29:59 AM GMT
Post Edited (Phil Pilgrim (PhiPi)) : 4/21/2009 1:47:18 AM GMT
Since your load is an unknown black box, the diode is there to protect the FET if the load happens to be inductive.· The load may, for example, have a relay coil inside it.· You don't say.· Perhaps you don't know; they may have sealed the thing so you can't tell.· Let's assume for the moment that it is inductive.·
Let's say the FET is conducting, and the diode was left out.· There's a current (positive-to-negative) flowing downward through the load, and downward through the FET.· The diode is not conducting because it ain't there.
Now shut off the FET.· The FET tries desperately to stop the current.· The load, being inductive, tries desperately to maintain the current.· That's what inductors do.· There is strife, and the inductive load will win, melting the FET, because there is no other path for the current to take.· Pffft.
Now put the diode back in, just as I've shown it.
Let's say the FET is conducting, and the diode is in place.· There's a current flowing downward through the load, and downward through the FET.· The diode is not conducting because it can't conduct downward the way it is positioned in the circuit.
Now shut off the FET again.· The FET tries desperately to stop the current.· The load, being inductive, tries desperately to maintain the current.· The current will continue to flow downward through the load for a little while, but the diode is there, so that same current can flow upward through the diode and doesn't get forced downward through the FET.· The FET's job is now very easy, because no one is fighting it; the diode earns a medal for heroism.· The current will circle through the diode and the load until it dies out (from the resistance of the load) or until the FET is turned on again, whichever occurs first.
That four-cent diode (I like 1N4001 for this)·will save a lot of (much more expensive) FETs in a surprisingly short time.
Alternatively, if they are sensing logic levels, and they use only a switch externally, they must have included a pullup inside the box anyway.· Agree?
Post Edited (Carl Hayes) : 4/21/2009 2:35:27 AM GMT
'Missed the 1/2 amp part. That does imply a relay of some sort. But look at his schematic: the MOSFET shorts +5V to Gnd.
HMLittle, you need to pay closer attention to Carl's schematic and follow it assiduously!
The Company did tell me before that there is a relay inside and their electronics handles the pushing of the button. I have this working with a (NTE R56 -D SSR) but I was looking for the BEST replacement part(cheaper) switching Mosfet/transistor that can handle twice(+) the load. The +5vdc is being shorted to Gnd within the unit when someone pushes the button and that's why I was only concerned about putting a transistor in place that could handle the +5vdc @ .5 Amp.
thanks again for your time and explanation
hmlittle59
