RS485 Interface board for Propeller - Updated to REV-P — Parallax Forums
DavidMDavidM Posts: 640
edited 2009-04-20 11:01 in Propeller 1
I have updated my PCB design ( and schematic) again , the Diode D2 was in the wrong place, And I have moved the transformer closer to the IC.
Any comments on my design?
Q1) If I were to connect 3 of these RS485 boards ( using the prop) with only say about 2 meters of cable between nodes 1 & 2 & 3, according to my design both end nodes ( 1 & 3) will be terminated, but I have read that short lines do not need termination, so does this mean it won't work?
Q2) Do I need the resistor R17 to be placed as i have done, as part of the DIODE regulator circuit? is it the correct value/wattage?
Q3) I have chosen a different OPTO COUPLER since the last design, will this work?
Q4) Is 1 watt for the resistors R2, R4 & R5 to large? or will 1/2 watt work just fine?
Dave M
Post Edited (DavidM) : 4/20/2009 11:04:43 AM GMT
  • dMajodMajo Posts: 862
    edited 2009-04-09 18:29
    Hi DavidM,
    · I am still busy (sorry, the revamping is taking more time that I expected) so I have given just a quick look. I assume that the schematic was not changed and that the pcb correspond to it (I haven't looked for routing errors)
    A1) "it doesn't need" it doesn't mean "it doesn't owe": it is always good to terminate properly the lines. If the lines are short, you have less reflections/distorsions and it can work even without termination (for low speeds)
    A2) No, you not need and you not owe: D2 is just for precaution (to eventually protect your AHC logic), usually it will never act (anyway it can handle the current from the transformer also without R17). With R17=10R and let's say I(Vcc2)=200mA you will loose 2V on this resistor and this is not good
    A3) PS2581AL2 is OK (R11=6K8 to 8K1; R10=560), PS2597AL2 not able to find datasheet right now
    A4) 1/2W can do the job if everything OK but for safety reasons (product life time) I suggest you 1W
    The PCB at first look seems OK. Not so easy to hand-solder because of the reduced space between some components. Take care at mounting screws: you do not want to make a short between the two grounds (at least one ground plane maybe too close to screws holes)
    regards
  • DavidMDavidM Posts: 640
    edited 2009-04-10 03:45
    Thanks dMajo,
    I have updated the schematic & the layout.
    I removed the resistor for the diode.
    I consolidated some capacitors ( the 10UF ones)
    I have updated the BOM which is now attached along with the layout & schematic.
    I have to work out how to make more space around the HOLES
    thanks
    Dave M
    HI,
    I have made some changes to the PCB Layout.
    1) I removed the bottom 2 mounting holes , these are not needed as the connectors will hold the board in place ( these connector are insulated).
    2) I moved C6 as downwards, and moved the TRANSFORMER a Little closer to the IC.
    3) The tracks for the R4/R5 have been increased.
    4) If only the EXTERNAL LED's are used ( via the 4 pin header) then , no need to mount the internal ones. So only one set of resistors is needed. The internal leds are for testing, the external ones are for mounting on a panel.
    The revision is now REV-P
    regards
    Dave M
    1917 x 1638 - 130K
