IR Beacon
I succesfully built an IR beacon using a 555 timer and following the instructions on "IR Remote for the Boe Bot" in appendix C.· I would like to increase the intensity of the beacon by adding more than one infared LED to it.· Can I accomplish this by simply connecting more IR LEDs in parallel to the circuit?· Would doing so change·the frequency setting so that I would have to recalibrate?· Please refer to my schematic.
The output from the LEDs will tend to drop the more LEDs you add because the output voltage from the 555 will drop with increased current drain. The LM555 datasheet goes into details on that. In any event, you'll have a sort of diminishing returns behavior. If you increase the supply voltage to compensate, the heat dissipation will increase and you'll have to adjust the resistor values as well.
I'd probably use no more than 4 LED/resistor sets in parallel and I'd run the whole thing off a 6V battery pack, maybe using 270 Ohm resistors for the LEDs
Jax
If a robot has a screw then it must be romoved and hacked into..
I will be using the basic stamp with the circuit to be able to obtain a frequency that can be transmitted at 38khz, following the direction on"IR Remote for the Boe Bot" in appendix C. Once I get the value of resistance of the potentiometer that gets me this value I will then not use the stamp and use a fixed resistors instead of the potentiometer and will use a 9 volt supply instead of the 5v that is regulated by the homework board. I should not have written 9v on the schematic, it should really say 5v since the power is being supplied by the homework board. I want to use 9 volts after I build the circuit seperate from the stamp using the 555 timer, a capacitor and resistors. Basically an IR beacon. My goal is to maximize the distance the beacon can be detected by increasing the number of ir emmitters.
Jax
OK Try this one, It has 7 IR LED's. Use the 9 volt power supply that your going to use and tie the grounds together to your homework board. Attach TP1 to pin 7 of your stamp and then adjust the VR to get at around 38Mhz once this is set then disconnect the grounds and your ready. Let me know how this works for you please..
Jax
Lets make the following assumptions (they should be close):
1-With a 9V battery the output from the 555 is 8.2V.
2-The IR leds have a forward drop of 2.2 volts
3-The duty cycle is 40%
6 leds in parallel
resistor ohms
220
led voltage 2.2
res voltage 8.2-2.2=6.0
current (mA) 6.0/220 x 6 = 164
power .164x9x0.4= 0.59W
2 strings of 3 leds in series
resistor ohms
56
led voltage
2.2x3=6.6
res voltage
8.2-6.6=1.6
current (mA)
1.6/56 x 2 = 57.2
power
.0572x9x0.4= 0.206W
This gives slightly brighter output with three times the battery life. You will have to measure the utput voltage of the 555 with the 9 volt battery and the forward voltage of the leds and adjust the resistor value accordingly to make sure it will works properly.
I would also suggest using the ir sensor you plan to use with the stamp to adjust the frequency.
Post Edited (kwinn) : 4/3/2009 4:53:36 AM GMT
@Kwinn If you change your resistance to 56 OHMS on the IR LED the circuit will provide 7.34 volts to each LED " Can you Say POP there goes the Magic Smoke'? also the current and power will have a spike on them as well along with using more Current and Power as well. Please see the attached screen shots for these readings I provided for both 200 OHM set up with 14 IR LEDs and the 56 OHM setup as you instructed. This is one reason I use the computer simulations because then I can design circuits and test them before building and not only tat but to see how they preform as well. Also the Power is calculated by the following P=IR and not by the 40% duty cycle.. This may be where you got confused.
Jax
Post Edited (GWJax) : 4/4/2009 4:34:45 AM GMT
Also here is the comparison running 6 IR LED's in series.. As you see the 200 Ohms has Just a little bit more Power consumption and Current consumption than a 56 OHM resistor, not only that but the Voltage it too high on them and will over heat the IR's thus giving you less usage on them including the spikes that occur with this value . See the attached images to compare.
Jax
Post Edited (GWJax) : 4/4/2009 5:04:42 AM GMT
It would be a good idea to temporarily put a higher value resistor (say 100 ohms) in series with the leds, measure the actual voltage across it, and use that to calculate the value of the permanent resistor needed to limit the current to the desired value.
OK kwinn, rebuilding this circuit again the way you instructed now shows that your design is using alot more Current and more Power with the 56 OHM resistor than the 220 OHM resistor setup. Also you forgot about what happens when you add resistors or LED in series that the voltage will drop when you go down the line even though the Power and Current remains the same. With this said the first LED in the series will be brighter and when you go down the row they will get dimmer. This is why in my first post I used a pull-up resistor bank to keep the voltage the same on all LEDs. As of the output from the 555 timer this will remain the same until the battery charge starts to drain past the threshold. Also this is another reason why I use the computer to do the math and testing because even though we know the math how it should work we are all human and make small mistakes while building electronics.
Jax
With a nine-volt supply, say, and three LEDs in series, you will get three times the light output per watt as you would with a single LED and a larger series resistor operating at the same current.
@ Phil,
OK now I have to try to prove you wrong with a photo of 9 LED in series. In theory this is correct but each LED has a tolerance in which the manufacture must make them by so finding all LEDs with the same resistance other than military specs which are at a 1% tolerance and cost alot more than what a hobbiest is willing to pay, you'll have to test alot of them to get just the right ones. I'll post a picture of the LED's in series from the same spool and we'll compare them in a little bit and if I'm wrong then I'll retract my statement.
Jax
Jax
I hope you will agree that if you connect several components such as diodes, resistors, and inductors in series and apply a voltage across them each component will have the same current flowing through it. The voltage and power will be different, but the current is the same.
I agree that individual leds will produce different intensities with the same current applied to them, but that is true for series or parallel connected leds.
Leds are diodes, so when the voltage increases to where the diode starts to conduct (forward biased) the current increases very rapidly with small increases in voltage unless there is a resistor in series to limit the current.
If you put several leds in series this is still true, but the voltage required to start them conducting will be the sum of the forward voltage drops of the leds. All of the leds will have the same current through them, so the intensity differences are strictly due to manufacturing tolerances, not to the location in the series chain.
Jax
The ir led has a forward voltage drop of 2.2V
The battery provides 9V
There is a drop of 0.8V through the 555 when the leds are on
LEDS WITH 220 OHM CURRENT LIMITING RESISTORS X 6
One led with a 220 ohm resistor will have 8.2 volts applied by the output of the 555 when it is on
The led will have 2.2V across it leaving 6.0 volts to be dropped across the resistor
Since I=V/R hat means there must be 6.0/220=27.273mA through the 555/resistor/led
If you connect 6 leds and 220 ohm resistors to the output (in parallel as drawn in the schematic) of the 555 then you have 6x27.273=163.636mA or 0.163636 Amps in total
Since this is powered by a 9V battery the total power (VxI) is 9x0.163636=1.472727W
If the duty cycle of the 555 is 40% ( on 40% of the time ) then the average power is 1.472727x0.4=0.589091Watts
3 LEDS AND 56 OHM CURRENT LIMITING RESISTOR X 2
If you connect 3 leds and a 56 ohm resistor in series and apply the 8.2 volts from the output of the 555 each of the leds will have 2.2V across it for a total of 6.6 volts across the 3 leds, leaving 1.6 volts across the 56 ohm resistor
Since I=V/R there must be 1.6/56=28.571mA through the 555/resistor/3 leds
If you connect 2 sets of 3 leds and 56 ohm resistors to the output of the 555 then you will draw 2x28.571=57.143mA or 0.057143 Amps total
Since this is powered by a 9V battery the total power is 9x0.057143=0.514286 Watts
With a duty cycle of 40% that would be an average of 0.514286x0.4=0.205714 Watts
We make the following assumptions:
The current drawn by the 555 that is not going to the output pin to drive the leds is the same for both circuits and is low enough to be ignored.
We have picked resistors that provide the same current through the leds in both circuits (220 ohms for circuit A, 58.66667 ohms for circuit
The same leds are used in both circuits
Under those conditions circuit B will draw one third of the power drawn by circuit A and both circuits will provide the same ir output.
This would be correct Kwinn,
Showing the results of both circuits on the simulator does prove this setup to work just fine and will save battery life. See attachments below.
Jax
PS. I'm glad we resolved this debate..
Proof of the old adage that a picture is worth a thousand words
Ok now I did it, I just looked at the attached files and I sent the wrong ones, LMAO resending the correct screen shot photos..
Jax
Oh you have to love this, I just uploaded the wrong ones again!!! Not only that but I forgot to save the images to my HDD.. I am really having a hard time with this, LOL Sorry Guys for that
Post Edited (GWJax) : 4/5/2009 11:48:25 PM GMT
