Step motor with load feedback - free running like a brushless motor - somewhat
Step Motor with Load Feedback
Intention
The idea of this project is to have a method to use a step motor like a brushless motor. It will run with high speed at low torque and will automaticly run with low speed and high torque. – And loose no steps.
Feedback wellcome! I am now thinking of a method to reduce the power consumption at low speeds. Use a step motor for robots?
Have fun,
Christof
Intention
Have fun,
Christof
Marty
Lunch cures all problems! have you had lunch?
The idea has also been put forward by Mariss of Geckodrive on their Yahoo group, the "unstallable stepper drive". Have a search and you should find info.
Of course it just means everything slows down until the motor has enough torque. Personally I like to use big enough motors for the job but I can see the attraction especially for none CNC applications like robotics as you mentioned.
Graham
Thank you too, Graham, for your comment.
Yes, that is a wise thing to do, install motors, that are just big enough. - I have moved in this direction too, after first lowest cost trials. Of course everything is steeply growing more expensive: Motors, drivers, voltage supply. At my lathe, I think I have motors which are big enough. - At least when it is cutting metal. When it is positioning in rapid movement, is there any "fast enough"? When I work with wood, there could be more speed too, but I think, you will see changing speeds on the surface, what you might not be happy about. (I am using an old pc with a bought program "pcnc" for it.)
As far as I have read, Mariss wants to use encoders. The method, that I have posted, does need only a resistor that you have anyway to control the current, and an opamp and some propeller pins together with some software, not even assembler. Perhaps I will use it for a single axis positioning system. I have got a mill, where I would like to have a controlled vertikal axis to bring the head into position for changing tools and shorter and longer tools.
Best regards, Christof
As far as your rapids go all this will do it reduce the speed until the motor can manage it, that can also be achieved by setting up the rapid speed/accell carefully. The only way to go faster is a different motor and generally higher voltages, or servos!
The other thing is that this needs to be integrated in to your motion controller somehow, that could be the propeller as well but if you want a smooth transition from CAD through CAM to machining that might be a lot of work.
Graham
Parallax Engineering
