Prop-CPLD
As I mentioned in another thread, I've been thinking of putting a Propeller chip on the same board as an Altera MAX II CPLD. The smallest MAX II comes in a 100 lead QFP package, and I have some of the EPM570 devices, so it makes sense to use one of those. The smaller EPM240 is pin-compatible. The EPM570 has 570 logic elements, up to 8kBits of storage, and a maximum input frequency of 304 MHz. It uses a 3.3V supply.
The proposed board would have a QFP Propeller chip with the usual stuff like a 5 MHz crystal, Prop Clip connector, EEPROM, etc. The CPLD will have a socket for a an oscillator, and a JTAG connector for programming. The I/Os will be brought out to pads, and there will be a sizeable prototyping area.
Is there any interest in such a board?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
You will also need a ByteBlaster for programming the CPLD, it's easy to make one that uses the parallel port (I have a PCB design for my version of it). USB devices are also available.
Leon
Why not, directly add a SRAM to the board ?
At least 512 Kb.
Regards.
Alberto.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
It would be feasible to program the CPLD with software running on the Propeller, and downloaded via the Prop Clip, but I won't put that on the initial version.
I've started on the schematic. I'll make it available for comments when it's finished.
Leon
It's not quite complete - I need to add some more decoupling capacitors and pads for I/Os. I'm not sure how best to arrange the connections between the Propeller and the CPLD. Does anyone have any suggestions? I thought of connecting all the Propeller I/Os to the CPLD, as well as bringing them out to pads, and bring the remaining CPLD I/Os out to pads.
Leon
Post Edited (Leon) : 9/30/2008 6:36:58 PM GMT
About the IO's I would leave free some propeller pins for used with some special devices, and some of the CPLD too.
But I would wired some I/O pins from propeller to the CPLD (Like eight for data, and some for asyncronous comunications..ie: three pins more).
Also I think a good idea could be leave one pin of the propeller wired to the gclk1 of the CPLD. (I used that for an easy, and different clk for the CPLD).
Just a question, do you have some LM317 free ?? why this ?, I found it very unstable although the 1% R's used, why not the LM2937-3.3 ??
If you do that, (for me) you're god !!
I found Altera selling the USB blaster for $150.-, Terasic, some similar for $50.-
Maybe it could be very atractive, to buy your board.
Regards.
Alberto.
I've got a Sunshine USB I/F, which is similar to the Terasic one, but costs more.
I'll actually use the LM1117, although I've never had any problems with the LM117. I think they are cheaper than the fixed ones, which is why people like Olimex use them.
I've programmed an Altera FPGA with an MCU on the same board, it wasn't too difficult.
Here are details of my JTAG I/F:
www.geocities.com/leon_heller/Blaster.zip
Leon
Post Edited (Leon) : 9/30/2008 9:59:47 PM GMT
How big this board will be.
In my sugestion try to have al Pins accesible trouth Pin headers even if them is conected to CPLD, RAM etc.
It is more reliable to tests
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Leon
In My opinion have it same as ProtoBoar.
But have al Pins On Board for compatiblity and Re configuration posiblites
Sapieha
Nico Hattink
Count me in for two as well.
We have been looking at a similar design for marrying Prop up with an FPGA but we've got far too much on at the moment for it to get off the ground.
I'd like to see at least one pin group left free of any other connection to the CPLD along the lines of what Alberto was saying.
Then if you can just bring the rest out to pin headers it would be a great board for prototyping then.
Integrated SRAM would be a bonus but not really a great iussue if you add pin headers.
Looks good so far.
Coley
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
By pin group I presume you mean pins that can be used for video?
Of course, pins can simply be routed straight through the CPLD. I considered just doing that, originally.
Leon
Post Edited (Leon) : 10/1/2008 10:41:23 AM GMT
Might not be wise to route all the prop pins straight through the CPLD, would cause problems when wanting to change rapidly from input to output.
Perhaps provide pads for connecting to all Prop and CPLD I/Os externally with PCB traces between that can be scratched out (or bridged) as required.
www.leonheller.com/Prop-CPLD/Prop-CPLD.pdf
To avoid clutter, I've incorporated net names in the PCB part for the Propeller. The PCB software I use (Pulsonix) will automatically connect them in the PCB layout editor. I'll do the same with the CPLD.
I've bought P12-P14 out to pads for video output.
I won't actually be connecting the pins between the Propeller and the CPLD, they will be bought out to pads that can be bridged, as suggested. I'll also be adding some header connectors. The prototyping area will be defined on the PCB.
Leon
Post Edited (Leon) : 10/1/2008 4:23:16 PM GMT
If only as an initial confidence test heartbeat for example. One for the Prop and one for the CPLD.
Leon
Nico Hattink
Leon
Depends on price of course but I'm leaning toward fully assembled just now.
Leon
I think some bare PCB's could be a great idea too.
Soldering the CPLD package is not difficult at all, I usually did that with a common iron solder and some flux gel. Just only need a little bit of practique.
Leon, be carrefully with the bridges to connect some propellers pins plus some CPLD pins, I can imagine you've in mind to avoid degrading signals of high frequency at the buses.
Regards.
Alberto.
if the eeprom is only 256K than I will prefer a ramtron device FM31L278 (no rewrite limits, RTC, 2 CNT, SN support). You can route VBAT out the board near VCC so they can be easely bridged together.
I have already used the backed counters for anti-tamper and security key features on other developments.
Dario
I would prefer assembled and tested but only because I have enough to do assembling my own boards
Leon
I've added two 2x8 IDC cable headers for the Propeller I/O, two LEDs and pads for I2C expansion. The LEDs are connected to pads, so they may be connected to any of the Propeller or CPLD I/Os.
Leon
