One more Software Question, Pretty Please.
OK, here is what I want to do. Right now, I am loading up the BoebotBASIC Interpreter·program from the hard drive. I am placing it in EEprom. From there, I take the terminal and l hook it up. I load "Boebot.bas" the roaming program from the SD card (2Gig).· Then I have to say "RUN". This all has to be attached to the boebot. I want to load it into the SDcard and run it by resetting it or something.·
I have been told that I expect all the answers without working for it. I truely have spent countless hours and truely have did my wheel spinning. But, it just doesn't come to me easy.··
If you don't want to share the information that you worked hours to learn, please point me in the right direction so I can look it up and find it.
I like the way Mike always says where the information is. I go back and sure enough, it was there, just invisible to me.
I have found ProDos. Is this my answer?·
I really do NOT take you all for granted.· There are other subjects that I know quite a bit about. And I have shared the information with many other people. Students,mostly. I find that when they ask me questions , it helps me to learn and grow more.· I am the one who benifited from sharing it with other people.·· I know that most of your time is very valuable , and I apreciate that.
I am a very curious person by nature. But, I will do my best to hold it back until I have exaused every avenue that I have in my understanding. I am almost to the end of my project anyway.· All I have left to do is software to program the robot to do certain things.· I thank you guys for your previous help.· I have a Deep Respect for you all.
It was neat to see where everyone came from.· You guys are scattered out all over the world. When we think about it, it is a very small world.· I would like for the whole world to live in peace and love each other.
I think personally that everyone from every country are very nice people. It is usually the governments that cause friction between nations. I believe we should be racing to cure cancer or something instead of trying to kill each other. But, that is my humble opinion.
I guess I will give up off my soapbox.
Thanks.
JMH - Electronics: Engineer - Programming: Professional
It's free and works well . He can call you for free PC to PC.
www.skype.com/
Aka: CosmicBob
Also, right now, I am waiting on a second IRemitter to come it. I have at 45 degree angles the IRDetectors. They are tied together to one Port through a 1k resistor. I have only ONE emitter and it is kinda floating on the top of the wires pending I want to connect it up to the other emitter. Since this program is already compiled , it is expecting only one IR device, so I have twin ones tied together and going to only two pins for four devices. Seems to work, except this usb cable. But, I will figure it out.
Did you read my previous message explaining this USB thing?· You really need to read this stuff.· If you don't understand it, ask "what do you mean by ...", don't just skip over it.· Take a couple of deep breaths, slow down, reread stuff until you understand it (or get help with it), take some more slow breaths, etc.
It's possible to solder a diode between the USB power line and the +5V regulator so the FTDI chip is always powered. That's one fix. If you have a spare USB cable, you can connect it (the +5V power wire) to the +5V regulated supply on the Protoboard. You don't need the diode if you use a USB cable because you can't plug in a real USB cable at the same time. There was some other fix using another wiring change around the FTDI chip, but I don't remember exactly what that was. You can call the Parallax support line, explain the situation, and see what they suggest.
Post Edited (Mike Green) : 9/9/2008 12:30:11 AM GMT
As always, Thanks!
You asked about diodes.· You answer ... What kind of diode is a 1N914?· What's a Zener diode?· What are they used for?
You can find out all sorts of things in the Wikipedia.· You can look up diodes and transistors through vendors like Jameco and DigiKey.· They have links on their web catalog pages to the datasheets for the devices.· That way you avoid wasting time with the datasheet databases that try to get you to pay to read their copies of the datasheet when you can get them for free from the manufacturer or distributor.
Post Edited (Mike Green) : 9/9/2008 12:36:47 AM GMT
I was refering to the diode above mentioned.
1N914 diodes certainly are common. Find out something about them. Sure they're used for detectors. We're talking about computers here. How are they used in computers? What other functions are they good for?
Zener diodes can be used as clamps. They can be used as regulators. How? Find out something about them. Find out how they're used (how they're connected and why ... how do the circuits work).
Computer technicians, if they're (hopefully) anything more than a replacement monkey (just substituting one PCB for another based on a repair manual) need to know something about how things work. Managing technicians is an honorable profession, but Parallax products and the type of things that go on here don't need much in the way of management.
You have a good night!
Please read the introductory material Mike wrote in his texts, and please, for God's sake, read and perform the Parallax self-learning exercises. This is a complex area of study, and they are no shortcuts.
You, and only you, must do the hard work. I do not know any other way of making this simpler - you have to do the work and research yourself.
Please don't take this as being overly critical - but you must master the basics of self-learning.
Google Skype and follow the directions. You need a degree of hand holding that does not lend itself well to a forum exchange.
I will volunteer to offer real-time telephone support, at least to get you over the lack of communication skills that you seem to exhibit.
A few months from now, you will be the old-timer answering the questions of neophytes...
Post Edited (Quantum) : 9/9/2008 2:53:22 AM GMT
