OBD11 Scanner
I was wondering is there any information on OBD11 using an SX Chip. I want to make a simple scanner to display and erase DTC on automobiles·for my students using an SX Chip.·I was wondering if someone can point me in a direction. I looked and did a search on this site and nothing came up. I see there are a lot of scanners out there but I would like to build one with the SX chip.
·Not to correct you but it's OBDII not OBD11 :-) . If you do a search using " OBDII ISO" ,you should find some good info. Here is one that I found.
http://en.wikipedia.org/wiki/On-Board_Diagnostics
Good Luck,
·Brian
Scantool.net sells PDIP8 chips that can talk to your car's MCU.· They also have free laptop software to enable you to talk to the chip and make changes to your car's MCU.
The SX chip could be used in place of a laptop and run an LCD w/ buttons for the human interface.· Could be a fun project!
www.scantools.net
- products
- parts
take a look at the OBD Interpreter ELM320 ($17.95) or similar chip.
John J. Couture
San Diego Miramar College
http://www.elmelectronics.com/
The ELM327 is worth a look also. I've used their ICs in projects before, makes life simple and they work well.
Post Edited (DynamoBen) : 8/3/2008 11:33:34 PM GMT
there was a thread sometime back about this that didn't really go anywhere. I'm looking into this too (but only for two vehicles [noparse]:)[/noparse]
Second John's suggestion of the ELM products that would make interfacing to any controller much easier. The site DynamoBen posted has a good cross ref too.
cheers
- H
Buzz Whirr Click Repeat
I picked one up a couple of years ago and was able to talk to the chip with my laptop, but I never did get around to wiring it up to my Jeep (was winter up here in Canuck-land!).
Are you planning on getting the proper connector? Let me know where you get yours!
Cheers
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Robert
http://www.obd2cables.com/products/
In regards to changing settings in the ECU, the Elm ICs are designed to do just diagnostics (clearing/reading code, reading onboard sensors).
I am reading the data sheets on and it looks like the SX48 may be able to do it all without the ELM chip...
I found some good info to start with.. They are using an AVR chip for this scanner but I think the SX may be able to do it too..
John J. Couture
