120v light dimming — Parallax Forums
120v light dimming
ProfessorwizProfessorwiz Posts: 153
edited 2008-01-03 21:10 in General Discussion
I was trying to dim a strand of Christmas lights with a triac setup similar to the sprinkler setup in this post
http://forums.parallax.com/showthread.php?p=667859
I was trying to use the PWM command, but it's not working.· Is it that the triac is not turning all the way off quick enough for that to work?
Russ
  • BeanBean Posts: 8,129
    edited 2008-01-03 17:46
    Russ,
    The PWM command won't work, because a triac stays on until the AC goes·to zero. So if the PWM output goes off on just after the zero point, the triac will still stay on until the AC reaches zero again.
    Basically the PWM needs to monitor the AC zero crossing.
    Bean.
    www.iElectronicDesigns.com
    Post Edited (Bean (Hitt Consulting)) : 1/3/2008 9:13:52 PM GMT
  • JonnyMacJonnyMac Posts: 9,766
    edited 2008-01-03 19:15
    Attached you'll find the [noparse][[/noparse]updated] code and schematic for a project I originally did for the November issue of Nuts & Volts. To Terry's point, you have to monitor the zero-cross and then turn on the triac some time after that -- the longer you wait, the more dim the light will be. The process is explained in the article.
  • ProfessorwizProfessorwiz Posts: 153
    Thanks, I will get the article. I appriciate it very much.
    Russ
