My First Schematic for the SX28
I'm learning.
I'm not so good at this, and would like to know if I've got it.
=>is the jumper for debugging OK?, or maybe it should be on the OSC1 line?, or both?
=>is the reset OK?
=>is the Power supply OK?
SXlee
=>is the reset OK?
SXlee
Can the RTCC be tide to (Vdd or Vss)?.
I usually tie the RTCC pin low. You can see this on the schematic for my SX48 carrier PCB:
http://www.robotworkshop.com/robotworkshop/projects/parallax/SX48OEMSchematic.pdf
I still have some of these boards available if you want to experiment with the SX48 chip. You can read about that board here:
http://forums.parallax.com/showthread.php?94916-SX48-40-pin-DIP-full-kit-and-PCB-available.&highlight=bs2p40
Robert
