SPIN CODE EXAMPLES FOR THE BEGINNER (Public Version) - Page 5 — Parallax Forums
123578
  • Dave ScanlanDave Scanlan Posts: 160
    edited 2006-04-25 17:52
    (This reading closely corresponds to readings from an HP 5314A.)
    Example 14
    PROPELLER FREQUENCY COUNTER: External Frequency Source
    '                                       EXAMPLE 14
    '               PROPELLER FREQUENCY COUNTER: External Frequency Source
    'IMPORTANT: This example may require an understanding of Example: 13
    'WHAT'S NEW IN THIS EXAMPLE:
    '          SPECIAL PURPOSE PROPELLER REGISTERS: CTRA, FRQA, AND PHSA.  Using these
    '          registers, an incoming frequency source is sampled for one second. The
    '          result is then displayed on a Parallax LCD.
    'DIFFICULTY LEVEL: Intermediate
    'PURPOSE: The purpose of this example is to show how to create a frequency counter
    '          using the Propeller's special purpose registers and display a frequency
    '          count in Hz on an LCD.
    'Submitted by Dave Scanlan, April 25, 2006
    'File: Example14_FreqCtrLCD_ExternalSource.spin
    'CORRECT OUTPUT: After sampling an incoming digital wave, the result will be
    '                displayed as below:
    '                                      4x20 LCD Module
    '                               │         PROPELLER        │
    '                               │     FREQUENCY COUNTER    │
    '                               │     FREQ:XXXXXXXXXXXHz   │
    CON
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
      LCD_Pin   = 0                           'The LCD is connected to pin A0.
      LCD_Baud  = 19_200                      'Baud
      LCD_Lines = 4                           'The number of lines on this LCD
      In = %0
      On = 1
      Off = 0
    VAR
     Long Frequency
    OBJ
     LCD: "debug_lcd"                          'Creates the object LCD from "debug_lcd"
    PUB Start
      Repeat
         MeasureFrequency
         DisplayFrequency
    PUB MeasureFrequency | Pin
      Pin := 5                                  'Pulses are sampled on this pin.
      DirA[noparse][[/noparse]Pin] := In
      CTRA := 0                                 'Clear settings
      CTRA := (%01010 << 26 ) | (%001 << 23) | (0 << 9) | (Pin) 'Trigger to count rising
    '                                                            edge on Pin A5
      FRQA := 1000                              'Count 1000 pulses on each trigger
      PHSA := 0                                 'Clear accumulated value
      WaitCNT( 80_000_000 + CNT )               'Wait for 1 second
      Frequency := PHSA / 1000                  'Calculate Freq based on the sampling
    '                                            duration, 1000 ms (1 second)
    PUB DisplayFrequency
    ' If LCD.Start(0,       19_200,   4        )
      If LCD.Start(LCD_Pin, LCD_Baud, LCD_Lines) 'Initialize the LCD object
        LCD.Cursor(Off)                          'Set cursor off
        LCD.Backlight(On)                        'Set backlight on
        LCD.Cls                                  'Clear the LCD screen
        LCD.Str(string("      PROPELLER"))       'Display string on LCD
        LCD.Newline
        LCD.Str(string("  FREQUENCY COUNTER"))   'Display string on LCD
        LCD.Gotoxy(2,3)                          'Gotoxy(Col,Row)
        LCD.Str(string("FREQ:"))                 'Display string on LCD
        LCD.Gotoxy(7,3)
        LCD.DecF(Frequency, 8)                   'Display Freq. as a decimal.
        LCD.Gotoxy(15,3)
        LCD.Str(string("Hz"))                    'Display string on LCD
    'ADDITIONAL INFORMATION:
    '  --  The code for sampling an incoming wave is an adaptation from
    '      Dr. Martin Hebel's original code in the object, BS2.Function.spin.
    '  --  The results of this counter agree closely with the readings from an HP 5314A
    '      frequency counter with deviations of 0 to 6 Hz at 2MHz.
    '  --  For this example, the amplitude was 3 volts. Until, the max input voltage,
    '      has been "firmly" established for the Propeller, I would proceed with
    '      caution.  Remember, this processor is a 3.3VDC device.
    '  --  For analog signals, a pre-conditioning Schmitt trigger is suggested.
    '      Resource: [url=http://en.wikipedia.org/wiki/Schmitt_trigger]http://en.wikipedia.org/wiki/Schmitt_trigger[/url]
    'FORMAT FOR: LCD.DecF(Frequency, 8)
    ' LCD.DecF(Value, Field_Width)
    '  Prints signed decimal value in fixed-width field
    FEWER COMMENTS (EASIER TO READ)
    '                      FEWER COMMENTS (EASIER TO READ)
    '                                EXAMPLE 14
    '                                      4x20 LCD Module
    '                               &#9474;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#9474;
    '                               &#9474;         PROPELLER        &#9474;
    '                               &#9474;     FREQUENCY COUNTER    &#9474;
    '                               &#9474;                          &#9474;
    '                               &#9474;     FREQ:XXXXXXXXXXXHz   &#9474;
    '                               &#9474;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#9474;
    CON
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      In = %0
      On = 1
      Off = 0
    VAR
     Long Frequency
    OBJ
     LCD: "debug_lcd"
    PUB Start
      Repeat
         MeasureFrequency
         DisplayFrequency
      Pin := 5
      CTRA := 0
      FRQA := 1000
      PHSA := 0
        LCD.Cursor(Off)
        LCD.Backlight(On)
        LCD.Cls
        LCD.Newline
        LCD.Gotoxy(2,3)
        LCD.Gotoxy(7,3)
        LCD.Gotoxy(15,3)
    Post Edited (Dave Scanlan) : 4/25/2006 6:37:57 PM GMT
  • El PaisaEl Paisa Posts: 375
    edited 2006-04-25 18:23
    Jon:
    What about a example in Assembly to run at 115200?
    edited 2006-04-25 18:45
    El Paisa said...
    Jon:
    El Paisa, it seems that the demand for assembly is rising.· How about starting a thread for it? ·This thread is for Spin code.
    Dave
    edited 2006-04-25 18:49
    As Dave points out, he started this thread to focus on Spin code -- and I have previously posted examples that use the FullDuplex.spin object which is written in assembly (by Chip) and can to buffered rx/tx over 400K.
    El Paisa said...
    Jon:
    Jon Williams
    edited 2006-04-25 18:55
    Dave:
    I am all for it.
    Two file folders one for assembly and the other for spin.
    That will be great.
    edited 2006-04-25 19:04
    El Paisa,
    I assume you will start the thread, and others will add to it.· I don't want to start it, because there are only so many hours in each day.· Go for it...·Let's try to focus on Spin in this·thread.
    Dave
    El Paisa said...
    Dave:
    I am all for it.
    That will be great.
    edited 2006-04-26 01:38
    Dave,
    ·· Once again, very nice.· Good examples!
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    edited 2006-04-26 02:09
    Chris Savage (Parallax) said...
    Dave,
    Thanks, Chris...more to come.
    edited 2006-04-26 17:15
    ·(This frequency reading is exactly the same reading using an HP 5314A)
    EXAMPLE 15
    ·····TWO-PROCESSOR FREQUENCY COUNTER: Internal Frequency Source····
    '                                       EXAMPLE 15
    '         TWO-PROCESSOR FREQUENCY COUNTER: Internal Frequency Source
    'IMPORTANT: This example may require an understanding of examples 5, 6, 13, 14.
    '  INTERNAL FREQUENCY GENERATOR: Generates digital pulses at a rate of
    '                                of 27,933Hz.  One cog (procssor) is
    '                                used for this; that is, this Cog has
    '                                no other function but to generate pulses.
    'PURPOSE: This example shows how to use two Cogs (processors). One processor
    '         generates digital pulses at a frequency of 27,933Hz and the second
    '         processor measures the pulses coming from the first processor and
    '         displays the frequency of these pulses on a Parallax serial LCD.
    '         Example 14 vs. Example 15
    '         -- Example 14 used one processor; and the frequency source was from
    '            an EXTERNAL source, such as a function generator.
    '         -- Example 15 uses two processors, and the frequency source is from
    '            an INTERNAL source; that is, from one of the two Cogs (processors).
    '         Pin connections: Besides connecting the serial LCD, you must
    '                          connect pin A6(Pulse output) to pin A5(Frequency
    '                          counter input). Also, see Example 13 for the serial
    '                          LCD connections to the Propeller.
    'Submitted by Dave Scanlan, April 26, 2006
    'File: Example15_FreqCtrLCD_InternalSource.spin
    'CORRECT OUTPUT: After sampling the digital wave coming from one of the Cogs,
    '                the result will be displayed as below:
    '                                      4x20 LCD Module
    '                               &#9474;                          &#9474;
    '                               &#9474;     FREQ:   27933Hz      &#9474;
    CON
      Out = %1
      In = %0
      On = 1
      Off = 0
      High = 1
      Low = 0
    VAR
     Long Stack1[noparse][[/noparse]30]                        'Sets up a stack space for a one Cog
     Long Stack2[noparse][[/noparse]40]                        'Sets up a stack space for a second Cog
    OBJ
     LCD: "debug_lcd"                       'Creates the object LCD. The file
    '                                        "bebug_lcd" can be found on the Parallax
    '                                         Web site under Propeller object downloads.
    '                                         [url=http://www.parallax.com/propeller/object.asp]http://www.parallax.com/propeller/object.asp[/url]
    PUB Start
      CogNew(FrequencyOut_PinA6, @Stack1)
      Cognew(MeasureFrequency_PinA5, @Stack2)
    PRI MeasureFrequency_PinA5 | Pin, Frequency
        LCD.Str(string("      PROPELLER"))       'Displays string on LCD
        LCD.Newline
        LCD.Str(string("  FREQUENCY COUNTER"))   'Displays string on LCD
        LCD.Str(string("FREQ:"))                 'Displays string on LCD
       Repeat
        Pin := 5
        DirA[noparse][[/noparse]Pin] := %0
        CTRA := 0                                'Clear CTRA settings
    '                                                              rising edge on A5
        FRQA := 1000                              'Count 1000 each trigger
        Frequency := PHSA / 1000                  'Calculate Freq based on duration,
    '                                              1000 ms (1 second)
        LCD.Gotoxy(7,3)
        LCD.DecF(Frequency, 8)                    'Displays freq in an 8 char field.
        LCD.Gotoxy(15,3)                          'Start on the next line
        LCD.Str(string("Hz"))                     'Displays string on LCD
    'Generates a frequency of 27,933Hz. This seems to be the
    ' "top" speed for Spin, not so for assembly.
    'Try other settings: WaitCNT(4_000_000 + CNT)is 10Hz; WaitCNT(400_000+ CNT) is 100Hz.
    PRI FrequencyOut_PinA6 | Pin
      Pin := 6                                   'Output pin for 27,933Hz signal.
      DirA[noparse][[/noparse]Pin] := Out
      Repeat
        OutA[noparse][[/noparse]Pin] := High
        WaitCNT(400 + CNT)
        OutA[noparse][[/noparse]Pin] := Low
        WaitCNT(400 + CNT)
    '      Dr. Martin Hebel's original code in the object BS2.Function.spin.
    '  --  The results of this example agree perfectly with the readings from an HP 5314A
    '      frequency counter at a frequency of 27,933Hz.
    'PIN CONNECTIONS:
    ' (Input)PIN  A5&#8226;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9532;
    ' (Output)PIN A6&#8226;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9532; Jumper wire from Pin A5 to Pin A6
    ' See Example 13 for LCD-to-Propeller pin connections.
    'MEMORY USAGE:
    '  Program: 324 Longs
    '  Variables: 89 Longs
    '  Stack/Free: 7,775 Longs
    '                                   EXAMPLE 15
    '                                      4x20 LCD Module
    '                               &#9474;                          &#9474;
    CON
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      Out = %1
      In = %0
      On = 1
      Off = 0
      High = 1
      Low = 0
    VAR
    OBJ
     LCD: "debug_lcd"
    PUB Start
        LCD.Cursor(Off)
        LCD.Backlight(On)
        LCD.Cls
        LCD.Newline
        LCD.Gotoxy(2,3)
       Repeat
        Pin := 5
        CTRA := 0
        FRQA := 1000
        PHSA := 0
        LCD.Gotoxy(7,3)
        LCD.Gotoxy(15,3)
      Pin := 6
      Repeat
        WaitCNT(400 + CNT)
        WaitCNT(400 + CNT)
    Post Edited (Dave Scanlan) : 4/27/2006 1:39:14 AM GMT
  • Charlie JohnsonCharlie Johnson Posts: 147
    edited 2006-04-26 18:49
    Dave,
    ·· Great stuff.· Here is a PDF with all your examples to date, in one place.
    Charlie
    PDF - Updated·16 June 2006
    Post Edited (dy8coke) : 6/16/2006 5:39:50 PM GMT
    edited 2006-04-26 19:00
    Charlie,
    Thank you, very much! It is hard to believe that there are 34 PDF pages of these examples.
    Many Propeller users will appreciate these pages.
    Thanks again,
    Dave
    Post Edited (Dave Scanlan) : 4/26/2006 7:42:32 PM GMT
    edited 2006-04-27 13:59
    dy8coke said...
    Dave,
    Charlie
    Hi Charlie,
    If it is ok with you, I would like to place access to·your PDF file on the very first part of this thread.· Also, on that first·part, I will·post a description of the·all the authors'·examples and their locations.
    Thanks again for your PDF file,
    Dave
    Post Edited (Dave Scanlan) : 4/27/2006 2:38:40 PM GMT
    edited 2006-04-27 15:18
    Dave,
    Go ahead. I will edit the PDF to include a TOC if you like, and will update it with each new example.
    Charlie
    edited 2006-04-27 15:31
    Sounds good to me.· Thanks!
    edited 2006-04-27 15:33
    I tried to separate the files and cut & paste to other program (NOTEPAD).
    The formating is completely screwed-up.
    I only get two long,long, long, long ·lines of text.
    The indentations are gone.
    I am using version 7.0 of Acrobat Reader.
    edited 2006-04-27 15:42
    Does SPIN differentiates between low caps and up caps?
    edited 2006-04-27 15:48
    El Paisa said...
    Hi El Paisa,
    ····· When you get the Propeller editor, you will be able to cut and paste with no problems.· It is
    ······always best to download the files from the examples.· That way the formatting will work
    ····· just fine in the Propeller editor when it is released.
    ······For me, the examples·display ok in notepad.· Are you downloading the files or copying
    ····· them·from the screen-shots?· It could be that the screen-shots are causing the problem.
    ······Now, off to my job that pays the bills.
    ······Dave
    Post Edited (Dave Scanlan) : 4/27/2006 5:22:11 PM GMT
    edited 2006-04-27 17:21
    Hi Paisa,
    No, Spin does not care if you use upper or lower case letters.
    Dave
    El Paisa said...
    edited 2006-04-28 13:48
    dy8coke said...
    Dave,
    Charlie
    Hi Charlie,
    The table of contents looks great.· I will be posting another example today or tomorrow.
    Thanks again,
    Dave
    edited 2006-04-29 10:29
    EXAMPLE 16
    ·ARRAYS: Using an array and displaying array values on a serial LCD
    '                                     EXAMPLE 16
    '    ARRAYS: Using an array and displaying array values on an LCD
    'IMPORTANT: This example may require an understanding of example 6
    '   Array
    '     - How to declare an array: ArrayName[noparse][[/noparse]NumberOfElements]
    '     - Example: Array[noparse][[/noparse]10] has 10 elements:  Array[noparse][[/noparse]0] thru Array[noparse][[/noparse]9]
    'DIFFICULTY LEVEL: Easy
    'PURPOSE: The purpose of this example is to show how to declare an array,
    '         place values into an array, access values from an array, and
    '         display these value on an LCD.
    'Submitted by Dave Scanlan,  April 29, 2006
    'File: Example16_ArrayLCD.spin
    'CORRECT OUTPUT: The LCD will display the result below:
    '                                     4x20 LCD Module
    '                             &#9474;  ARRAY VALUES:           &#9474;
    '                             &#9474;  0123456789              &#9474;
    '                             &#9474;  LARGEST VALUE:9         &#9474;
    '                             &#9474;                          &#9474;
    CON
      On = 1
      Off = 0
    VAR
      Byte Array[noparse][[/noparse]10]                        'All 10 elements are global
      Byte Largest                          'Largest is global
    OBJ
      LCD: "Debug_LCD"                      'Create the LCD object
    '                                        Be sure this program can find Debug_LCD.spin
    PUB Start
      FillArray
      FindLargestValue
      DisplayValuesOnLCD
    PRI FillArray | I, J                    ' "I" and "J" are local variables
      J := 0
      Repeat  I From 0 To 9                 'Fill array positions from 0 thru 9
        Array[noparse][[/noparse]I] := J
        J := J + 1
    PRI FindLargestValue | I                ' "I" is a local variable
      Largest := Array[noparse][[/noparse]0]                   'Start the compares with the first element
      Repeat I From 1 to 9                  'Find the largest value in an array
        If Array[noparse][[/noparse]I] > Largest
          Largest := Array[noparse][[/noparse]I]
    PRI DisplayValuesOnLCD | I
      If LCD.Start(LCD_Pin, LCD_Baud, LCD_Lines) 'Initialize LCD
        LCD.Cursor(Off)
        LCD.Backlight(On)
        LCD.Cls
        LCD.Str(string("ARRAY VALUES:"))    'Display string on LCD
        LCD.NewLine
          LCD.DecF(Array[noparse][[/noparse]I],1)              'Display all array values
    '                                        (Array[noparse][[/noparse]I],1): The "1" is the field width.
        LCD.NewLine
        LCD.Str(string("LARGEST VALUE:"))
        LCD.Gotoxy(14,2)                    'LCD.Gotoxy(Col,Row)
        LCD.DecF(Largest,1)                 'Display the Largest value
    '                                        (Largest,1): The "1" is the field width.
    '  --  With some languages, a declaration of Array[noparse][[/noparse]10] produces 11 locations:
    '      Array[noparse][[/noparse]0],[noparse][[/noparse]1],[noparse][[/noparse]2],[noparse][[/noparse]3],[noparse][[/noparse]4],[noparse][[/noparse]5],[noparse][[/noparse]6],[noparse][[/noparse]7],[noparse][[/noparse]8],9],[noparse][[/noparse]10]
    '  --  With Spin, a declaration of Array[noparse][[/noparse]10] produces exactly 10 locations:
    '      A[noparse][[/noparse]0],A[noparse][[/noparse]1],A[noparse][[/noparse]2],A[noparse][[/noparse]3],A[noparse][[/noparse]4],A[noparse][[/noparse]5],A[noparse][[/noparse]6],A7],A[noparse][[/noparse]8],A[noparse][[/noparse]9].
    '  --  MEMORY USAGE
    '        Program: 308 Longs
    '        Variables: 22 Longs
    '        Stack/Free: 7,858 Longs
    '                                     EXAMPLE 16
    '       ARRAYS: Using an array and displaying array values on a serial LCD
    'CORRECT OUTPUT: The LCD will display the results below:
    '                                       4x20 LCD Module
    '                               &#9474;                          &#9474;
    CON
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      On = 1
      Off = 0
    VAR
      Byte Largest
    OBJ
      LCD: "Debug_LCD"
    PUB Start
      FillArray
      FindLargestValue
      DisplayValuesOnLCD
      J := 0
        J := J + 1
        LCD.Cursor(Off)
        LCD.Backlight(On)
        LCD.Cls
        LCD.NewLine
        LCD.NewLine
        LCD.Gotoxy(14,2)
        LCD.DecF(Largest,1)
    '  --  MEMORY USAGE
    Post Edited (Dave Scanlan) : 4/29/2006 11:21:27 AM GMT
    edited 2006-04-29 16:31
    dy8coke said...
    Dave,
    Charlie
    Hi Charlie,
    I placed your TOC document-file on the very first part of page 1.· I tried to copy the document into that page, but the formatting would not hold.· Thus, it is there in the form of a PDF attachment.
    Today I added another example: Example 16.· It is about array processing.
    Thanks again,
    Dave
    Post Edited (Dave Scanlan) : 4/29/2006 4:34:12 PM GMT
  • John AbshierJohn Abshier Posts: 1,116
    edited 2006-04-29 22:39
    In Example 16, in the FillArray procdure why not use Array[noparse][[/noparse]I] = I instead of using another variable J?
    edited 2006-04-30 21:17
    Hi John,
    Initially I was going to put values in the array in reverse order (9 to 0) from "I" because I was planning to sort them back into order (0 to·9).··Then, I changed my mind, and did a simple·search for the highest value in the array.· Yes, you are correct; I could have·used just·"I" for·the index and the array value.
    Dave
    John Abshier said...
    Post Edited (Dave Scanlan) : 4/30/2006 9:50:31 PM GMT
    edited 2006-05-02 03:13
    dy8coke said...
    Dave,
    Charlie
    PDF - Updated 1 May 2006
    Hi Charlie,
    I have placed your latest Spin Code PDF file of all examples at the very first part of page 1 on this thread.
    The latest version has contributions from all authors: Tracy, Jon, Beau, and Dave.
    NOW THAT OTHERS HAVE THE PROPELLER DOCUMENTATION AND THE CHIP, I HOPE THESE USERS WILL POST HERE ALSO.
    edited 2006-05-03 17:49
    EXAMPLE 17
    ····ONE WAY TO PASS A VALUE FROM ONE COG TO ANOTHER COG
    ··AND INSUFFICIENT STACK SPACE
    '                                     EXAMPLE 17
    '                    ONE WAY TO PASS A VALUE FROM ONE COG TO ANOTHER COG
    '                              AND INSUFFICIENT STACK SPACE
    'IMPORTANT: This example may require an understanding of examples 6 and 14
    '   PASS A VALUE BETWEEN COGS
    '     - In this example, the value of the variable X is passed from one Cog
    '       to another Cog.
    '   THE IMPORTANCE OF SUFFICIENT STACK SPACE FOR A COG.
    '     - Without sufficient stack space for a Cog, the Cog will not function
    '       correctly.
    'PURPOSE: The purpose of this example is to illustrate a procedure for passing
    '         a value from one Cog to another Cog.  In this example the value of
    '         variable X is passed from Cog0 to Cog1. These two Cogs will
    '         communicate by sharing access to a common location in memory.
    '         The location is X and it is a global variable.
    '         In the code below you will reduce the stack space of a Cog by
    '         10 longs and observe the results: The program will not run correctly.
    'Submitted by Dave Scanlan,  May 3, 2006
    'File: Example17_PassDataBetweenCogs.spin
    '                                     4x20 LCD Module
    '                             &#9474; PASS X BETWEEN GOGS:     &#9474;
    '                             &#9474; X = 10                   &#9474;
    '                             &#9474;                          &#9474;
    '                             &#9474;                          &#9474;
    CON
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      Off = 0
      On = 1
    VAR
       Long Stack0[noparse][[/noparse]20]
    '  Long Stack1[noparse][[/noparse]20]                               If you use only 20 longs the
    '                                                program will not run correctly.
    '                                                CLEAR THE LCD, THEN TRY
    '                                                Stack1[noparse][[/noparse]20].
       Long X                                        'Location to be shared between
    '                                                 two cogs.
    OBJ
      LCD: "Debug_LCD"
    PUB Start
      CogNew(SendsValue, @Stack0)
      CogNew(RecievesValueAndDisplaysIt, @Stack1)
    PRI SendsValue                                   'Passes a value
      X := 10
    PRI RecievesValueAndDisplaysIt                   'Recieves a value and displays
    '                                                 it on an LCD panel.
        LCD.Cursor(Off)
        LCD.Backlight(On)
        LCD.Cls
        LCD.Str(string("PASS X BETWEEN COGS:"))
        LCD.Gotoxy(0,1)                         'LCD.Gotoxy(FirstCol,SecondRow)
        LCD.Str(string("X ="))
        LCD.Gotoxy(4,1)                         'LCD.Gotoxy(FifthCol,SecondRow)
        LCD.DecF(X,2)                           'Displays value: X
    '  -- Note that the locations on an LCD start with 0; that is, HOME is 0,0.
    '  -- Several months ago, when I was beta testing the Propeller, I had trouble
    '     getting the Cogs to communicate with each other. After some "wasted"
    '     time I realized that I did not have enough stack space for one of my
    '     cogs.  I hope this example will allow you to "skip" this error.
    'MEMORY USAGE:
    '  Program: 295 Longs
    '  Variables: 70 Longs
    '  Stack/Free: 7,823 Longs
    Post Edited (Dave Scanlan) : 5/3/2006 5:55:32 PM GMT
    edited 2006-05-05 13:10
    A quick observation that might help anyone new to the Propeller, this includes me!
    Was playing with Beau's IR-Decoder code and could not get it to work. This is what helped me:
    1. Unpacked the *.zip to a temp directory
    2. Made a directory and copied over the two custom files (IR_Test.spin and IR_JVC_RMV715U.spin to a folder in my:
    ·· C:\Program Files\Parallax Inc\Propeller Tool v0.95\Examples directory.
    3. Connected IR hardware to Propeller board
    4. Ran F10 (Load RAM + RUN)
    5. Received an error of: "Expected "(" and the editor highlighted the term.start line. Changed this to term.start(3) I'm assuming that the libraries were recently updated as of V.095 Propeller Tool and the TV.SPIN now requires that you set the MODE.
    6. Ran F10 again and it works flawlessly.
  • Beau SchwabeBeau Schwabe Posts: 6,548
    edited 2006-05-05 15:06
    Mike,
    What you mention is an excellent point about the archiving encapsulation option.
    The object "tv_terminal" has changed slightly since I wrote the IR demo program,
    but because I saved it as an archive, ALL of the necessary files are
    there. What you need to do, is "unzip" the archive with all of the files in a specific
    directory of your choice. When you run the Propeller Tool, go to that directory and
    run the "top" file. The "top" file can be determined by looking at the "_README_" file
    within the archive.
    The program you mention was just an example, that ONLY works if you have a JVC_RMV715U remote.
    If you have another remote, you will need to have an object specifically for that remote.
    I would however be interested if "other" JVC or SONY remotes would work with this object.
    http://forums.parallax.com/showthread.php?p=577755
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/5/2006 3:11:31 PM GMT
    edited 2006-05-05 15:46
    Beau,
    I tried that, unzipping to a directory and then setting the Top File, but I must have done something wrong because I could get it to display until I did the procedure as described in my post. I'll go back and try again tonight when I get home. It's quite possible that I may have skipped a step.
    As for remotes, I used a JVC remote from an old VCR that I no longer have. I did have to go reassign some of the DAT statements to each key that I was decoding, but other than that, worked like a champ! I suspect that you could use a universal remote and just pick a JVC item. Now I need to figure out how to do an overlay using a LM1881 chip!
    Good job on you IR Decode program!
    edited 2006-05-05 16:04
    Thanks Mike!
    The only other thing I can think of... Check what the 'pins' under the 'tvparams' has for it's value between the 'tv_terminal' objects.
    My board might be different than the released version of the Demo Board.
    When you hit F8, everything compiles correctly right? ...you just don't see anything unless you use the "newer" 'tv_terminal' object. Right?
    Cool about the remotes!
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 5/5/2006 4:07:02 PM GMT
    edited 2006-05-06 15:17
    EXAMPLE 18
    ··············· MENU-DRIVEN, SHIFT-RIGHT AND SHIFT-LEFT DEMO:
    ··································· USES PS/2 KEYBOARD AND LCD PANEL
    '                                    EXAMPLE 18
    '                  MENU-DRIVEN, SHIFT-RIGHT AND SHIFT-LEFT DEMO:
    '                        USES PS/2 KEYBOARD AND LCD PANEL
    'IMPORTANT: This example may require an understanding of examples 8 and 14
    '   LCD MENUS
    '     - In this example, an LCD will be used to display two menus.
    '   KEYBOARD USED TO SELECT MENU CHOICES
    '     - Using the keyboard, the user will be able to select menu choices.
    '   SHIFT LEFT AND SHIFT RIGHT
    '     - The bits in the variable X will be shifted left or right.
    '     - X is only 8 bits to keep things simple.
    '     - The shifting process will be displayed on the LCD in real time.
    '   REPEAT-UNTIL and CASE
    '     - Menu input is often constucted from these two control structures.
    'DIFFICULTY LEVEL: Easy-to-intermediate for a beginner.
    'PURPOSE: The purpose of this example is to illustrate:
    '          1.  How to set up menus in Spin on an LCD.
    '          2.  How to use the keyboard to make menu choices.
    '          3.  How to shift bits in a variable while watching the process
    '              in real time. The user can select how many bits to shift.
    'Submitted by Dave Scanlan,  May 6, 2006
    'File: Example18_ShiftLeftRight.spin
    'CORRECT OUTPUT: The LCD will display the Menus below:
    '                                  4x20 LCD Module
    '                           &#9474;      BIT SHIFT DEMO      &#9474;
    '                           &#9474; R - Shift Right          &#9474;
    '                           &#9474; L - Shift Left           &#9474;
    '                           &#9474;>R<                       &#9474;
    '                                 4x20 LCD Module
    '                           &#9474;HOW MANY BITS? >7<        &#9474;
    '                           &#9474; BINARY X: 00000001       &#9474;
    '                           &#9474; DECIMAL X: 1             &#9474;
    '                           &#9474;Restart: Esc Key          &#9474;
    CON
    'KEYBOARD SETUP
      PS2ToProperllerPins_Setup = 6  'See number (1) at the bottom.
      KeyLocks_Setup = %0_000_010    'CapsLock ON: See number (2) at the bottom.
    ' KeyLocks_Setup = %0_000_000    'CapsLock OFF: See number (2) at the bottom.
      AutoRepeat_Setup = %01_01000   'See number (3) at the bottom.
    'LCD SETUP
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      Off = 0
      On = 1
      R = 82
      L = 76
    VAR
     Byte X
     Byte NumOfBits                  'Number of bits to shift
     Byte ASCII_Key                  'Holds ASCII value from Keyboard
     Byte Right
     Byte Left
    OBJ
      KB : "Keyboard_iso"             'Creates Keyboard (KB) object
      LCD: "Debug_LCD"                'Creates LCD object
    PUB Start
      Initialize_KeyBoardAndLCD
      Display_ShiftRightOrLeftMenu
      Input_RightOrLeftChoice
      Repeat
        Display_NumOfBitsToShiftMenu
        Input_NumOfBitsToShift
        ShiftBitsInVariableX
    'INITIALIZES KEYBOARD AND LCD
    PRI Initialize_KeyBoardAndLCD
      KB.Startx(PS2ToProperllerPins_Setup, KeyLocks_Setup, AutoRepeat_Setup)
      WaitCnt(50_000_000 + Cnt)     'YOU MUST HAVE THIS DELAY TO INITIALIZE KB
    ' LCD.Start(0,       19_200,   4        )
    'DISPLAYS MENU FOR LEFT OR RIGHT SHIFT CHOICE
    PRI Display_ShiftRightOrLeftMenu
      LCD.Cursor(On)
      LCD.Backlight(On)
      LCD.Cls
      LCD.Str(string("   BIT SHIFT DEMO"))
      LCD.Gotoxy(1,1)
      LCD.Str(string("R - Shift Right"))
      LCD.Gotoxy(1,2)
      LCD.Str(string("L - Shift Left"))
      LCD.Gotoxy(0,3)
      LCD.Str(string("> <"))
    'INPUTS MENU DATA: (RIGHT OR LEFT SHIFT CHOICE)
    PRI Input_RightOrLeftChoice
      REPEAT
        LCD.Gotoxy(1,3)             'LCD.Gotoxy(Col,Row)
        ASCII_Key := KB.GetKey
        Case ASCII_Key
          "R" : LCD.Str(string("R"))
                Right := True
                Left := False
          "L" : LCD.Str(string("L"))
                Left := True
                Right := False
      UNTIL ASCII_Key == R OR ASCII_Key == L
      WaitCNT(10_000_000 + CNT)
    'DISPLAYS MENU FOR CHOOSING NUMBER OF SHIFT BITS
    PRI Display_NumOfBitsToShiftMenu
      WaitCNT(80_000_000 + CNT)     'Delay while user reads display
      LCD.Cls
      LCD.Str(String("HOW MANY BITS? > <"))
      LCD.Gotoxy(1,1)
      LCD.Str(String("BINARY X:"))
      LCD.Gotoxy(1,2)
      LCD.Str(String("DECIMAL X:"))
      LCD.Gotoxy(0,3)
      LCD.Str(String("Restart: Esc Key"))
    'INPUT MENU DATA: (NUMBER OF SHIFT BITS)
    PRI Input_NumOfBitsToShift
      LCD.Gotoxy(16,0)
      If ASCII_Key == $CB           'Looks for Esc Key ($CB)
          Start                     'Restarts program
      Case ASCII_Key
         "0" : LCD.Str(string("0"))
               NumOfBits := 0
         "1" : LCD.Str(string("1"))
               NumOfBits := 1
         "2" : LCD.Str(string("2"))
               NumOfBits := 2
         "3" : LCD.Str(string("3"))
               NumOfBits := 3
         "4" : LCD.Str(string("4"))
               NumOfBits := 4
         "5" : LCD.Str(string("5"))
               NumOfBits := 5
         "6" : LCD.Str(string("6"))
               NumOfBits := 6
         "7" : LCD.Str(string("7"))
               NumOfBits := 7
         "8" : LCD.Str(string("8"))
               NumOfBits := 8
        Other: Input_NumOfBitsToShift
    'DISPLAYS SHIFTING BITS AND CHANGING DECIMAL VALUE
    PRI ShiftBitsInVariableX
      X := %1111_1111
      LCD.Gotoxy(11,1)
      LCD.Bin(X,8)
      LCD.Gotoxy(12,2)
      LCD.DecF(X,3)
      LCD.ClrLn(3)
      WaitCNT(80_000_000 + CNT)    '1 second delay while user reads display
      Repeat NumOfBits
        If Right
          X := X >> 1              'Shift bits in X to the right.
        If Left
          X := X << 1              'Shift bits in X to the left.
        LCD.Gotoxy(11,1)
        LCD.Bin(X,8)
        LCD.Gotoxy(12,2)
        LCD.DecF(X,3)              'Decimal with a fixed field of size 3.
    '  --  This example will help a beginning programmer visualize what happens
    '      when bits are shifted.
    '  --  You will need a PS/2 keyboard and a serial LCD (4x20)
    '  --  The code was written to make the application easy to understand.
    'KEYBOARD SETTINGS EXPLAINED (SEE CONSTANT SECTION ABOVE.)
    '(1) 6 is a setup code that will properly match the pins on a PS/2 male
    '    conector with a PS/2 female connector that is connected to the
    '    the Propeller.  See Keyboard_iso.spin for more pin setup codes.
    '(2) %0_000_010 is a setup code that will set CapsLock ON (bit 1). See
    '    Keyboard_iso for more KeyLock setup settings, such as NumLock and
    '    ScrollLock.
    '(3) %01_01000 is a setup code that will produce a .5sec (bit 5) delay before
    '    auto repeat starts and a 15cps repeat rate (bit 3). See Keyboard_iso
    '    for more setup settings.
    'MEMORY USAGE:
    '  Program: 798 Longs
    '  Variables: 42 Longs
    '  Stack/Free: 7,348 Longs
    '                               EXAMPLE 18
    'DIFFICULTY LEVEL: Easy to intermediate for a beginner.
    '                                  4x20 LCD Module
    '                                 4x20 LCD Module
    CON
    'KEYBOARD SETUP
    'LCD SETUP
      LCD_Pin   = 0
      LCD_Baud  = 19_200
      LCD_Lines = 4
      Off = 0
      On = 1
      R = 82
      L = 76
    VAR
     Byte X
     Byte NumOfBits
     Byte ASCII_Key                  '
     Byte Right
     Byte Left
    OBJ
      KB : "Keyboard_iso"
      LCD: "Debug_LCD"
    PUB Start
      Repeat
      LCD.Cursor(On)
      LCD.Backlight(On)
      LCD.Cls
      LCD.Gotoxy(1,1)
      LCD.Gotoxy(1,2)
      LCD.Gotoxy(0,3)
      REPEAT
        LCD.Gotoxy(1,3)
        Case ASCII_Key
                Right := True
                Left := False
                Left := True
                Right := False
      LCD.Cls
      LCD.Gotoxy(1,1)
      LCD.Gotoxy(1,2)
      LCD.Gotoxy(0,3)
      LCD.Gotoxy(16,0)
      Case ASCII_Key
               NumOfBits := 0
               NumOfBits := 1
               NumOfBits := 2
               NumOfBits := 3
               NumOfBits := 4
               NumOfBits := 5
               NumOfBits := 6
               NumOfBits := 7
               NumOfBits := 8
      X := %1111_1111
      LCD.Gotoxy(11,1)
      LCD.Bin(X,8)
      LCD.Gotoxy(12,2)
      LCD.DecF(X,3)
      LCD.ClrLn(3)
      Repeat NumOfBits
        If Right
        If Left
        LCD.Gotoxy(11,1)
        LCD.Bin(X,8)
        LCD.Gotoxy(12,2)
        LCD.DecF(X,3)
    'MEMORY USAGE:
    Post Edited (Dave Scanlan) : 5/6/2006 7:07:03 PM GMT
