P2EVAL Rev 3 acrylic enclosure
W9GFOW9GFO Posts: 4,002
edited 2020-07-18 - 06:22:56 in Propeller 2
P2 Eval Rev C enclosures now ready to order. Slight redesign to account for the DIP switch being in a slightly different location and cutouts changed so that there is no interference with accessory boards.
www.etsy.com/P2 Eval Rev C
www.etsy.com/P2 Eval Rev C (Top piece only)
  • These are really sharp! I love mine and will definitely need another.
    Request: Ilthis is a small thing, but the radius on the inside corners of the connector cutbacks interferes with the accessory boards. Any chance of changing this radius? If you need a picture I can post one for you.
  • JRoark wrote: »
    ...the radius on the inside corners of the connector cutbacks interferes with the accessory boards. Any chance of changing this radius?
    A known issue. It is my understanding that a few swipes of a nail file will take off the corner of the accessory board so that it can fit without interference.
    The alternative is to alter the design making the cutouts deeper and/or sharper. The radius is already as small as I can make it while still being able to chamfer the edges - making it a sharper corner would mean that the continuous chamfer around the top piece would not be possible. Deepening the cutouts would require the "neck" to be even narrower - that would be a problem at the lower left where it is already quite narrow due to the reset button.
    I would like to see a picture though, it would be useful to compare it against the CAD model to see what the real clearances are.
  • Not the best picture, but maybe you can get a better idea. If you’d like, I can loan you a board for sizing. But as you say, that nail file trick works nicely.
  • PublisonPublison Posts: 11,679
    edited 2020-07-05 - 15:19:23
    I'm with Rich. The nail file treatment only takes a minute. Much easier than Rich trying to tweak the corner. I did 8 boards in less than ten minutes, plus if you had applied this to the lastest case, they are already done!
  • W9GFOW9GFO Posts: 4,002
    edited 2020-07-05 - 21:25:50
    Here is what the clearance looks like in CAD, it is pretty close to what your picture shows. I think I will remain stubborn on this one. Perhaps in future runs Parallax could chamfer those corners? If not, a nail file can resolve the issue quite easily.
    492 x 800 - 97K
  • Yea, file on the board faster than triangle file on the plastic.
  • Works for me. Have nail file and had been using it as needed. (I had to search for a board that wasnt filed yet for that picture). But I figured you might want to know before you did a new run.
    That enclosure fits together so snugly its amazing. I wasnt sure you could actually get those kind of tolerances with hobby-level CNC. When I got mine I tried to test-assemble it with the protective paper on. Nope! Just amazing...
  • JRoark wrote: »
    Thanks, it is difficult to find the ideal size to make the holes because there are always variances in the thickness of sheets of acrylic*, more so in different colors even though they are all nominally the same. I had to slightly enlarge the holes when I found that a certain color of side piece was thicker than all the rest and was causing some problems with assembly.
    I am not sure that my machine qualifies as "hobby level". It is bigger and more powerful than either of the machines that I saw at Parallax. Having said that, even the cheapest eBay laser can produce the same quality of parts as long as the operator is competent. It won't be as fast and won't last as long, but for a hobbyist it would work fine.
    *I always use cast acrylic, extruded acrylic is more consistent in thickness but is much more brittle. Cast is much more durable and it engraves nicely. Extruded acrylic is what you will find at a home improvement store, you have to get cast acrylic from a supplier.
  • Still going to do Etsy?
  • Publison wrote: »
    That is the plan.
  • When can I order?
  • pilot0315 wrote: »
    When can I order?
    Hopefully by the end of this week, I am waiting on parts...
  • Great please let me know.
    edited 2020-07-11 - 06:40:46
    Okay, due to popular demand and a little arm twisting by someone that shall not be named, I have reversed my stubbornness and made some changes to allow the accessory boards to fit (I think) with no modifications.
    I should be able to post a link to where they may be ordered by tomorrow evening.
    800 x 800 - 455K
    600 x 600 - 614K
    600 x 600 - 615K
  • Animated gifs on forums obviously became banned when jump scares and bright flashing were being abused.
  • Rich
    It is difficult to see what your fix is from the photos. I know it would mess up your beautiful chamfer, but couldn't you just cut a corner into the chamfer? I don't think it would look too bad. Just my opinion :)
  • JRoarkJRoark Posts: 548
    edited 2020-07-11 - 23:23:11
    Would that someone “who shall not be named” sorta look a bit like me when I pass a mirror? (Tall, dark, handsome, svelte, sort of a cross between Tom Sellack and... well... ok... Marty Feldman, with emphasis on Marty)
    Asking for a friend. :)
    EDIT: Take my money, please!
  • JRoark wrote: »
    No, it definitely was not you, but the description is at least partially accurate.
  • idbruce wrote: »
    Rich
    It is difficult to see the differences, that's why I wanted to post an animated gif. The chamfer remains. You can carefully compare the two images and see that the corners of the accessory boards now have clearance.
  • Sorry Rich
    Being unfamiliar with the board and your nice acrylic work, I was looking at the wrong location.
    I see the fix now . :)
  • I have updated the original post with links to where they can be ordered.
  • Wow... How fast did this happen?
    Thank you, W9GFO!
    dgately
    1331 x 1774 - 456K
  • My enclosure arrived a couple of days ago. Thanks
  • That is some darned-Skippy good work there, Rich. I just ordered my second one.
  • And.... mine arrived yesterday! The fit and finish is really excellent, as is the documentation.
  • I have an odd request. Is it still possible to order the Rev A case? I moved my Rev A case to my Rev B board and so now the Rev A board is without a case. Can I get a Rev A case along with my Rev C case?
  • JonnyMacJonnyMac Posts: 6,950
    edited 2020-07-28 - 19:19:00
    [deleted]
    edited 2020-07-29 - 00:47:58
    David Betz wrote: »
    Hi David, the Rev B and the Rev A have significantly different top pieces, I wouldn't think that the Rev A case would work well with the Rev B board. If you just need a new top piece you could order a Rev C top piece (link in first post) and leave a note that you need it to be for the Rev A (or Rev B.) Eval board.
  • W9GFO wrote: »
    David Betz wrote: »
    What I would need is two cases, one with a Rev A top piece and the other with a Rev C top piece. When I got my Rev B board I bought a new top plate from you to convert my Rev A case to a Rev B case. Unfortunately, I broke the old Rev A top plate when I removed it so I can't use it again.
  • David Betz wrote: »
    No problem, I already have a Rev A top piece cut.
