HC-SR04 Ultrasonic Sensor
AdolfoAdolfo Posts: 2
edited 2020-01-29 - 16:45:30 in BASIC Stamp
I have tried different codes to operate the HC-SR04 sensor and it only reads zeros, the board I am occupying is BASIC Stamp HomeWork Board USB and the codes that I have used are the following:
Code 1:
' {$STAMP BS2}
' {$PBASIC 2.5}
time VAR Word
main:
DO
LOW 9
PULSOUT 9, 20
PULSIN 8, 1, time
time = time ** 2251
DEBUG CR, "Distance = ", DEC4 time, " cm"
PAUSE 5
LOOP
Code 2:
' {$STAMP BS2}
' {$PBASIC 2.5}
time VAR Word
main:
DO
PULSOUT 1, 100
PULSIN 1, 1, time
time = time ** 2251
PAUSE 5
LOOP
Code 3:
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
HIGH 1 ' start output "pulse" on P1
PULSIN 1, 1, W0 ' make P1 an input and measure return echo
W0=W0/72 ' convert to inches
DEBUG DEC W0,CR ' display data
PAUSE 50 ' delay stops ringing, reduces zeroes
LOOP
Code 4:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin connections
EchoPin CON 0 ' The pin that the terminal "echo" is connected to. Pin 0 is default.
TrigPin CON 1 ' The pin that the terminal "trig" is connected to. Pin 1 is default.
' Connect "GND" to ground / VSS
' Connect "VCC" or "5+" to positive / VCC
' Don't edit below.
InConstant CON 890
inDistance VAR Word
time VAR Word
' The code below gets measurements.
beginning: ' Simply used for "GOTO beginning"
DO ' Start of the loop.
PULSOUT TrigPin, 5 ' Send a 0.005 second pulse to Ping.
PULSIN EchoPin, 1, time ' Listens for the echo.
' Coversion (Time to inches)
inDistance = inConstant ** time ' Convert time into inches. [inches = inConstant x time]
' If statement.
IF ((inDistance = 0)) THEN DEBUG CR, "Not connected properly!": GOTO beginning: ENDIF ' If the distance is "0" then something isn't connected. And goto the beginning to remeasure.
' Display management
DEBUG CR, DEC inDistance, "in" ' Display result in the debug terminal.
PAUSE 200 ' A 0.2 second delay until next measurement.
LOOP ' Start over.
I have used the two Echo and Trig pins separately, and also joining them with a resistance of approximately 1.8K. And I would like to know if anyone has a solution for this.
Thank you.
  • PublisonPublison Posts: 11,737
    edited 2020-01-29 - 17:06:29
    Welcome to the forum!
    Give the code in this thread a try. I do not own a HC-SR04 to try
    https://forums.parallax.com/discussion/163555/ps2-hc-sr04-ultrasonic-sensor-code
    You could also find this under the search funtions, (upper right of the page):
    https://forums.parallax.com/search?Search=HC-SR04
  • Thank you very much for answering, but this code is the same as I had already tried, code 4
  • I have tried different codes to operate the HC-SR04 sensor and it only reads zeros, the board I am occupying is BASIC Stamp HomeWork Board USB and the codes that I have used are the following:
    Code 1:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    time VAR Word
    main:
    DO
    LOW 9
    PULSOUT 9, 20
    PULSIN 8, 1, time
    time = time ** 2251
    PAUSE 5
    LOOP
    Code 2:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    time VAR Word
    main:
    DO
    PULSOUT 1, 100
    PULSIN 1, 1, time
    time = time ** 2251
    PAUSE 5
    LOOP
    Code 3:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    DO
    LOOP
    Code 4:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' Pin connections
    ' Don't edit below.
    InConstant CON 890
    inDistance VAR Word
    time VAR Word
    ' If statement.
    LOOP ' Start over.
    Thank you.
  • Have you successfully used your HC-SR04 with any microcontroller?
    Do you own more than one HC-SR04?
    IIRC about 20% of the cheap HC-SR04 are dead on arrival.
    I'm pretty sure I have a couple HC-SR04 sensors and a Basic Stamp board. I'll try to test this out today. (If no one else beats me to it.)
  • Duane DegnDuane Degn Posts: 10,300
    edited 2020-02-13 - 22:28:58
    Sorry but I haven't found my Basic Stamp board yet. I have found a few HC-SR04 sensors.
    I'll keep looking.
    Edit: I found it! Time to install Basic Stamp editor on this computer.
  • Isn't there a problem with using "PulseOut" and "Pause" with the HC-SR04?
    According to the data sheet pulseout isn't necessary because the HC-SR04
    generates it's own signal after the trigger pin is held high for a min of 10us,
    and pause is only capable of using 1ms increments.
    Bill M.
  • I just tried code 4 from above and it works with my hardware.
