Hey all,
This forum has lots of ideas and I need some help, please. We've got a lot of excess inventory at Parallax - it accumulates every time we obsolete a product.
Situation
We have about 1,200 Sharp short-range reflective photointerrupters (GP2A25J0000F) and 3-pin cables that accompany. These were used as our ActivityBot encoders before we got the Feedback 360 servo. I'd like to put these in a bag as sets of four, maybe with 10K (or 20K) resistors, the cables, maybe some jumpers and try to liquidate them. Probably have about $5-6K worth of parts.
A quick grab of data from Karlson Robotics:
Description: GP2A25J0000F Series are OPIC output, reflective photointerrupters with emitter and detector facing the same direction in a molding that provides non-contact sensing. This family of devices uses light modulation to reduce the affects of disturbing light, and the sensor is optimized to work in the selected focal distance. A 3-pin connector is included to allow remote-mount or off-board designs.
Features
Reflective with OPIC Light Modulated Output
Highlights :
Includes additional screw fi xing holes
Position pin to prevent mis-alignment
Short focal distance
Key Parameters:
Detecting distance : 1 to 9mm (White paper) 3 to 7mm (Black paper)
Undetecting distance : over 27mm (White paper)
What kind of super simple project could be done?
If we had a four-pack of these available for sale on-line for $10, what kind of very simple project could be made with them? I could imagine them being lined up for a 4-bit piano if there was a speaker, or used as an edge detector for a robot. . .or even just provide a sample piece of code. If we sell them, it would be nice to show people what to do with them, but it's also not necessary.
Are there any simple applications that you might have in mind, even if we just offered an "idea list"?
Apologies for the cruddy pics - quickly snapped by a co-worker!
LOL, a valid use for a wide variety of components and small boards.
That looks and sounds like a smaller version of a board I designed for monitoring the mechanical pumps in high vacuum systems years ago. It then became my general purpose board for monitoring fans, pumps, and other actuators on critical systems. Your part could do the same.
If nothing else, I'll have a list of possible applications for this bag-o-parts!
I have been amazed how popular the cheap $5 line followers are in my Maker Faire demos. The Edison robot goes so far as to call line following the "Holy Grail" of robotics.
https://meetedison.com/robot-activities/youre-a-controller/line-tracking-robot/
Edit: That same page (Edison robot) shows that it can be "programmed" by reading a barcode. It's just a pattern of course stripes, not a real barcode. But that's a neat trick that a BoeBot could do. For educational demos, a master program might have ten subroutines... line following, photocell light response/tracking, sound sensitivity, etc. Then use one of these sensors to read a "barcode" pattern and branch to one of these subroutine behaviors.
https://forums.parallax.com/discussion/150349/scribbler-2-barcode-sensor
Just remember that these are not standard barcodes but are optimized for reading by a moving robot.
With just eight sensors, the remaining five semitones in an octave could be played by detecting simultaneous adjacent notes. Also, the range can be extended to multiple octaves by encoding the selected octave in separate tracks.
Addendum: A template could be designed as a PDF file, with inscriptions in very light lines and font, to show the locations and notes that a person could color in with a black pen or Sharpie. That way no special programming is needed to produce a disk for each selected song.
Furthermore, the micro need not play songs through a speaker, but could do it through a servo-operated xylophone, for example:
https://forums.parallax.com/discussion/162529/robotic-xylophone/p1
(4) 350-00038 Sharp GP2A25J0000F Sensor
(4) 805-28107 Cable for ActivityBot Encoder
(4) 150-02210 220 ohm ¼ resistor
(4) 150-01030 10K ohm ¼ resistor
(4) 451-00303
(2) packs jumper wires
$29 of parts we will sell for $15 each. 250 kits to be available.
Here's a look at what we're dealing with:
I can use all of your ideas. If any of you are highly motivated by this little project and want to make something to share (Phil's Music Box) or similar, drop me an e-mail and I'll send you a bag of parts kgracey@parallax.com
Now to sell these Arduino R3s down. Now on SALE for $18 each! ($4 less than others, and we'll ship them for free!)
For the really senior among us, modify your reel to reel tape to have EOT/BOT on your favorite recordings.....
I'd buy a few for sure.
It probably goes with the Player Piano too.
Version 2.0 would obviously be that the feline owner would put his hand on the sensor to get a cold drink from the fridge
Um, no, the ASR33 is not obsolete, neither is the Player Piano. Some amazing works were composed just for that instrument. And have not so recently emerged. The ASR33, and also the 43 are also in great use for the retro-computing enthusiast.
Mascot offers a yowl.
It's awesome that the 360 servos have built-in encoders. I don't think external encoders should go away. A kit with the following would be pretty neat, IMO.
H-Bridge
Small DC motor
Sharp sensors and resistors
Printed encoder wheel
Start with a single sensor tachometer. Work your way up to dual sensor quadrature closed loop feedback motor controller.
I'll go with the model railroaders one. In fact I've got an idea for a layout which would dwarf both the one that the gallery for the Museum of the NYCTA hosts every year, and even the one at the Botanical Garden in the Bronx has. But space is the limiting size of course.
Well yes. But I did not, and am not going to announce what brand of trains I've got in mind.
https://mailchi.mp/parallax/sharp-gp2a25j0000f-close-range-reflective-sensor-4-pack
Thanks all!
Sweet package!
In the product description, I see the following: "At the right distance of .03" they'll also detect the difference between black and white" Should that be .3" ? Three hundreds of an inch seems "oh so small"...
dgately
