P2 Eval RevB consuming 224mA on startup? — Parallax Forums
samuellsamuell Posts: 554
edited 2020-01-02 18:53 in Propeller 2
Hi,
I've just caught my P2 Eval RevB doing something unusual: consuming 224mA on startup, without being programmed. This was just after enumeration, after being unused for a few days. The issue was solved after pressing the reset button. I've disconnected and reconnected the board after that, without being able to repeat the glitch. The P2 seems to work fine, though, so nothing got damaged.
Has anyone had encountered such an issue?
Kind regards, Samuel Lourenço
    samuell wrote: »
    Hi,
    So, after that, you can't get it to show high current again? It should be around 30 milliamps, right? Not sure why that would happen.
  • cgracey wrote: »
    samuell wrote: »
    Hi,
    Indeed, I can't reproduce the glitch.
    Note that doing "itusb1-detach" and "itusb1-attach" on the terminal is the equivalent of doing a re-connection of the physical cable, since the board is connected via the ITUSB1 test switch.
  • Was there an SD card connected? I had something similar happen right after I got the board. It pulled about 150 ma and wouldnt boot. Eventually I found it was the SD card. Nary a problem since.
  • Do you have a SD card installed?
    While developing my RAISD system I had lock up situations with not unmounted SD cards where a reset would not be enough and I had to power cycle or remove and reinsert the SD card.
    There is an aweful lot of capacitance on the P2-EVAL so it is possible the inrush current could be this high although it would only be a power up spike.
    I have no way to measure the inrush spike though.
  • samuellsamuell Posts: 554
    edited 2020-01-02 23:42
    JRoark wrote: »
    msrobots wrote: »
    No SD card. Plus, all the switches were, and still are, in the "off" position, so the EEPROM was not being used.
    Cluso99 wrote: »
    But that spike would have to have a relatively long duration, in the order of ms. The program used to read the status takes five samples for the current measurement, and averages them. The one spike would need to be huge, or long in duration.
  • That realization has definitely moved this issue deep into “gremlin” territory. If it isnt the SD card, I got nothin...
  • evanhevanh Posts: 15,212
    It looks like the first reading after instrument initialisation. I wouldn't be treating that as an accurate reading without further evidence that it can't be screwy at that point.
  • You say its not programmed, but it would still run the startup code from Rom briefly, wouldn't it? The code that checks for a flash chip, listens on serial for a short while, etc?
  • samuell wrote: »
    JRoark wrote: »
    msrobots wrote: »
    Cluso99 wrote: »
    All switches open means no brownout detection.
    Some OSes might probe serial devices looking for a modem.
  • evanh wrote: »
    The program always does one or two bogus reads (depending on the initial condition) and discards them unconditionally, just right before taking samples for the actual read. Thus, it cannot be screwy.
    Tubular wrote: »
    Then I got "lucky", I guess.
    samuell wrote: »
    JRoark wrote: »
    msrobots wrote: »
    Cluso99 wrote: »
    No brownout detection just means that the P2 won't reset in case of a too low core voltage. Doubt that the glitch was caused by that. As for the OS trying to look for a modem, even if that happens, it shouldn't cause the glitch.
