Revisiting XMM Mode Using Modern Memory Chips - Page 9 — Parallax Forums
145679
  • RossHRossH Posts: 5,348
    I'll check the Forum postings later on this morning to see if you found something.
    Don't hurry back. It will take me some time to dissect the EEPROM dumps. They don't look correct to me - which is promising - but I can't figure out how some of the stuff in there got there!
  • Wingineer19Wingineer19 Posts: 279
    edited 2019-09-11 20:20
    @Wingineer19 - BTW - If you had put a quarter of your effort so far into Tachyon instead, you would be finished and working on the next version of your software, without the need for any kind of fancy memory expansion. Just saying. (dig dig :wink: )
    Perhaps, but you would have to account for the time necessary to come up to speed on Forth, as I haven't done any type of even rudimentary Forth programming in nearly 30 years.
    However, it's ability to immediately test and debug the Word without having to go through the C compiling, linking, and debugging process would no doubt speed things up.
    I've not ruled out ultimately using Forth, but right now I'm too lazy to ramp up on it, so while I insanely continue struggling and stumbling through my C program with XMM memory, I'm also working with @RossH to shake out some bugs and add some new features to Catalina that no doubt would benefit other users of the compiler. So from that perspective I see it as a 360-win scenario.
  • RossH wrote: »
    I took a look at a couple more programs.
    One was Sumeria.c, which compiled to a little less than 64KB. I uploaded it to my Project Board and it seems to work OK.
    Thinking that maybe we're looking at a 64KB limit issue, I grabbed Startrek.c and compiled it to 88KB. I uploaded it to the Project Board, and it seems to work fine too.
    So much for the 64KB limitation theory.
    I went back and reviewed the MenuTest.c program. It works fine using XMM SRAM. I again recompiled it to include the EEPROM loader, with a total size a bit more than 71KB. I uploaded it to the Project Board, and it still doesn't work. A lot of crazy characters before locking up the screen.
    We have one program less than 64KB that works.
    Another one that's nearly 90KB that works.
    And one that's around 71KB that doesn't work with the EEPROM loader, but does work with XMM SRAM. This program uses the 4-Port serial driver, while the other two use the TTY driver.
    Could the different serial drivers cause an issue?
    Ok, some progress.
    I have confirmed that the EEPROM is being programmed correctly. The stuff I saw in there that I couldn't understand seems to be parts of Tachyon, left in the EEPROM because Catalina only programs the sections of EEPROM it uses - and they were all ok.
    You can confirm this if you like by adding -d to the payload command, and verifying which parts of the EEPROM Catalina is actually programming, using a command like:
    payload EEPROM program.binary -d
    For example, here is what I see (adjust the -p parameter to suit your port):
    C:\Users\User\Downloads>payload EEPROM MenuTestWithLoader.binary -d -p8
    Catalina Payload 3.14
    diagnostic level 1
    arg: -p8
    switch: -p8
    using port COM8
    executable name = payload
    Loading Propeller binary EEPROM
    Error: Unable to open local file EEPROM.binary
     - trying bin directory
    File size = 5264
    baudrate = 115200
    timeout = 250
    sync timeout = 100
    reset delay = 0
    interfile delay = 500
    opened port 7
    Using Propeller (version 1) on port COM8 for first download
    Downloading normal binary file EEPROM
    Response = 0xfe
    Using Secondary Loader on port COM8 for subsequent download
    Downloading Catalina binary file MenuTestWithLoader.binary
    Loading Propeller binary MenuTestWithLoader.binary
    file = 73480 bytes
    Sending page 00000000
    Sending page 00000200
    Sending page 00000400
    Sending page 00000600
    Sending page 00000800
    Sending page 00000A00
    Sending page 00000C00
    Sending page 00000E00
    Sending page 00001000
    Sending page 00001200
    Sending page 00001400
    Sending page 00001600
    Sending page 00001800
    Sending page 00001A00
    Sending page 00001C00
    Sending page 00001E00
    Sending page 00002000
    Sending page 00002200
    Sending page 00002400
    Sending page 00002600
    Sending page 00002800
    Sending page 00002A00
    Sending page 00002C00
    Sending page 00002E00
    Skipping null 00003000
    Skipping null 00003200
    Skipping null 00003400
    Skipping null 00003600
    Skipping null 00003800
    Skipping null 00003A00
    Skipping null 00003C00
    Skipping null 00003E00
    Skipping null 00004000
    Skipping null 00004200
    Skipping null 00004400
    Skipping null 00004600
    Skipping null 00004800
    Skipping null 00004A00
    Skipping null 00004C00
    Skipping null 00004E00
    Skipping null 00005000
    Skipping null 00005200
    Skipping null 00005400
    Skipping null 00005600
    Skipping null 00005800
    Skipping null 00005A00
    Skipping null 00005C00
    Skipping null 00005E00
    Skipping null 00006000
    Skipping null 00006200
    Skipping null 00006400
    Skipping null 00006600
    Skipping null 00006800
    Skipping null 00006A00
    Skipping null 00006C00
    Skipping null 00006E00
    Skipping null 00007000
    Skipping null 00007200
    Skipping null 00007400
    Skipping null 00007600
    Skipping null 00007800
    Skipping null 00007A00
    Skipping null 00007C00
    Skipping null 00007E00
    Descriphering prologue
    seglayout = 00000002
    code_addr = 00001B94
    cnst_addr = 00000038
    init_addr = 000007E0
    data_addr = 000009F4
    ends_addr = 00009EF0
    ro_base   = 00001B94
    rw_base   = 00000038
    ro_ends   = 00009EF0
    rw_ends   = 00001B94
    Sending page 00008000
    Sending page 00008200
    Sending page 00008400
    Sending page 00008600
    Sending page 00008800
    Sending page 00008A00
    Sending page 00008C00
    Sending page 00008E00
    Sending page 00009000
    Sending page 00009200
    Sending page 00009400
    Sending page 00009600
    Sending page 00009800
    Sending page 00009A00
    Sending page 00009C00
    Sending page 00009E00
    Sending page 0000A000
    Sending page 0000A200
    Sending page 0000A400
    Sending page 0000A600
    Sending page 0000A800
    Sending page 0000AA00
    Sending page 0000AC00
    Sending page 0000AE00
    Sending page 0000B000
    Sending page 0000B200
    Sending page 0000B400
    Sending page 0000B600
    Sending page 0000B800
    Sending page 0000BA00
    Sending page 0000BC00
    Sending page 0000BE00
    Sending page 0000C000
    Sending page 0000C200
    Sending page 0000C400
    Sending page 0000C600
    Sending page 0000C800
    Sending page 0000CA00
    Sending page 0000CC00
    Sending page 0000CE00
    Sending page 0000D000
    Sending page 0000D200
    Sending page 0000D400
    Sending page 0000D600
    Sending page 0000D800
    Sending page 0000DA00
    Sending page 0000DC00
    Sending page 0000DE00
    Sending page 0000E000
    Sending page 0000E200
    Sending page 0000E400
    Sending page 0000E600
    Sending page 0000E800
    Sending page 0000EA00
    Sending page 0000EC00
    Sending page 0000EE00
    Sending page 0000F000
    Sending page 0000F200
    Sending page 0000F400
    Sending page 0000F600
    Sending page 0000F800
    Sending page 0000FA00
    Sending page 0000FC00
    Sending page 0000FE00
    Sending page 00010000
    Sending page 00010200
    Sending page 00010400
    Sending page 00010600
    Sending page 00010800
    Sending page 00010A00
    Sending page 00010C00
    Sending page 00010E00
    Sending page 00011000
    Sending page 00011200
    Sending page 00011400
    Sending page 00011600
    Sending page 00011800
    Sending page 00011A00
    Sending page 00011C00
    Sending page 00011E00
    Press a key to continue
    The areas I couldn't explain were all in those areas not programmed (e.g. in the "skipping Null" sections).
    I also now think that the program may be loading correctly from the EEPROM, because apart from the fact that we had smaller programs execute correctly, your program seemed to run correctly once. Also, I just re-read this snippet (my bold):
    It just puts a bunch of garbage on the screen. If you hit a key the initial Main Menu appears, but then it locks up after that. No further response.
    To get far enough to display the menu, the program code must have loaded correctly (at least up to that point). The fact that you see garbage on the sceeen beforehand means there is some Hub RAM memory corruption. It may be some peculiar hardware interaction between your XMM RAM and your EEPROM, such that reading from one and writing to the other is causing corruption, but which only occurs for larger programs (we know it works for smaller programs). To test this, we can try a slightly larger program - one that is known to work when compiled as SMALL and executed from the EEPROM - my old favorite startrek.c, which is in your "demos" folder.
    To do this, use commands like:
    cd demos
    catalina startrek.c -lc -lm -C CUSTOM -C SMALL -C CACHED_1K -C EEPROM -C TTY
    payload EEPROM startrek.binary -i
    If this works, we can keep trying larger and larger programs.
    Another possibility is that it is something specific to your program. Here are a few things we can try:
    1. The cache might be getting corrupted if you are running low on Hub RAM. Can you please try compiling your program with a 1K cache and loading it - i.e. something like:
    catalina program.c -lc -C CUSTOM -C SMALL -C CACHED_1K -C EEPROM
    2. There may be some destructive interaction between the specific plugins you use and the 3rd stage EEPROM loader. For me to investigate this, I will need a copy of your current program source code so that I can recompile it for my platform and investigate.
    We'll get there in the end!
    Ha! Our posts overlapped, and we are converging on the same theory!
    @Wingineer19
    Yes, I think it may be related to the plugin you use. Something is interacting badly with the 3rd stage loader.
    As I said in the last email, can you post your entire source code so I can investigate?
  • RossH wrote: »
    @Wingineer19
    Yeah, that's what I was beginning to think.
    I posted both Sumeria and Startrek earlier (see previous post), and both of them worked fine.
    But I used the TTY serial driver when compiling them. My MenuTest program uses the 4-Port serial driver.
    Check your emails. I decided to email them to you instead of posting them here on the Forum.
    Let me know if there's any problems getting it to compile
    Ok - got the sources, and they compile ok. I have to go out for a few hours, but I'll start investigating when I get back.
    edited 2019-09-12 03:49
    RossH wrote: »
    It looks like getting the s4 serial driver to work with this is a lost cause.
    However, I changed the code to use the tty functions instead of the s4 ones, and it works fine.
    And here's the sample GPS Raw Data Screen (The display is real, the data is fake -- for now):
    I went into the CduPort.c file and changed all s4 references to tty.
    Under Code::Blocks I went to Project >> Build options >> libtty instead of libserial4.
    Then recompiled, uploaded to the Project Board, and the Menus work fine.
    Unfortunately, for this Project I need at least 3 serial ports (CduPort, GpsPort, WiFiPort), which compels me to use the s4 library.
    The question, then, is how and why is the s4 driver messing with the EEPROM loader (or vice versa)…
    854 x 575 - 50K
    851 x 573 - 55K
  • Perhaps, but you would have to account for the time necessary to come up to speed on Forth, as I haven't done any type of even rudimentary Forth programming in nearly 30 years.
    I was actually taking that into account because it is not like learning a language, and then trying to use it. With Forth as you would know, you use it, you learn it. Start small at the bottom and then incrementally the routines that you write become the tools to test out and debug the system. While it may seem slow at first, your rewards are received as you go, and productivity increases proportionally.
  • I was actually taking that into account because it is not like learning a language, and then trying to use it. With Forth as you would know, you use it, you learn it. Start small at the bottom and then incrementally the routines that you write become the tools to test out and debug the system. While it may seem slow at first, your rewards are received as you go, and productivity increases proportionally.
    My Forth friend would agree with you 100%. He despised C and couldn't understand why anyone would want to mess with such an horrific language :)
    RossH wrote: »
    Yes, I also suspected the 4 port serial driver, which I am looking at now. It is a direct port of a Spin driver, and I think its use of Hub RAM is conflicting with other plugins in a way that only really shows up when it is being used by a largish program which is being loaded using the EEPROM loader.
    However, don't worry - if that is all the problem amounts to, it is quite fixable.
    Without knocking Forth, people use C because (apart from a few now well-known "gotchas") it is actually a very small, simple and straighforward language.
    Also, being the longest-lived "universal" language, you find that in many cases much of what you need already exists somewhere.
    Also, C is scaleable.
  • RossH wrote: »
    Yes, I've been programming in C for quite some time now and am quite comfortable with it. Like any computer language, it took time to get used to. At my former employer it's the only language I used for embedded systems work.
    Many years ago I had a short course on Forth, did a little bit of programming using it, found it interesting, but never did an in-depth dive on it. Eventually I would like to revisit it, but now it appears that Python is the going thing, so I guess I need to look at it as well...
  • RossH wrote: »
    It looks like excellent progress has been made today, as apparently we narrowed the problem down to the 4-Port serial driver.
    I have some questions about your EEPROM loader, as well as your XEPROM API, and their potential integration into the FLiP module with external memory, but that can wait for another day.
    And with that being said, I'm going to call it a night.
    edited 2019-09-12 08:29
    @Wingineer
    Well, I think I have some good news ...
    I found a problem with the initialization of the 4 port serial driver. The symptoms I see are similar to what you saw - i.e. you get some Smile on the screen, then the main menu comes up, but then the program freezes.
    What I think is happening is that the 3 currently unused ports (ports 1, 2 & 3) were not being initialized, and are interfering with the one currently used port (port 0). It seems likely that when you load the program serially the relevant portion of Hub RAM is usually zero, but when you load from EEPROM this memory is used by the EEPROM loader itself and is being set to something that is causing the problem. The fix was to just zero this memory during initialization of the serial4 plugin.
    I have attached a new version of Catalina_FullDuplexSerial4FC.spin which does this - put it in your target directory, then recompile your program and let me know how it goes.
    Ross.
    P.S. When you do need to use the other 3 serial ports, be aware that you will need to edit the file "Extras.spin" in the target directory. It should be fairly clear what you need to do, but ask if you have any questions.
    P.P.S. I noticed while investigating that there is a later version of the 4 port serial driver, which fixes a few minor issues (unrelated to the one I just found, which was entirely my own fault!). I will include the later version in the next release.
    P.P.P.S While messing about, I tried all the caching options - 1K, 2K, 4K and 8K. They all seem to work with your program now, whereas I think you had trouble with 8K before? Also, I had to use the XEPROM XMM option, since I don't have your XMM RAM hardware, so I can confirm that this works as well with your program. This will also be in the next release.
    edited 2019-09-12 23:44
    RossH wrote: »
    @Wingineer
    Yeah, what I saw was that it was repeatedly writing "Parallax Miniplate Participant" so fast that it was flickering on the screen. When I hit a key, the Main Menu came up, and then froze. So the problem was consistent across platforms.
    Ross.
    It works! I'm elated!
    To be on the safe side, I went ahead and defined the other S4 pins within the Extras.spin file:
    S4.AddPort(0,31,30,-1,-1,0,0,115200)
    S4.AddPort(1,17,16,-1,-1,0,0,115200)
    S4.AddPort(2,15,14,-1,-1,0,0,115200)
    S4.AddPort(3,13,12,-1,-1,0,0,115200)
    Well, I just tried other cache options, and all work except for the 8K. So the problem remains :(
    Since you brought up the subject of XEPROM, and recalling that I recently said this:
    Now is as good a time as any to go there.
    I want to focus on the FLiP module, so let's have a discussion about EEPROM physical memory mapping.
    If we had a single, large EEPROM (like 256KB) that replaced the existing 64KB on the FLiP, we would have a contiguous block of EEPROM memory that physically maps from $00000 to $3FFFF. So, your EEPROM loader is free to use whatever segments within this space to do its thing. Likewise, the XEPROM API is free to execute my Program Code from anywhere within this block, as specified by your compiling process.
    Keeping the 64KB EEPROM on the FLiP module, however, introduces a problem. Although I would like to actually replace this 64KB with 256KB, I don't want to risk damage to the module (which is likely if I tried).
    So, my only option is to add the 256KB EEPROM externally. But the 256KB EEPROM only has a single Device Address Bit, A2, which effectively allows me to map the EEPROM from address space $0000 to $3FFFF, or from $4000 to $7FFFF.
    I can't choose the former because it overlaps and conflicts with the existing 64KB EEPROM space used by the FLiP, so I must choose the latter.
    With our two EEPROMs, we now have this physical addressing:
    $0000_0000 to $0000_FFFF (Internal 64KB EEPROM)
    $0001_0000 to $0003_FFFF (Nothing)
    $0004_0000 to $0007_FFFF (External 256KB EEPROM)
    As you can see, this arrangement is not contiguous, and thus poses a problem.
    Unless, of course, there's a way to provide Addressing information to both the EEPROM Loader, and the XEPROM API, telling them that I only want to use that external 256KB memory to store/load/execute my Program Code, and not mess with the internal 64KB memory.
    Somewhere within your EEPROM Loader and XEPROM API there has to be a constant or variable that specifies the starting address of the Program Code.
    Within the XEPROM API Definition file, I found this:
    ' This file contains definitions for using EEPROM as XMM. The EEPROM must
    ' be larger than 32k to be used for XMM (note that a 64k EEPROM is better
    ' used as CMM or LMM, which can be done using just the EEPROM loader).
    '============================= XMM DEFINITIONS =================================
    ' XMM Base Address. Catalina currently requires one contiguous block
    ' of XMM RAM - Note that this is the internal hardware address, not
    ' the address the Catalina XMM Kernel uses:
    XMM_BASE_ADDRESS = $0000_0000   ' XMM adddressing from 0
    ' XMM RW & RO Base Addresses - Note that these are the addresses used
    ' by the Catalina XMM Kernel - they typically start AFTER the last
    ' Hub address:
    XMM_RW_BASE_ADDRESS = $0000_8000 ' Read-Write Base address (not used)
    XMM_RO_BASE_ADDRESS = $0000_8000 ' Read-Only Base address
    ' XMM RW & RO Sizes (in bytes):
    XMM_RW_SIZE = -1                 ' Read-Write Size (not used)
    ' The following symbol is currently used only by the XMM RAM Test program
    ' (which is not really relevant for executing XMM code from EEPROM) but it
    ' may eventually be used elsewhere, so it should be set. It is currently set
    ' for a 128k EEPROM:
    XMM_RO_SIZE = $0002_0000         ' Read-Only Size (for a a 128k EEPROM)
    ' This value determines the size of the cache index:
    CACHE_INDEX_LOG2 = 7         ' log2 of entries in cache index
    '========================== END OF XMM DEFINITIONS =============================
    So it appears that:
    does specify the starting address, while:
    sets the EEPROM size.
    Does this mean that if I do this:
    XMM_RO_BASE_ADDRESS = $0004_0000
    and this:
    XMM_RO_SIZE = $0004_0000
    that the XEPROM code will execute from the 256KB EEPROM?
    If so, that's fantastic.
    How do I convey this Addressing information to the actual EEPROM Loader?
    It would need to know this regardless of whether it will ultimately have the XEPROM API execute Program Code from the 256KB EEPROM itself, or if it instead copies the EEPROM Program Code over to the SRAM for execution by the SRAM XMM API.
    So I guess the question is, how do you tell the EEPROM Loader where to store the actual Program Code, and is there a way to tell it to store it in the external 256KB EEPROM?
  • RossH wrote: »
    Just as long as you keep your new s4_txcheck() function, all should be well :)
    Phew! :)
    Yes, that looks ok. Note that the newer version of the 4 port serial driver seems to include bug fixes for the 3 upper ports, mostly to do with the RTS/CTS handling (which it seems from the above you don't intend to use) - but in any case I will have that version out soon.
    I will look at that again when I have some time. It may be related to your XMM API code.
    I had a quick look at the FLiP module. It should be supported "out of the box", but I may add a new symbol for it (-C FLIP) in the next release.
    All correct.
    Yes, it would be a problem. However, that problem goes away if you use a FLASH chip instead of an EEPROM. Catalina would then work with without much effort - just a fairly simple new XMM API. Catalina already has such an API for a module that is essentially just a FLASH chip - look at the FlashPoint SuperQuad API.
    It is possible you could use an EEPROM in this way as long as it is on its own I2C bus - i.e. 2 pins. But why not use a FLASH chip?
    Unless there's a way to provide Addressing information to both the EEPROM Loader, and the XEPROM API, telling them that I only want to use that external 256KB memory to store/load/execute my Program Code, and not mess with the internal 64KB memory.
    Simple - don't use the XEPROM API, use a new FLASH API.
    ' Hub address:
    So it appears that:
    and this:
    Sorry to disappoint, but most of those constants are not used anywhere except in the RAM Test code. I originally defined them and used them, then discovered that there was really no need for most of them. Even their use in the RAM Test code is probably unnecessary.
    I don't know of any means to specify Addressing information to the Loader telling it where to get the Program Code from EEPROM...
    It would need to know this regardless of whether it will ultimately be executing Program Code from the 256KB EEPROM itself using the XEPROM API, or if it simply needs to ship the Program Code to SRAM for execution by the SRAM XMM API.
    The short answer is "no".
    The longer answer is "maybe, if you were willing to do a lot of work"
    But the best answer is to just use a FLASH chip (or an EEPROM) on its own I2C bus. Is there a specific reason you don't want to use this option? Is it just to save the 2 pins?
    Yes, that will be in the next release.
  • So I guess the question is, how do you tell the EEPROM Loader where to store the actual Program Code, and is there a way to tell it to store it in the external 256KB EEPROM?
    RossH wrote: »
    Yes, reducing (or ideally eliminating) the number of pins required to access external memory could allow me to discard some multiplexers and latches needed to access other devices the propeller will be working with, thus reducing circuit complexity.
    The program execution speed will be the determining factor, though, as to whether or not I can go with the I2C EEPROM approach or the Flash one. There's going to be a lot of UART serial traffic the prop will have to manage, so the I2C approach might not be able to keep up, even with an 8K cache enabled.
    An indicator could be how fast you saw the various MenuTest screens updating when you were running XEPROM. If the GPS Command Screen was updating pretty quickly then there's a chance the EEPROM approach might work. If it was moving at a snail's pace, then Flash wins.
    Bottom line, it sounds like what I want to do for this test, namely executing Program Code from the external EEPROM, could be accomplished if I write the Flash API to work with it instead of a Flash chip. Which is what I've been assuming all along, and was supposed to be working on this week. I was just hoping I could take a short cut if your XEPROM API would let me do that instead. :smiley:
    Of course I could still run the test using my USB Project Board, which has the 256KB EEPROM installed instead of the 64KB one, if the XEPROM API was working. I just tried doing that using the XEPROM API you posted, but Catalina aborted the compiling process with a lot of errors:
    C:\WorkCode\Catalina\XMM2\MenuTest\11Sep19A>catalina -CCLOCK -CNO_HMI -CXEPROM -CCACHED_4K -CSMALL -Clibtty -Clibma -Clibc -CCUSTOM -p1 menutest.c
    Catalina Compiler 3.16
    Undefined or Redefined symbols:
     tty_tx undefined
     tty_rxcheck undefined
     rtc_settime undefined
     strftime undefined
     gmtime undefined
     time undefined
     difftime undefined
     strlen undefined
     strcat undefined
     strcpy undefined
     vsprintf undefined
     sprintf undefined
    I know you cautioned me that it probably wouldn't work, but I wanted to try it anyway. My bad :)
    Oh, is there a particular reason why you mentioned using a separate I2C bus instead of the one currently used by the internal 64KB EEPROM and the external 256KB one?
    I thought I would be able to adjust the addressing within the Flash API in order to direct traffic to the external 256KB EEPROM on the bus?
    edited 2019-09-13 01:21
    @Wingineer19 - pssst - this guy is as crazy as you :wink:
    @RossH - pssst - this guy is as crazy as you :wink:
    @"Peter Jakacki" - you're talking to yourself again :astonished:
    But if eeprom is only being accessed at 100kHz rates surely it would benefit if it could read at 1MHz rates.
    Btw, it would be fairly easy to replace the eeprom without damage. It's only 8 pins and desolders with a hot iron and a blob of solder.
     tty_tx undefined
     strftime undefined
     gmtime undefined
     time undefined
     difftime undefined
     strlen undefined
     strcat undefined
     strcpy undefined
     vsprintf undefined
     sprintf undefined
    Most of those errors are because you are using -Clibxxx instead of -lxxx for the libraries. Your command should be:
    catalina -CCLOCK -CNO_HMI -CXEPROM -CCACHED_4K -CSMALL -ltty -lma -lc -CCUSTOM -p1 menutest.c
    However, the XEPROM API needs a few tweaks to various other files in the target directory. Wait till the next release to use it.
    I'm not sure about this one. I don't know enough about I2C. I guess if you don't need to access the EEPROM after boot time, the same I2C bus can be used for exclusive access to the other EEPROM just by using the appropriate device address. If so, then this is probably your answer.
    Is there an echo in here? :)
    The existing I2C driver should work at 400khz if the EEPROM supports it. Beyond that we'd just have to try it and see. Just like EEPROMs larger than 128kb, I don't think EEPROMs supporting 1MHz bus speeds were around when this driver was written, but it might be able to support it. It's probably worth a try.
    However, the advantages of faster bus speeds are not as dramatic as you might think, because of the use of the cache. With a large enough cache, doubling the bus speed only gives you a small improvement. Of course, it depends on how linear the code is - if the code consists of small functions or loops that can fit entirely into the cache, you may get no improvement at all.
  • An L2 cache in hub ram could hold a larger chunk which would leverage sequential read speeds. What size is your cache and how is it organised?
  • @Wingineer19 - pssst - this guy is as crazy as you :wink:
    LOL. I just now saw this after I got back from dinner. Too much excitement here! :)
    We know the AT24CM02 can support 1MHz bus speed. Tachyon proved that a couple of days ago once I lowered the pullup resistors to around 2K each.
    For a normal person, yes. In my case, I would likely break the circuit board in half, while simultaneously covering everything with an entire spool of solder :)
    If only there was a P1X1 module that had 256KB EEPROM installed...
    edited 2019-09-13 02:10
    Cache size can be 1K, 2K, 4K or 8K of Hub RAM. Organized as pages of 8 - 8K bytes, configurable depending on the cache size and the platform.
    For more detail I'd have to refer to the code.
    EDIT: I just realized you could go up to a page size of 8K if you reduced the cache to a single page. Not that you would, but I think the code supports it.
  • RossH wrote: »
    You really expect me to wait? :)
    RossH wrote: »
    I'm pretty sure it will work just as long as the API sends the proper address values to confine access between $0004_0000 and $0007_FFFF on the bus.
    I guess I will find out once I write the Flash (EEPROM) API...
    edited 2019-09-13 02:19
    Cluso99 already has tiny P8XBlade2 modules and could supply them with 256kB I'm sure but I have a ton of various modules I have designed such as the P8 which also has Flash. What are your requirements in terms of size, power, I/O etc?
    BTW, you would be surprised how easy it is to remove a small SMD component. Blob some solder onto both sides of the chip and then with a hot iron and a larger tip and some more solder just run that tip on either side a couple of times and the chip falls off. Hot air from a gas iron works well too and you just pick up the part with tweezers. Failing that just cut the leads of the old chip with a exacto pen by pressing on the pins so that the package comes loose and then use a solder blob on a big tip to draw the remnants off the board in one quick action.
  • RossH wrote: »
    The 512KB SRAMs I use consist of two, 256KB SRAMs on the same die. I believe they will support sequential access up to the 256KB limit, in which case you must terminate the process and restart since you can't cross the die boundary.
    Looking at the 256KB AT24CM02 EEPROM, it appears to support sequential reads up to the maximum 256KB limit, then rolls back over to location $0. Page writes are limited to 256 bytes each.
