Accessory Boards - Page 3 — Parallax Forums
Accessory Boards
13
  • whicker wrote: »
    The "charlieplex_text.spin2" isn't in the zip file.
    Today isn't my day :(. Sorry about that -- let's hope it's third time lucky. I've updated the .zip above, and I'll attach the file here too.
  • ersmith wrote: »
    whicker wrote: »
    Wow. Pretty neat that this print #2 device is able to wait until the buffer has enough room.
    I wrote some code to slam it with strings and no other waits.
    I tested this by toggling an LED in the loop, and the LED only toggles every few seconds as new strings are brought in.
  • Ahle2Ahle2 Posts: 1,178
    Is there a ready to use 640x480 1bpp VGA driver laying around somewhere that will work with ES + accessory board? I will eventually read up on video stuff on the P2 and do my own driver, but I would like a quick start to get going!
    On the VGA 1920x1080 thread I posted 1bpp code. Perhaps you can massage that into 640x480.
    Cluso99,
    Thank you for always being so helpful! :smile:
  • I found some use for almost all accessory boards, except the Goerzel one.
    What is it supposed to do? My guess would be Propscope to gnd X an Y and then what?
    curious,
  • evanhevanh Posts: 15,203
    Its an analogue joystick for your finger! :) It is computed like a resolver is, but uses electric fields instead of magnetic fields.
  • aah, looking sideways at the board shows some sort f a pad, I see.
    Is there any demo?
  • Has anyone actually written code to successfully drive the Goerzel board?
  • @cgracey had a demo here somewhere.
  • Ozprop and I had a brief look at the goertzel board a while ago. I think Chip's code needs adapting to that small board. The original demo Chip did had sparse electrodes on quite a large scale. The goertzel board is very compact and the electrodes immediately adjacent to each other
    Tubular wrote: »
    Just read this thread. I haven't written any code, yet, for the Goertzel board.
    Parallax just built some of these and sent me two. It's the HyperRAM/Flash board that VonSzarvas designed.
    1024 x 576 - 184K
  • msrobotsmsrobots Posts: 3,704
    edited 2019-08-23 22:27
    nice.
    I wonder If I need one, just in case.
    I showed you that monstrous Laptop I keep to replace the innards with some P2 stuff I have not written yet...
  • cgracey wrote: »
    Does this mean we need to start working on XMM for P2? :smile:
  • David Betz wrote: »
    yes
  • RaymanRayman Posts: 13,918
    I suppose it looks a bit better than my Hyper board...
    msrobots wrote: »
    nice.
    I need to ask how many they built.
  • cgracey wrote: »
    Yummy!
    Kind regards, Samuel Lourenço
    I wonder if the fixed pll will allow for new P2 clock and VGA resolution options than before when showing image from HyperX...
    edited 2019-08-24 00:08
    Nice-looking addition.
    Congratulations to VonSzarvas and every other ones involved in the production of those boards.
    Hope they could be ordered with two HyperRams fitted.
    edited 2019-08-24 02:15
    Mike,
    I went a looking for the code to control the Goertzel accessory board and found it - https://forums.parallax.com/discussion/169236/fun-with-goertzel/p1
    Tested and works as advertised. Just had to set the pin constants to suit (I used the second header):
    		gtzpin = 8			'four quadrants, four consecutive pins
    		adcpin = 15			'centre pad
    		xpin = 12			'scope X
    		ypin = 13			'scope Y
    edited 2019-08-24 08:30
    evanh wrote: »
    Mike,
    		xpin = 12			'scope X
    		ypin = 13			'scope Y
    oh cool, I need to try that out.
    I hope I understand the code, need to look at it. Finally a reason to get the propscope and PPDB out of the plastic container and onto the new workbench. Yes! I am building a new man-cave. The room is fresh painted, has a nice hardwood floor, and a solid work bench so far.
    Something around 12 by 12, so small, but I will try to build it as cozy as I can.
    Current goal is to have all outlets grounded not just the ones on one side of the room.
    House is build I 1930 so one has to have patience to get stuff up to standard.
    edited 2019-08-24 09:19
    Renovation of an unused room, or moved house recently?
    In doing some more experimenting with the Goertzel board I'm finding it needs further translating to give a one to one mapping of the x/y position. As it is it has a circular trace when moving across a side/corner, ie: off centre motion.
    Proximity and size are a major factor to amplification. Without any mechanical guide it is very wonky to control. Even the rolled up fingers affect it. I placed a block ceramic heatsink on top that I could run my finger over and that helped a lot. Sadly it was too big to sit evenly so it still produced a lopsided effect.
    edited 2019-08-24 13:06
    Ah ... increasing the sensitivity by reducing the "shift" constant to 8 and adding basic filtering, it becomes more linear because the finger motion stays more central. I've levelled the ceramic block as well. So my finger is now kept a constant 16 mm away from the board, and finger tip motion is confined to a few millimetres from perpendicular centre of the pads.
    EDIT: Also needed a calibrate button to handle drift and shifting conditions like the position of the ceramic block and even the plastic spacer for levelling it. I used the four-button control accessory for this.
    edited 2019-08-24 17:02
    The new P2 silicon has SINC2 filtering in the Goertzel circuit, which is a huge improvement.
    It also allows 120-degree 3-phase output by always assuming data in LUT are pre-signed. The 4th channel can be a 180-degree complement to the 3rd channel. So, you can get by with three outputs, instead of four.
    edited 2019-08-25 10:55
    evanh wrote: »
    both, see here how it started … http://real-hell.blogspot.com took me a while to fix it. My Sister published that. I can't even access it. You might know the difference between Friends and Family, you can choose your Friends!
    Now I am able to unpack and have a nice Lab, hopefully.
    That's a lot of garbage lying around! It looks like it had some squatters staying.
  • cgracey wrote: »
    I'm also interested in coding and sharing results on this board. I just got permanently laid off from my controls engineer job of 15 years, so I'm looking for something productive to do in the interim.
    whicker wrote: »
    If you want to write code for the HyperRAM board, I will send you one. PM me your shipping address.
