New Products!
A neat little compound sensor. Gas sensor with air pressure, humidity, and ambient air temperature.Bosch quality.
https://www.parallax.com/product/28061
And a long awaited ePaper display!
https://www.parallax.com/product/28084
Rumors of a new GPS soon. (I saw some finished product on Twitter).
It does not mention Methane specifically. Not sure if it would work as a "bad smell detector".
I suspect it would also detect methane and other flammable gases like propane, MAPP, etc. Phil, you should try it out and report back to us ;-)
More to come!
I see you've done some research on the topic. I'm surprised that it's only 7% methane. I wonder what the other 92% is. If the balance is air then I think the ...umm....whats the polite term...ah researchers who ignite the gas at it's source might be risking some painful burns in a tender area.
Does H2 qualify as a VOC?
No - VOCs must contain carbon. Whether that sensor would detect it is a different question. Off to research their theory of operation...
Mike R...
Are not we Carbon Based?
Absolutely! Being carbon based != VOC... Except for certain, ummm, "emissions"! :-) Every time I see the word "organic" it causes instant anxiety as I am now forced to recall a couple of semesters of organic chemistry. "Organic food" - of COURSE it's carbon based! Pedantic Mike heads off to go float in my non-VOC pool. :-) :-)
Mike R...
We are, which is why we emit 9% CO2. While H2 does not qualify as a VOC I suspect it might produce a reading.
