Streamer for digital pin sampling
I would like to use the P2 streamer to sample I/O pins and am not sure where to start.
I have a separate cog that will wait for a que to log a sample of pins.
What i need to understand is how to setup the streamer to read 'n' samples of pins, where these samples will be saved, and if I can save a group of pins.
Can I sample P0-P31 (a long) each clock?
Is there any sample code to look at?
  • evanhevanh Posts: 9,830
    edited 2018-11-04 - 21:58:43
    Here's a streamer config for 32-bit input:
    %1111_xxxx_xppp_xxxx          -    32-pin -> WFLONG                    <none>
    In the case of the pure input modes (top nibble = %1101..%1111), the %ppp field selects which pins will be captured on streamer input cycles:
    %ppp : 000 = pins 31..0
    001 = pins 39..8
    010 = pins 47..16
    011 = pins 55..24
    100 = pins 63..32
    101 = pins 7..0, 63..40
    110 = pins 15..0, 63..48
    111 = pins 23..0, 63..56
    For the 1/2/4-bit WFBYTE submodes, extra %p bits below the %ppp field are use to select the bit, twit, or nibble within the byte selected by %ppp.
    WFBYTE/WFWORD/WFLONG modes
    On every NCO rollover, input pins are captured and a background WFBYTE/WFWORD/WFLONG is executed to store them into the hub.
    It is necessary to do a WRFAST sometime beforehand, to ensure that the hub RAM FIFO is ready to receive data.
  • The Goertzel testing should help with general use of the streamers - https://forums.parallax.com/discussion/169210/goertzel-self-test/p1
  • It is really simple, Cluso99. First, you set up the frequency and then you give it a command which includes how many samples to take. Of course, do a WRFAST first.
  • Ray
    Have a look at my P2 logic analyzer, it should help.
    https://forums.parallax.com/discussion/163967/p123-a9-prop2-logic-analyzer
  • Thanks for the link Brian. I'll look to see if it does what I want as it may well do, or else a simple mod may work.
    I often just want to see what is happening on a group of pins. I can easily set something to start the sample off, and let it run for 'x' samples.
    Hopefully it samples on every clock. I presume this is possible?
  • The default frequency setting is $8000_0000, which causes something to happen on every clock.
  • Code looks good Brian.
    I expected the streamer part to be way more complex to setup. Should get some time to try it today.
    Thanks Chip. Similar to P1 timer setup :smile:
  • Cluso99Cluso99 Posts: 16,574
    edited 2018-11-06 - 06:04:31
    Here is a section of code to record 'sample_length' of P0-P31 or P32-P63 using the streamer into HUB RAM at 'samples'...
    con
    ' Streams INA (32 bits) to hub.
                    sample_length = 4000    'longs
    dat             orgh
                    org     0
                    setxfrq ##$8000_0000    'sysclk sample rate
                    wrfast  #0,##@samples
    '                         %1111_xxxx_xppp_xxxx << 16 ppp=000 P00-31, =100 P32-63
    '                                     000                                 P31-0
    '                                     001                                 P39-8
    '                                     010                                 P47-16
    '                                     011                                 P55-24
    '                                     100                                 P63-32
    '                                     101                            P7-0+P63-40
    '                                     110                           P15-0+P63-48
    '                                     111                           P23-0+P63-56
                    xinit   ##%1111_0000_0000_0000 << 16 | sample_length,#0  'P00-31
    '               xinit   ##%1111_0000_0100_0000 << 16 | sample_length,#0  'P32-63
                    waitxfi
                    orgh    $4000
    samples         long    0[sample_length]
  • Here is a complete program for sampling P0-31 or P32-63 and then outputting to the serial port using the ROM in-built commands to output in hex...
  • Next question,
    Using the streamer in writing pins to hub, if I just want to write 8 pins, I use WRBYTE.
    The docs seem to imply that a byte is written to hub on every NCO rollover.
    Does the hub address increment by 1 for each wrbyte?
    And if I am streaming every clock, will the streamer/fifo pack the bytes up where necessary as the hub window is 8 clocks and each clock the window advances by a long address?
  • Yes, it's all taken care of.
    edited 2018-11-17 - 10:22:44
    In the VGA program, the hub accounts for half the screen. That's fine because if i display 2X it just wraps. So RDFAST is only executed once at the beginning.
    If I want to change the buffer during the screen display, do I need to insert an FBLOCK instruction (D[31]=0) in between one of the line displays? Will it store the new values ready for the RDFAST count expiration?
    eg At the start of the visible lines, execute an FBLOCK ##blockcount,##hubaddr and halfway thru the visible lines, execute another FBLOCK ##blockcount,##hubaddr2 where blockcount= 1080 /2 /64 /2 = 135/32 ??
  • You can do FBLOCK right after RDFAST, but before the current block is completed. Not sure about your math, as I don't know your goal.
  • Thanks Chip. I just wanted to confirm what I thought was the case.
    I want to build the 1080 screen into sections - part graphics and part text. I want the whole 512KB HUB for screen buffer, so I will need to load up cogs/luts first, then clear hub for the buffer.
    This is the "FUN" that we all love :smiley:
    And it's testing out the P2 in different ways.
  • The following works for streaming 32-pins, 16-pins and 1-pin.
    '' Sample P0-P31 using streamer to hub on every clock cycle...
    '                                     000                                 P31-0
    '                                     001                                 P39-8
    '                                     010                                 P47-16
    '                                     011                                 P55-24
    '                                     100                                 P63-32
    '                                     101                            P7-0+P63-40
    '                                     110                           P15-0+P63-48
    '                                     111                           P23-0+P63-56
    '               xinit   ##%1110_0000_0000_0000 << 16 | sample_length,#0  'P00-15 (16 bits)
    '               xinit   ##%1101_xxxx_xppp_pppx << 16 | sample_length,#0  'P00    (1 bit) wkg
                    waitxfi
    The following is in the document, but I am not following the explanation or get it to work for 8-bits, 4-bits or 2-bits
    %1101_xxxx_xppp_pppx %r00 1-pin -> WFBYTE, r=reorder <none>
    %1101_xxxx_xppp_ppxx %r01 2-pin -> WFBYTE, r=reorder <none>
    %1101_xxxx_xppp_pxxx %r10 4-pin -> WFBYTE, r=reorder <none>
    %1101_xxxx_xppp_xxxx %11 8-pin -> WFBYTE <none>
    Anyone have it working in byte/nibble/nit modes?
  • Cluso99, I found a strange bug in these modes, I believe, where your XINIT/XCONT/XZERO instruction cannot have D[2:0] clear. It seems to hang up the streamer.
    edited 2018-11-24 - 14:02:43
    Solved...
                    xinit   ##%1101_0000_0000_0000 << 16 | sample_length,#%00011  'P00-07 (8 bits)
    Needed extra config bits in the #S operand. I was trying to put them in the #D command :(
  • jmgjmg Posts: 14,474
    Does the 'solved' above merely avoid this bug ?
  • jmg wrote: »
    Not sure, but the streamer is getting a big makeover. I'll need to recreate exactly what the problem was. It needs to be known for the current silicon.
  • cgracey wrote: »
    I've probably avoided the bug accidentally as I've used the sample length in decimal as in 50, 200, etc.
    Hope to combine my sampler with my VGA today. Wish me luck ;)
  • The streamer bug appears in 4/2/1 bit modes when DAC's are involved.
  • ozpropdev wrote: »
    There's another one, I believe, that has to do with WFBYTE 1/2/4-bit modes and count LSBs in D[2:0].
