P2 Streamer and parallel LCD video support
rogloh
Was browsing the P2 documentation today trying to figure out if/how the streamer might be able to support parallel video busses of LCD panels.
Maybe these are going be questions where only Chip currently knows the answers unless someone's already done something like this on one of the P2 FPGA platforms:
For an LCD can you get its CLK and DE signal output synchronously with the video data and in the appropriate phase with the streamer or smartpins perhaps? Let's say the LCD panel needs 40MHz which is a nice submultiple of some 160MHz system clock for example. Will it be possible to have these two LCD control signals generated correctly by the COG or other internal HW and output to the LCD panel?
Also if an LCD with say 18 parallel video inputs (6bpp x 3 RGB) is used, can the unused RGB data bit pins (the LSBs) of the 8:8:8:0 formatted output the streamer generates be freely allocated to other COGs/functions, also in particular including their use for CLK and DE signals as mentioned above, or are there some other limitations there?
Roger.
Roger.
And, yes, if you had 6x3 significant data outputs for RGB, you could repurpose each of the top two bits of the 8:8:8:0 streamer outputs by keeping their DIR bits low. Then, other cogs could control those pins.
I had kind of suspected something like that and I guess the proof of the pudding is in the eating. I hope to take a tasty bite once it's all ready.
Cheers!
I look forward to actually playing with it, too.
Just ruminating now about how to set up the development tools.
The good news is the smartpins sit in the middle and do have the ability to completely intercede if you wanted to do the LCD control signals on those very pins. Here's a snippet from the manual: It should even be possible to then use the DIR line to bit-bash via the smartpin.
What is needed is a 32-bit mask to gate streamer OUT bits. Too late now, but if we revise the silicon, that could go in.
Yeah I figured I would be unable to reuse the disabled streamer output pixel pins in the same COG that is using its streamer directly. In my case I'd like to use these spare pins from other COGs for features such as SD/USB etc, and not just leave them wasted when there are less bits per colour channel than 8 in the case of an 18bit LCD panel for example. However I'd quite like it if the COG that is setting up the streamer could also use Smartpins to do the CLK and DE signals on either a couple of the disabled streamer output pixels (perhaps not possible), or at least using two other pins that are not part of the defined 32 bit group that the streamer is controlling. These LCD CLK and DE signals need to be synchronized with the streamer data and in the appropriate phase, so I imagine the COG driving the streamer will need to coordinate them. From Chip's response I gather it should be possible to reliably set that up (I would hope, anyway).
Roger.
So, I don't think there's really a need for a 32-bit mask, after all.
Streamer gets configured to use the following pins:
%eppp : 1111 = enable output on pins 23..0, 63..56
DIR bits set to enable only pixels MSBs on red, green, blue channels with 6 bits each. The redundant fourth streamer byte lane (the "0" in the 8:8:8:0 output) is wrapped around to high pins and also disabled in DIR.
So DIR is
0000000000000000000000000000000000000011_111111_00_111111_00_111111_00
and
P0..P1 - free for use by other COGs
P2..P7 - Blue channel (6 MSBs of 8 bit data, sourced from HUB/LUT)
P8..P9 - free for use by other COGs
P10..P15 - Green channel (6 MSBs of 8 bit data, sourced from HUB/LUT)
P16..P17 - free for use by other COGs
P18..P23 - Red channel (6 MSBs of 8 bit data, sourced from HUB/LUT)
P24..P25 - two Smartpins for LCD CLK, DE signal generation, under control of same COG using pixel streamer
P26..P63 - free for other functions
If that is possible I will be a happy person.
EDIT: looking at the Smartpin stuff I guess DE signal could be generated using a Pulse/cycle output mode, with the high time set as the same as the number of active pixels, and the cycle time as the number of total pixels, with the base clock period equal to the pixel period. The Y register would be set to the number of active lines once each frame, after which DE would drop low. I'd hope this sequence could remain synchronized with the streamer, as the streamer gets reconfigured for each video line and frame. The LCD clock output should be easy enough if it is an integer fraction of the system clock and we can delay down to individual clock cycles and/or it's rising/falling edges.
Could be my poor understanding, but, wasn't Chip talking about the 6 LSbs of each one of the color bytes, and you, in turn, about the 6 MSbs of the same bytes?
Henrique
EDIT: I haven't looked at using LUT tables. Maybe a good advantage to low order output bits then.
Another thing to consider is that if you want to simultaneously output this data to DACs (assuming that is possible), by using the top bits you should get a larger dynamic range of analog voltages at the output and a brighter image.
Yes, that was the way I've understood it.
Perhaps its due to the fact I have a long history with indexing, anyway, I tend to always use the LSbs first, by principle.
Acting otherwise, I feel like I'm trying to follow Ben Turpin's line of sight.
Henrique
