Maze solver
Here are a video and a pdf file relating to a maze solving PARALLAX robot. The pdf file contains the software written in "Arduino".
It is still a bit crude: the servos need re-centering and the turns are clunky. But it is time to show off. Hope you like it.
vimeo.com/238068223
vimeo.com/238068223
http://forums.parallax.com/discussion/138125/erco-s-figure-eight-challenge
Fantastic work on the new servo motors. I am tempted to jump into the Figure 8 Challenge with the new servos....
I want to see if I can do this with an S3!
Just had a look at the S3's details. It certainly looks doable. You will probably have to increase the number of line sensors because with only 2 sensors it is difficult for the robot to work out the need for making sharp turns.
I tried with 4 sensors and failed, but succeeded with 6.
Keep us posted on your progress.
I was thinking of trying both - first with a specialized using the existing sensors, then my back up plan was to use the hacker port to add additional sensors. I also want to try to do this with BlocklyProp to demonstrate that it is capable of something like this.
I will keep you posted!
Thanks for your great example.
