new prop stops at 86%
I bought a new prop chip because, i believe, i burned the one i had.
the problem is that im trying to make it say a hello via the Simple IDE and it it at 86% and wont do anything else.
Do i have to do anything to make it work? isnt it suppose to be plug and play?
I am using a 4x AA battery, might be about 5v and about 4Amps. I am starting to believe that it is a software problem and not the chips because the power led connected to them is on. If anyone had the same problem. I have restored the laptop to a previous state, didnt work, trying to uninstall and re-install the simpleIDE, doesnt work (downloads yet it cannot load). Might need to inform parallax, yet I am still cautious as I have recently toasted a prop chip so...
It is the simpleIDE problem because everything else works (prop tool, bs2, arduino).
Does anyone have a previous version of it to upload?
Using an LED to indicate proper voltage is deceptive. It is much better to get a little switcher that displays Volt. It can toggle from input side to output side, so you can monitor that actual voltage while programing.
If you don't want to buy that, just use a multimeter to monitor the voltage at the Propeller pins - not anywhere else.
If you can load the original Propeller IDE (aka Propeller Tool) to the same computer and it works, that would confirm the Simple IDE problem.
But I will shut up as it seems that Simple IDE might have a problem with W10 that I know nothing about.
If you are using both the 5V and 3.3V regulators you could have a problem with 4 AA batteries if they are slightly drained, or if you are pulling a lot of current. The minimum input voltage for the 5V regulator is 6 volts, so if the AA batteries are drained they could be below the minimum voltage. I've had problems using 9V batteries that were almost dead, where programs that used just one cog worked OK, but programs using multiple cogs would fail due to the higher current drain and resulting voltage drop.
It is really nerve breaking :-(
The other issues is if there is an unresolved bug in Simple IDE when installed in Windows 10 on some computers (yes it may be one computer's BIOS or something). I think now that the idea has been expressed, Parallax would like to make sure they can help anyone else with similar Simple IDE problems on Windows 10.
So I guess I have clarified -- Can you get what you want? and can Parallax get what it wants? Most importantly, Parallax wants you to be a satisfied customer. They might skip what they want.
- Both Props load from the Prop Tool
- Both Props do not print to the terminal
- Neither Prop works with SimpleIDE. The loading stops at 85% on both.
Are those statements correct?
Now let's figure out why your program doesn't print to the terminal. What terminal program are you using? Are you using the Propeller-Serial-Terminal program? Could you post your code? Maybe there's a problem with the code. Do you have a WAITCNT at the beginning of your program to give you time to start the Prop terminal?
If you answer all my questions we can probably resolve your problem in a short period of time. If you don't answer the question it could be days before we finally realize what the problem is.
johnproko,
What kind of bypass caps did you use, how many are there, and where are they located on your breadboard?
Many of the questions go unanswered. What is needed is the code and a picture of the setup.
Indeed Publison the crystal makes the difference, as I try to mix the equipment I have on the board.
Using the crystal will make the led high/low, although using the proptool it was fine even if i didnt use it.
Remember that the crystal is optional, as well as the eeprom.
So far I have been able to light a led, NEVERTHELESS printing in the terminal is not functioning.
Now before I blame W10, I used W8.1 and even tried to print using the proptool with no success.
The problem is something else.
FYI I did manage to print in the terminal for just once when the new chip came, yet it was a simple test to see if
everything was ok. Since then nothing. It is so frustrating!
This leaves us:
-Both props light a pin in simpleIDE
-Both props dont print in terminal using simpleIDE and Proptool.
As David said, the xstal is not optional when using the serial terminal.
I will try to upload a photo later because I am from a phone.
In addition to that, not having a decoupling / bypass capacitor between power and ground near the Propeller itself will cause issues as well. Anything that causes minor power surges, like lighting an LED or toggling the serial pin, will cause the power to fluctuate and introduce noise. Putting a 1uF cap (or a 0.1uF if that's all you have) between the pins will help filter noise. Using both is even better, because they handle different noise frequencies.
But pondering this points to a more general issue with selling DIP microcontrollers to those that want to DIY learning in electronics by breadboarding.
We seem to have a 'Just go for it' culture, that skips a lot of helpful assistance at the entry point. With the BS2, everything was prewired, and even with the Parallax Forum always had someone new to them struggling with getting the serial interface for program. That issue still carries over to the Propeller. And it likely will never go away.
But here we have the added challenges of proper breadboarding and proper power configuration. I suppose that we need to document a 'Tried and True' starter solution for breadboard.
(NOTE - THIS SECTION HAS BEEN CORRECTED)
The fact that a crystal MUST be used for SERIAL INPUT AND OUTPUT after programing the Propeller or the EEPROM, but programming doesn't required a crystal hasn't been made clear in starter solutions. And I am still wondering if it MUST be a 5Mhz crystal and no other.
I have never bothered to dig for clear answers as the 'accepted' usual way of doing things just worked for me.
And of course, a start solution should also include the fact that all the Grounds and all the V+ have to be included in wiring to avoid trouble.
The OP here obviously has acquired some rather exotic ideas of what passes for good practise in breadboarding and resolving wiring failures. One can't just read schematics or the main datasheet PDF. Those often presume that the reader has developed the knowledge and skills to avoid problems in a breadboard situation. Application Notes for knowledgible users are not appropriate either.
I feel that a special kind of Application Note seems needed, something like a HOWTO document.
Without the right document placed on Parallax's Downloads in appropriate places, Forum members will keep having to take up the slack of presenting the right way to get started without frustration. And it is rather hit or miss that the Forum members will do the job right.
Also, a box at the top of the datasheet mentioning that there is a good HOWTO construct a success first breadboard for users new to electronics and microcontrollers, might provied other a less frustrating first experience.
Obviously, a good first experience really builds a lot of confidence in Parallax and its products. A bad one looses business.
