Propeller Chip runs a mostly unmodified Arduino program (video)
Martin_H
I wanted to see if it was possible to use the SimpleIDE and the Propeller chip to run Arduino programs. So I ported some of the Arduino.h, main.cpp, SPI (sort of), Adafruit_GFX, and Max72xxPanel. The port consisted of writing Propeller implementations of Arduino functions like digitalWrite, delay, and pinMode. But I also removed some Atmel concepts that aren't on the Propeller (e.g. pgm_read_byte).
The most challenging part was dealing with SPI because the Arduino uses fixed pins for MOSI and SCLK, while the Propeller doesn't. So I used Spin2cpp and ported the Propeller SPI to C++. I then rewrote a small section of code which calls the SPI functions. Not a big deal, but it means the port is a one way trip and the code won't run on the Arduino afterwards. However, the port was much less work than writing the whole mess from scratch.
Here's the photographic evidence before this gets chalked up as a Bigfoot sighting:
Here's the source code:
Ticker.zip
Ticker.zip
Yup, you got pictures, so it happened!!
Just Wow!
This could be a game changer.
What other functions look like they might be a problem with Arduino code?
ADC maybe?
Yes, the ADC would be problematic, but only because there's no standard ADC used with the Propeller. If you assumed a specific board (e.g. Prop BOE, Propeller Backpack) or use conditional compilation, then that wouldn't be that hard at all. The hardest parts are the use of timers and interrupts as they don't exist on the Propeller. Now they're not needed because cogs are better and more general purpose, but that code won't port without a re-write. In practice most of their usage on the Arduino hides the ugly stuff behind a library, so the consuming code won't change. A good example is the servo library which uses timers. I could build a cog version and all code using the servo library would port unchanged. The same would be true for the analogWrite function.
A lessor concern is the fact that the Harvard architecture is more in your face on the Arduino. So there's annotations like PROGMEM and pgm_read_byte which aren't needed in LMM or CMM. On the Propeller the cogs need to worry about separate data and code stores, so code written on the Propeller for a cog might use those annotations.
Hmm... maybe we need a "hit list" of library functions not done yet...
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/asc/List/0/SortField/4/ProductID/872/Default.aspx
http://mghdesigns.com/propeller/mgh-designs/propeller-asc-arduino-shield-compatible-1.html
Bill's "hit list" is a great idea.
The core library is located in this directory \arduino-1.0.1\hardware\arduino\cores\arduino and consists of 36 files. Many of them aren't needed because either Propeller gcc has support for build in (e.g. new, delete), or don't apply (e.g. WInterrupts, HardwareSerial, USB support), or aren't core (e.g. IP Address). So I imagine we could limit it to the functions in Arduino.h, Print, and Serial. There commonly used libraries are in the directory \arduino-1.0.1\libraries and some like LiquidCrystal and Stepper look like they could compile with what I already have. But Servo will need work.
What I can do is try a few more program ports and flesh out my implementation a bit more. That will give me a better idea how big a project this could be.
The ASC, with built-in A2D converter would make the most sense.
All the other Propeller boards choke when that comes up.
They may be ok for many applications, but the ASC is going to be\
the closest match for the widest variety of apps.
I've been looking at that Touch Screen shield at Radio Shack,
wondering how to port the example programs from A to P.
This might just be the trick.
And it would be a very cool example too.
Timely, Martin...
Very timely.
Re: Concentrate on specific hardware - If only particular hardware is supported, that excludes everything else, and would obviously be a problem. Supported hardware should ideally include anything with a prop in it.
Having a HAL for each board could be a reasonable approach. There already is a selection in simpleIDE for each memory model, if this also includes somewhere a HAL definition for each board...and users could at more definitions as new custom boards come out...
is to be able to use the 'dino hardware as well. That's not something that any old prop board
will be able to do easily. The zillions of Aurdino shields that are out there, along with their
drivers and application code...
Martin has this niche pretty well nailed down.
His ASC board (Aurdino Shield Compatible) is laid out on the Aurdino form factor, so shields
will plug in just as they do on a Pic or Arm based Aurdino processor board.
He also offers an adapter (ASA = Aurdino Shield Adapter) for Propeller Platform boards to allow Aurdino
shields to be mounted.
That's why I think he should concentrate on his ASC board.
It has the required A2D converter that the Aurdino offers already.
Altruism is all well and good, and all Propellerdom will benefit from this project.
But business is business as well.
Anyway, moving on...
Hardware Abstraction Layer?
Sounds like a no-brainer, but how would such a thing be implemented ?
There are the normal suspects in the Propeller world -
memory addressing and interrupts, delay timing - might be - uh - Interesting?
The stuff that props often use; VGA, keyboard and mouse, TV, SD cards, EEPROM, RTC,
LCD, touch screens, etc?
All this hardware specific stuff...
Makes a strong argument for GCC, doesn't it?
There number of pronouns in that sentence might confuse people reading this who don't know the players.
Martin Hodge is the creator of the Propeller ASC and the Propeller Platform DNA
Martin Heermance (me) is the hobby robotics guy, plywood aficionado, and C++ programmer.
The fact that we are both named Martin H, and like Propeller chips and Arduinos has caused confusion in the past.
Anyway here's the list of functions left from Arduino.h that need to be nailed down:
I thought you were Martin Hodges, with a new avatar.
Sorry 'bout that.
There was a delay function posted somewhere fairly recently
that may solve the millis() function.
Dunno about the micros() tho.
For the analog functions, Martin's (the other one) ASC board uses the MPC3008,
a 10 bit, 8 channel chip. There is probably a driver for that somewhere that might
supply code for analogRead().
Those classes are used by the Serial object which is used for debugging purposes, so this is limiting. What interesting is that an AVR only has 32K of ram just like the Propeller's hub, so overflowing hub ram in CMM with so few classes seems a bit surprising. But I am using alpha software to cross compile code from another MCU, so trouble should be expected.
Isn't Arduino code in 32K FLASH? So it has another 2K of RAM for data.
I'm not sure that CMM is as compact as the AVR instruction set.
Yes, Arduino's have 16 bit ints. While the modern ones have a 32K flash and 2K RAM, the original was on a version that had 16K flash and 2K RAM, so it can fit in less. Since I'm not even calling most of these functions I suspect the linker isn't eliminating unused code which the AVR tools might be doing.
AVR instruction packing is pretty amazing.
We have per-function dead-code removal ability now in a release but haven't posted it yet. Will get to it tonight.
There is a way you can use dead-code removal now (with some limits). It requires using a special linker script.
https://sites.google.com/site/propellergcc/documentation/faq#TOC-Q:-How-can-I-get-smaller-programs-
Martin, could you post a .zip ?
Sure thing I can do it when I get home tonight.
Martin, A wonderful idea! I know such a library for Prop C would find its way into an article or two. In fact, I can see a series of pieces for basic robotics tasks with "cross-platform" code. Much of the basic functionality for a robot is fairly routine:
* Servo
* PWM out for DC motor control, LED dimming, or cranky sound making
* digitalRead, of course
* and just a scattering of others. Full string support isn't a must-have. The serial term stuff for debugging could be limited if there are memory concerns. Aren't there lighter weight versions for the string-handling routines?
The PropBOE/Activity Board variant for analogRead looks like a safe bet.
These and a plug-and-play equivalent to Ken Shirriff's remote IR library would just about cover 90+ percent of most people's robots.
-- Gordon
Thanks Gordon. I started working on the Servo lib port and that's going really smoothly. Using a cog boils it down to a for loop and some locks, which is much cleaner and smaller than the existing timer code.
Last year I ported a bunch of PBasic to the Arduino to improve my programming chops on both platforms. This port is making me learn a ton about the Arduino library internals and the Propeller chip.
https://code.google.com/p/propgcc/downloads/detail?name=propellergcc_v1_0_0-i686-windows.zip
Download the package, rename your C:\propgcc to C:\propgcc_save.
Extract the package contents as C:\propgcc
The package will let you remove (prune) unused code at build time. To enable dead code pruning, add this to SimpleIDE's Project Manager -> Compiler -> Other Compiler Options:
-ffunction-sections -fdata-sections -Wl,--gc-sections -Wl,--print-gc-sections
The -Wl,--print-gc-sections is optional and only allows seeing what was removed.
http://docs.macetech.com/doku.php/centipede_shield
on a prop asc -- how might I continue with your efforts? (as in how does what you are discovering enable us to use "any old shield we want to")
I don't know enough about the Prop ASC to say for sure. Looking at the docs (http://mghdesigns.com/wiki/_media/asc:pasc-f.pdf) it looks like pins 14 and 15 are used for SDA and SCL for the A2D converter. So implementing analogRead under that assumption should work.
BTW my interest in this project is code reuse, not shield reuse. My plan is to use this to port code from Arduino projects to Propeller projects, but I plan on using custom hardware.
If it would help you any with this project, I'd comp you an ASC. PM me your address.
Here is the thing I've been pondering...
2.8" LCD Touch Screen - with full source code examples.
Available from Lady Ada, Seed, And Radio Shack.
https://github.com/adafruit/TFTLCD-Library
http://www.radioshack.com/product/index.jsp?productId=12688460
http://www.seeedstudio.com/depot/28-tft-touch-shield-v20-p-1286.html
It's an Arduino form factor board, and would look perfect on an ASC.
I'm just not confident enough of my coding skills to tackle it by myself.
