How to Power Propeller Activity Board
amalfiCoast
in Propeller 1
Hello,
Is there a way to power the Activity Board other than using the 6-9 VDC power jack? I'd like to use a different lipo battery pack to power the Propeller and two motors. Is it possible to do this without splicing a male power jack (the one to fit the female jack on the board) onto the battery leads?
Thanks.
Thanks.
https://www.parallax.com/downloads/propeller-activity-board-wx-schematic
Looks like the cleanest way will be to make up a short adapter cable like you describe.
It is possible to solder wires to the power jack terminals on the WX board, but I agree with VonSzarvas, the cleanest way is with an adapter cable. It also makes it easier to remove and replace/repair/modify the board if required.
David
