Are Current limiting resistors required for TWO Props via Serial Coms?
HI,
I have two separate Prop chip circuits each with its own regulator circuits, but sharing a common power source ( battery 12VSLA)
I want to comunicate via Serial ( standard FDSerial object ) between the two circuits ( Props)
Q1) If I connect the RX & TX of One Prop to the TX & RX of the other prop, do I need any current limiting ( series) resistors in these lines Or is a direct wire for each OK?
Dave M
Dave M
Thanks for the reply,
The two prop serial connections are connected together via a small ribbon cable via a couple of MICRO-MATCH HEADERS.
I never like any direct "EXPOSED" Prop pin connections so I guess its best to have the resistors. Would 10K be two much or is something more like 150R a better choice?, Is there a calculation for the optimal resistor value?
Dave M
The 0.5mA current rating of the input protection diodes is the usual consideration when connecting the propeller pins to chips with higher voltage (ie +5V) power supplies, but for 2 props operating at nearly the same voltage it would be the max source/sink current of 30mA. That would make the lowest resistor value 3.3/.030 or 110 ohms. Personally I would use a resistor in the 470 to 1k ohm range.
I would have thought that CMOS to CMOS would not draw any ( or very little current ) and eliminating the need for addition components ( i.e resistors). But I am wrong!
I have seen many designs use current limiting resistors. I am trying to do "best Practice" as far as overall current usage is concerned, especially as all my devices are battery powered.
So..
1) Without any resistors - Result is higher current usage
2) With Resistors - Result is minimised current usage
So SOME current limiting is better for overall power consumption?
Q1) How do I calculate the Current Used, and the Voltage Drop ?
Dave M
Dave M
