Are Current limiting resistors required for TWO Props via Serial Coms? — Parallax Forums
DavidMDavidM Posts: 640
edited 2011-05-12 02:19 in Propeller 1
HI,
I have two separate Prop chip circuits each with its own regulator circuits, but sharing a common power source ( battery 12VSLA)
I want to comunicate via Serial ( standard FDSerial object ) between the two circuits ( Props)
Q1) If I connect the RX & TX of One Prop to the TX & RX of the other prop, do I need any current limiting ( series) resistors in these lines Or is a direct wire for each OK?
Dave M
  • JonnyMacJonnyMac Posts: 9,701
    edited 2011-05-10 22:39
    The resistor is cheap insurance. If a programming error causes one side to be driven high while the other is driven low the resistor will limit the current to a safe level. And if you think that kind of error doesn't occur, you haven't been programming very long.... ;)
  • DavidMDavidM Posts: 640
    edited 2011-05-10 22:46
    HI John,
    Thanks for the reply,
    The two prop serial connections are connected together via a small ribbon cable via a couple of MICRO-MATCH HEADERS.
    I never like any direct "EXPOSED" Prop pin connections so I guess its best to have the resistors. Would 10K be two much or is something more like 150R a better choice?, Is there a calculation for the optimal resistor value?
    Dave M
    edited 2011-05-11 21:08
    DavidM wrote: »
    HI John,
    Dave M
    The 0.5mA current rating of the input protection diodes is the usual consideration when connecting the propeller pins to chips with higher voltage (ie +5V) power supplies, but for 2 props operating at nearly the same voltage it would be the max source/sink current of 30mA. That would make the lowest resistor value 3.3/.030 or 110 ohms. Personally I would use a resistor in the 470 to 1k ohm range.
    edited 2011-05-12 01:09
    HI kwinn
    I would have thought that CMOS to CMOS would not draw any ( or very little current ) and eliminating the need for addition components ( i.e resistors). But I am wrong!
    I have seen many designs use current limiting resistors. I am trying to do "best Practice" as far as overall current usage is concerned, especially as all my devices are battery powered.
    So..
    1) Without any resistors - Result is higher current usage
    2) With Resistors - Result is minimised current usage
    So SOME current limiting is better for overall power consumption?
    Q1) How do I calculate the Current Used, and the Voltage Drop ?
    Dave M
  • M. K. BorriM. K. Borri Posts: 280
    edited 2011-05-12 01:46
    A high resistor will lower your max.data rate because the wire between the props has some inductance and capacitance, so a resistor will increase the logic transition time. That said you can probably use a 220ohm resistor and call it done :) it's big enough to save your bacon in case of error and small enough to not interfere.
    Dave M
