Announcing CPUModule: A simple tiny Propeller board - fits on breadboards! — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2011-05-08 03:27 in Propeller 1
There have been manu threads in the forums requesting a very simple, small, Propeller module. WBA Consulting and I discussed this back in March, then again in May last year... but I had not yet decided on a feature set. Part of me wanted to cram it full of features, and make it SMT.
I discussed it with Sapieha. He wanted a *REALLY* simple module, not SMT, that could plug into a standard breadboard.
Sapieha and I kicked it back and forth... he convinced me to drop the ADC and SMT construction, I convinced him to make it have at least three EXPansion connectors compatible with 10 pin modules.
Thus, CPUModule was born...
I had prototypes at UPEW 2010, and now I have production boards in hand for UPEW 2011
CPUModule features:
- 2.575"x1.160" - same form factor as the I/O modules, with the same mounting footprint
- extremely nice PCB layout by Sapieha
- can be mounted on standard .1" spacing breadboards using simple male headers
- can take EXP1 (P0-P7), EXP2 (P8-P15) and EXP3 (P16-P23) standard -or- stacking connector
- has on-board LM1117-3.3 (or compatible) SMT voltage regulator
- optional power LED and current limiting resistor
- supports up to three 33uF SMT/throughole tantalum capacitors and two 100nF ceramic bypass capacitors
- EXP1/2 can have optional 11'th +5VDC pin if the module is powered by +5VDC
- has my standard H-COMM connector for PropPlug, SerPlug or 485Plug
- can take TWO EEPROM's (pullups on both SCA and SCL)
- one EEProm socket defaults to address 0, the other can be strapped to address 0..7
- has two screw terminals for power input
Did I mention CPUModule is tiny?
Or that it runs fine at 100MHz?
miniPro works great on it, as do all the 10 pin modules I will be showing at UPEW!
I am attaching some shots of the CPUModule below.
Note: the next production run will be blue.
MSRP for the bare PCB is:
1 for $7.95+s/h
3 for $22.00+s/h
  • BeanBean Posts: 8,129
    edited 2011-05-06 17:57
    Look nice.
    Any chance you could post a schematic ?
    I'd be interested in a kit with all the parts. Any chance you will offer that ?
    Bean
    edited 2011-05-06 18:16
    Thanks Bean!
    I added the schematic to the first post - so I guess there was a chance :-)
    Sure, after UPEW I can offer a kit including parts. I will have some bare PCB's with me at UPEW.
    Bean wrote: »
    Look nice.
    Bean
    edited 2011-05-06 18:31
    Sweeeeet!! ...and there's a batch coming in blue!!
    It doesn't look like there are any hard to find parts, either.
    I'll be back with you after UPEW.
    Rick
    edited 2011-05-06 18:52
    Thanks for the kind words Rick!
    No, there are no hard to find parts; and if you don't want to use SMT tantalum caps, you can use through hole electrolytics.
    I'll be here after UPEW :)
    mindrobots wrote: »
    Rick
  • MacTuxLinMacTuxLin Posts: 821
    edited 2011-05-07 05:11
    Gzee ... if you had this earlier, it could have saved me a lot of hassle. I'll take 3 bare PCB please. Do you ship to Singapore?
    edited 2011-05-07 05:25
    Hi Bill,
    I have a question. There looks like a 1N4xx rectifier in the picture but I don't see it on your schematic?
    97 x 125 - 23K
    edited 2011-05-07 05:32
    Hi,
    I am glad you like the board, and yes, I can ship 3 bare PCB's to Singapore :) I'll figure out the s/h later today.
    You are correct, that is a 1N4004 (or 4007, I forget which one I used) diode!
    The schematic I posted is slightly out of date, and is missing the diode - sorry.
    MacTuxLin wrote: »
    edited 2011-05-07 05:35
    Thanks Bill. So, how do I make the payment to you? Could you PM me or do you have a web-site that I could enter to process this order?
    Oh, just saw your URL :tongue: ...
    edited 2011-05-07 05:39
    You are welcome :)
    Email or PM me your snail mail address, and what email address I can send a PayPal invoice to.
    I am afraid I won't have a shopping cart set up on my site until sometime in June.
    MacTuxLin wrote: »
  • doggiedocdoggiedoc Posts: 2,257
    edited 2011-05-07 05:46
    Bill - That looks really awesome! I look forward to buying a few from you at UPEW!!
    Paul
    edited 2011-05-07 05:50
    OK, just sent you a PM.
    Cheers.
    edited 2011-05-07 07:55
    Thanks Paul!
    I look forward to seeing you at UPEW..
    doggiedoc wrote: »
    Paul
    Thanks, got it!
    MacTuxLin wrote: »
    Cheers.
  • SapiehaSapieha Posts: 2,964
    edited 2011-05-07 10:47
    Hi MacTuxLin.
    Corrected SCH to this module
    MacTuxLin wrote: »
    Hi Bill,
    edited 2011-05-07 17:32
    Thanks for uploading the updated schematic Sapieha!
    Here is a teaser pic of CPUModule with three miniProp's stacked on top, plugged into a big breadboard holding unannounced educational mini boards :)
  • Cole LoganCole Logan Posts: 196
    edited 2011-05-07 18:15
    Look like you will have awesome 10pin boards
    edited 2011-05-07 19:26
    Thanks Cole... many more coming :)
    Cole Logan wrote: »
    Sapieha wrote: »
    Hi MacTuxLin.
    Thanks Sapieha.
