What's the difference between Prop Plug and USB2Ser Dev. Tool? — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2011-05-02 19:48 in Propeller 1
Both look about the same.
Are they interchangeable?
Can the USB2SER Dev. Tool be used as a Prop Plug to program the Propeller?
  • Duane C. JohnsonDuane C. Johnson Posts: 955
    edited 2011-03-30 04:15
    There is only a slight difference in the schematic between the Prop Plug and USB2Ser Dev. Tool.
    This difference is in the 5V / 3.3V connections to the FTDI chip.
    However, this looks to be insignificant to its operation.
    The important part is the 4 pin connector making connection to your board is the same.
    I would say you should be good to go.
    Duane
  • Paul Sr.Paul Sr. Posts: 435
    edited 2011-03-30 08:01
    BE CAREFUL - the 4 Pin connectors are NOT the same configuration!
    Prop Plug: VSS RES TX RX
    USB2SER: RST TX RX VSS
    edited 2011-03-30 08:19
    That's the difference. I hadn't noticed that.
    The USB2Ser Dev. Tool is like many of the other "non parallax" adapters.
    If my first adapter was the USB2Ser Dev. Tool I wouldn't have had to make
    all these gender changers.
    See another post regarding the RST pin:
    http://forums.parallax.com/showthread.php?130412-SPIN-Problems-Using-Non-Parallax-USB-to-TTL-RS-232-Adapter.&p=986154#post986154
    Duane
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2011-04-01 23:51
    For the record, you don't need to make any modifications between the PropPlug and the USB2SER other than how you orient the plug into the socket. See attached images.
    The difference is that the USB2SER is really designed for 5V applications, but should be ok "in a pinch" for the Propeller, since there are 1K current limiting resistors on the RX and TX lines.
    PropPlug: (looking at the front side)
     VSS RES TX RX
    USB2SER: (looking at the back side)
         RES TX RX VSS
    ...By shifting the Plug over by one, the RES,TX, and RX align. The only signal you need to carry is VSS. A simple jumper wire will do the job.
    1024 x 768 - 91K
    1024 x 768 - 89K
    520 x 248 - 19K
  • MagIO2MagIO2 Posts: 2,243
    edited 2011-04-02 11:47
    Hi Beau,
    nice tip. BUT ... the 1k resistors have been replaced by 150Ohm resistors with REV B and C. That's why I choosed to add 680Ohm.
    Additionally I don't need it as a Basic Stamp programmer, thus I made it a full Prop-Plug ;o)
    edited 2011-04-02 17:35
    MagIO2,
    "the 1k resistors have been replaced by 150Ohm resistors with REV B and C" - I see that... I looked at the revA datasheet.
    Still "in a pinch" it should be ok, but I wouldn't recommend it for a permanent setup. The FT232RQ datasheet indicates a maximum OUTPUT voltage from the datasheet (page 16 table #7) when VCCIO is powered from a 5V supply is at 4.9V(Max) ; 4.1V(Typical) ... The Diode drop of the Propeller (0.4V) and the difference of 3.3V amounts to 1.2V across the 150 Ohm resistor... or 8mA(Max) ;2.7mA(Typical) . The addition of a 680 Ohm resistor lessens the current to 1.4mA(Max) ;482uA(Typical).
    Datasheet reference:
    http://datasheet.octopart.com/FT232RQ-FTDI-datasheet-120501.pdf
  • davidsaundersdavidsaunders Posts: 1,559
    Because of the issues with the FTDI chips in some cases (certain kernels do not have a driver etc.), I would like to point out that there is an open source library that can be statically linked to provide the driver functionality with out a kernel linked driver (you just have to have working USB). for more see:
    http://www.intra2net.com/en/developer/libftdi/
    After searching the forums, this seems the best place for this (short of starting a thread).
