Lead free solder - opinions wanted
At present I have several 1 pound spools of leaded solder, hoping to last me few years.
So what that I am not EU compliant, I am not planning to export my hobby project anywhere.
But heard some rumblings that lead free solder is not that easy to work with.
Anybody like to share their opinions on the subject?
Vaclav
Vaclav
Franklin,
could you elaborate on this? Is there a difference in how it wets, what sort of solder iron you need, etc.? I've been using leaded solder for far too long and now that my kid wants to learn how to solder, I want to switch to unleaded stuff.
I tried using some lead free from RadioShack a year or so ago, I was able to complete the board I used it on but was very unhappy with how it looked. The connections tended to be dull and look a little cold joints. I went back to leaded solder because I didn't 'have' to use lead free and I like the results of leaded solder better, but I know over time I'll probably have to make the switch.
C.W.
http://www.warton-metals.co.uk/
It produces nice shiny joints.
Omega II, type SAC3.
but with the right gear and a tad bit of learning you can use it with not to much hassle .
Me I own a Edysin station that I love . I need a new tip every year .. $15 ..
I still perferr my 2% silver 5 core super lead bulltit stuff for jobs where I need it but I have done the switch .
but DO NOT MIX the tips . it will eat them so fast .
Peter
Long story short; continue your research and make an equipment investment so you can migrate without issues.
a RoHS iron is just that , It doesn't necessarily mean its made for lead free work , I Just means the iron is complaint .
Make shure its made for Lead free work ..
While I am not fabricating fine pitch IC boards, I may need to occasionally repair something and the fact that tin does create problems has made me wary.
As far as special soldering irons - it really is all about enough heat and there is nothing special with heat. Just be sure you have a high enough watt rating for the task you are doing.
Lead solder is likely to be around for a long time even though ROHS is pretty much a commercial requirement for export. And the lead/tin alloy was perfected for good flow. With all the lead acid batteries in use, I really wonder if we are really addressing the core heavy metal problem - batteries, not solder.
Industrial Consumption of Lead
http://www.lme.com/lead_industryusage.asp
The info is from 2007 but is probably useful as a general indicator.
