Mounting the Professional Development Board to a substrate?
xanatos
I am building a development environment for my PPDB with a dedicated supply and a whole lot of breadboard space for auxilliary circuit development. I would like to hard-mount my PPDB to the aluminum work surface I am building this all on, but I am hesitant to drill any holes through any area of the PPDB because I do not know if the board is multilayer or just two layer (top & bottom), and everything at the likely drill points is masked by a ground plane.
Can anyone tell me if the board can be safely drilled where there are no visible runs (ie., ground plane surfaces both sides) or if there are sandwiched runs beneath?
Thanks!
Dave
Thanks!
Dave
Someone on here must know about whether there are sandwiched runs on this item or not...
Happy Easter to all on here... and if you don't celebrate Easter, happy Sunday! :-)
Dave
Would that do what you are wanting?
Dave
Than you could slide you board in and out.
Maybe you can even buy new ones, I did not look.
