Drive Memsic 2125 directly from Prop pin? — Parallax Forums
DirtJockeyDirtJockey Posts: 6
edited 2011-04-16 07:23 in Propeller 1
I am considering running the Memsic directly from the Propeller pin. The application code only requires the output from the accelorometer at short specific times (samples.) I would like to turn it on and off as needed to keep the draw as low as possible.
The datasheet says the Memsic draws <5 mA. Everything else on the circuit is driven through a Darlington array. I did consider driving the Memsic through the Darlington but I have clamped the COM pin (10) to +12VDC for use in the inductive loads in the circuit.
My question is should I just drive the Memsic through the Prop pin, or can I use the existing Darlington array? I am somewhat limited for space as I am trying to meet space requirements for a short run proto board service.
Bob
  • RS_JimRS_Jim Posts: 1,775
    edited 2011-04-15 05:54
    Bob,
    Dont quite understand your question. The 2125 is a 3.3 volt part and should be able to interface directly with the prop. Are you trying to use a prop pin to power it on and off?
    RS_Jim
  • DirtJockeyDirtJockey Posts: 6
    edited 2011-04-15 23:10
    Yes, It would make for a much simpler design if I can power the 2125 on and off from a Propeller pin.
    The specs say that the 2125 uses less that 4ma at 5 volts, so with 40 available on a prop pin, I would say that yes you could power it on and off with a prop pin.
    Jim
