Keypad Documentation Error
The 4x4 Matrix Membrane Keypad (#27899) documentation diagram showing the cable pins in relation to the rows and columns is incorrect (assuming that the pin numbers are numbered left to right.
I used a Volt Ohm meter and found that image should actually look like the one below
(numbered 8 to 1 rather than 1 to 8).
This also agrees with the BS2 demo program comments
Thanks again, Ken Gracey
I've updated the doc and it should be on the web sometime tomorrow.
Cheers,
Jessica
I thought that might be the case. Glad I could help!
- Ron
