Keypad Documentation Error — Parallax Forums
edited 2011-04-15 04:43 in General Discussion
The 4x4 Matrix Membrane Keypad (#27899) documentation diagram showing the cable pins in relation to the rows and columns is incorrect (assuming that the pin numbers are numbered left to right.
I used a Volt Ohm meter and found that image should actually look like the one below
(numbered 8 to 1 rather than 1 to 8).
This also agrees with the BS2 demo program comments
506 x 609 - 46K
1024 x 486 - 40K
    edited 2011-04-14 19:43
    Nice find, Ron. We'll look into this right away. I'll report the problem to the internal Product Owner.
    Thanks again, Ken Gracey
  • Jessica UelmenJessica Uelmen Posts: 490
    edited 2011-04-14 20:09
    Thanks Ron, I was drawing the diagram from the back of the keypad, and obviously forgot to reverse the pins. >.<
    I've updated the doc and it should be on the web sometime tomorrow.
    Cheers,
    Jessica
    Jessica,
    I thought that might be the case. Glad I could help!
    - Ron
