Continuous DDS updating
Okay, so our keyboard synthesizer project is coming along well, but we have a few bugs to work out. The issue now is the updating the frequencies being thrown out to the dac. Here is a screenshot of the problem:
Essentially everytime the cog is restarted to start playing the updated list of frequencies, it has to reset. This is causing a pulsing sound (and in the output waveform). Here is the top object file:
con
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
obj
sinsynth : "sintabsynth"
sawsynth : "sawtabsynth"
trisynth : "triangletabsynth"
squaresynth:"squaretabsynth"
keyReader:"keyReader"
DDS : "DDS_PASM"
Debug : "FullDuplexSerial"
var
long playFreqs[6]
long playPress[6]
byte t1
pub main
Debug.start(31,30,0,57600)
keyReader.start(@playFreqs, @playPress)
repeat
waitcnt(clkfreq/20 + cnt)
DDS.start(playFreqs[0]*10000/322,playFreqs[1]*10000/322,playFreqs[2]*10000/322,playFreqs[3]*10000/322,playFreqs[4]*10000/322,playFreqs[5]*10000/322)
The playFreq calculations for each parameter are there to calculate the frequency tuning ratio for the following code:
VAR
long cog 'cog id
PUB start(M1,M2,M3,M4,M5,M6) : okay 'M is the tuning word
stop 'Stop DDS if it is running, frees a cog
M1_ := M1 'Assign passed variable (tuning word)
M2_ := M2
M3_ := M3
M4_ := M4
M5_ := M5
M6_ := M6
okay := cog := cognew(@entry,0) 'Start DDS, uses a cog.
PUB stop
if cog 'If cog is running
cogstop(cog~) 'Stop DDS, frees a cog
DAT
org 0
entry
Sine long $80,$83,$86,$89,$8C,$8F,$92,$95,$98,$9C,$9F,$A2,$A5,$A8,$AB,$AE
long $B0,$B3,$B6,$B9,$BC,$BF,$C1,$C4,$C7,$C9,$CC,$CE,$D1,$D3,$D5,$D8
long $DA,$DC,$DE,$E0,$E2,$E4,$E6,$E8,$EA,$EC,$ED,$EF,$F0,$F2,$F3,$F5
long $F6,$F7,$F8,$F9,$FA,$FB,$FC,$FC,$FD,$FE,$FE,$FF,$FF,$FF,$FF,$FF
long $FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE,$FD,$FC,$FC,$FB,$FA,$F9,$F8,$F7
long $F6,$F5,$F3,$F2,$F0,$EF,$ED,$EC,$EA,$E8,$E6,$E4,$E2,$E0,$DE,$DC
long $DA,$D8,$D5,$D3,$D1,$CE,$CC,$C9,$C7,$C4,$C1,$BF,$BC,$B9,$B6,$B3
long $B0,$AE,$AB,$A8,$A5,$A2,$9F,$9C,$98,$95,$92,$8F,$8C,$89,$86,$83
long $80,$7C,$79,$76,$73,$70,$6D,$6A,$67,$63,$60,$5D,$5A,$57,$54,$51
long $4F,$4C,$49,$46,$43,$40,$3E,$3B,$38,$36,$33,$31,$2E,$2C,$2A,$27
long $25,$23,$21,$1F,$1D,$1B,$19,$17,$15,$13,$12,$10,$0F,$0D,$0C,$0A
long $09,$08,$07,$06,$05,$04,$03,$03,$02,$01,$01,$00,$00,$00,$00,$00
long $00,$00,$00,$00,$00,$00,$01,$01,$02,$03,$03,$04,$05,$06,$07,$08
long $09,$0A,$0C,$0D,$0F,$10,$12,$13,$15,$17,$19,$1B,$1D,$1F,$21,$23
long $25,$27,$2A,$2C,$2E,$31,$33,$36,$38,$3B,$3E,$40,$43,$46,$49,$4C
long $4F,$51,$54,$57,$5A,$5D,$60,$63,$67,$6A,$6D,$70,$73,$76,$79,$7C
mov dira, PinMsk 'LSB to PA0, LSB to PA7
:loop add Acc1, M1_ wz 'M $1FF max if literal with #$xxx
ror Acc1, #16 'Postion index
movs :inline1, Acc1 'Store 9-bit index
andn :inline1, #%1_00000000 'Clamp to 8-bits
rol Acc1, #16 'Restore accumulator
:inline1 if_nz mov outa, 0-0 'Get long value from table
add Acc2, M2_ wz
ror Acc2, #16
movs :inline2, Acc2 'Store 9-bit index
andn :inline2, #%1_00000000 'Clamp to 8-bits
rol Acc2, #16 'Restore accumulator
:inline2 if_nz mov outa, 0-0 'Get long value from table
add Acc3, M3_ wz
ror Acc3, #16
movs :inline3, Acc3 'Store 9-bit index
andn :inline3, #%1_00000000 'Clamp to 8-bits
rol Acc3, #16 'Restore accumulator
:inline3 if_nz mov outa, 0-0
add Acc4, M4_ wz
ror Acc4, #16
movs :inline4, Acc4 'Store 9-bit index
andn :inline4, #%1_00000000 'Clamp to 8-bits
rol Acc4, #16 'Restore accumulator
:inline4 if_nz mov outa, 0-0
add Acc5, M5_ wz
ror Acc5, #16
movs :inline5, Acc5 'Store 9-bit index
andn :inline5, #%1_00000000 'Clamp to 8-bits
rol Acc5, #16 'Restore accumulator
:inline5 if_nz mov outa, 0-0
add Acc6, M6_ wz
ror Acc6, #16
movs :inline6, Acc6 'Store 9-bit index
andn :inline6, #%1_00000000 'Clamp to 8-bits
rol Acc6, #16 'Restore accumulator
:inline6 if_nz mov outa, 0-0
jmp #:loop 'Loop again
PinMsk long $FF '8-bit DAC, LSB on PA0, MSB on PA7
M1_ long 0 'Tuning word var init
M2_ long 0
M3_ long 0
M4_ long 0
M5_ long 0
M6_ long 0
Acc1 long 0 'Accumulator var init
Acc2 long 0
Acc3 long 0
Acc4 long 0
Acc5 long 0
Acc6 long 0
│ TERMS OF USE: MIT License │
│Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │
│files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │
│modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│
│is furnished to do so, subject to the following conditions: │
│The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│
│THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │
│WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │
│COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │
│ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │
Essentially, I need to actively update the frequencies to be produced actively, without stopping and starting the cog again. Any suggestions?
VAR long cog 'cog id long FreqControl1 long FreqControl2 long FreqControl3 long FreqControl4 long FreqControl5 long FreqControl6 PUB start(M1,M2, M3, M4, M5, M6) : okay 'M is the tuning word stop FreqControl1 := $41893 ''$E560 'Stop DDS if it is running, frees a cog FreqControl2 := $41893 FreqControl3 := $41893 FreqControl4 := $41893 FreqControl5 := $41893 FreqControl6 := $41893 M1_ := M1 'Assign passed variable (tuning word) M2_ := M2 M3_ := M3 M4_ := M4 M5_ := M5 M6_ := M6 okay := cog := cognew(@entry,@FreqControl1) 'Start DDS, uses a cog. PUB stop if cog 'If cog is running cogstop(cog~) 'Stop DDS, frees a cog PUB ChangeFreq(NewFreq1, NewFreq2, NewFreq3,NewFreq4,NewFreq5,NewFreq6) FreqControl1 := NewFreq1 FreqControl2 := NewFreq2 FreqControl3 := NewFreq3 FreqControl4 := NewFreq4 FreqControl5 := NewFreq5 FreqControl6 := NewFreq6 DAT org 0 entry Sine long $80,$83,$86,$89,$8C,$8F,$92,$95,$98,$9C,$9F,$A2,$A5,$A8,$AB,$AE long $B0,$B3,$B6,$B9,$BC,$BF,$C1,$C4,$C7,$C9,$CC,$CE,$D1,$D3,$D5,$D8 long $DA,$DC,$DE,$E0,$E2,$E4,$E6,$E8,$EA,$EC,$ED,$EF,$F0,$F2,$F3,$F5 long $F6,$F7,$F8,$F9,$FA,$FB,$FC,$FC,$FD,$FE,$FE,$FF,$FF,$FF,$FF,$FF long $FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE,$FD,$FC,$FC,$FB,$FA,$F9,$F8,$F7 long $F6,$F5,$F3,$F2,$F0,$EF,$ED,$EC,$EA,$E8,$E6,$E4,$E2,$E0,$DE,$DC long $DA,$D8,$D5,$D3,$D1,$CE,$CC,$C9,$C7,$C4,$C1,$BF,$BC,$B9,$B6,$B3 long $B0,$AE,$AB,$A8,$A5,$A2,$9F,$9C,$98,$95,$92,$8F,$8C,$89,$86,$83 long $80,$7C,$79,$76,$73,$70,$6D,$6A,$67,$63,$60,$5D,$5A,$57,$54,$51 long $4F,$4C,$49,$46,$43,$40,$3E,$3B,$38,$36,$33,$31,$2E,$2C,$2A,$27 long $25,$23,$21,$1F,$1D,$1B,$19,$17,$15,$13,$12,$10,$0F,$0D,$0C,$0A long $09,$08,$07,$06,$05,$04,$03,$03,$02,$01,$01,$00,$00,$00,$00,$00 long $00,$00,$00,$00,$00,$00,$01,$01,$02,$03,$03,$04,$05,$06,$07,$08 long $09,$0A,$0C,$0D,$0F,$10,$12,$13,$15,$17,$19,$1B,$1D,$1F,$21,$23 long $25,$27,$2A,$2C,$2E,$31,$33,$36,$38,$3B,$3E,$40,$43,$46,$49,$4C long $4F,$51,$54,$57,$5A,$5D,$60,$63,$67,$6A,$6D,$70,$73,$76,$79,$7C mov dira, PinMsk 'LSB to PA0, LSB to PA7 :loop rdlong M1_, par 'Get Freq Control Value mov CtrlPtr, par add Acc1, M1_ wz 'M $1FF max if literal with #$xxx ror Acc1, #16 'Postion index movs :inline1, Acc1 'Store 9-bit index andn :inline1, #%1_00000000 'Clamp to 8-bits rol Acc1, #16 'Restore accumulator :inline1 mov outa, 0-0 'Get long value from table add CtrlPtr, #32 rdlong M2_,CtrlPtr 'Get Freq Control Value add Acc2, M2_ wz 'M $1FF max if literal with #$xxx ror Acc2, #16 'Postion index movs :inline2, Acc2 'Store 9-bit index andn :inline2, #%1_00000000 'Clamp to 8-bits rol Acc2, #16 'Restore accumulator :inline2 if_nz mov outa, 0-0 'Get long value from table {{ add CtrlPtr, #32 rdlong M3_,CtrlPtr 'Get Freq Control Value add Acc3, M3_ wz 'M $1FF max if literal with #$xxx ror Acc3, #16 'Postion index movs :inline3, Acc3 'Store 9-bit index andn :inline3, #%1_00000000 'Clamp to 8-bits rol Acc3, #16 'Restore accumulator :inline3 if_nz mov outa, 0-0 'Get long value from table {{ add CtrlPtr, #32 rdlong M4_,CtrlPtr 'Get Freq Control Value add Acc4, M4_ 'M $1FF max if literal with #$xxx ror Acc4, #16 'Postion index movs :inline4, Acc4 'Store 9-bit index andn :inline4, #%1_00000000 'Clamp to 8-bits rol Acc4, #16 'Restore accumulator :inline4 mov outa, 0-0 'Get long value from table add CtrlPtr, #32 rdlong M5_,CtrlPtr 'Get Freq Control Value add Acc5, M5_ 'M $1FF max if literal with #$xxx ror Acc5, #16 'Postion index movs :inline5, Acc5 'Store 9-bit index andn :inline5, #%1_00000000 'Clamp to 8-bits rol Acc5, #16 'Restore accumulator :inline5 mov outa, 0-0 'Get long value from table add CtrlPtr, #32 rdlong M6_,CtrlPtr 'Get Freq Control Value add Acc6, M6_ 'M $1FF max if literal with #$xxx ror Acc6, #16 'Postion index movs :inline6, Acc6 'Store 9-bit index andn :inline6, #%1_00000000 'Clamp to 8-bits rol Acc6, #16 'Restore accumulator :inline6 mov outa, 0-0 }} 'Get long value from table jmp #:loop 'Loop againYour FreqControlx values are LONGs.
So they are separated by 4 bytes.
So I think you should be using "add CtrlPtr, #4" instead.
