Continuous DDS updating
Okay, so our keyboard synthesizer project is coming along well, but we have a few bugs to work out. The issue now is the updating the frequencies being thrown out to the dac. Here is a screenshot of the problem:
Essentially everytime the cog is restarted to start playing the updated list of frequencies, it has to reset. This is causing a pulsing sound (and in the output waveform). Here is the top object file:
con _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 obj sinsynth : "sintabsynth" sawsynth : "sawtabsynth" trisynth : "triangletabsynth" squaresynth:"squaretabsynth" keyReader:"keyReader" DDS : "DDS_PASM" Debug : "FullDuplexSerial" var long playFreqs[6] long playPress[6] byte t1 pub main Debug.start(31,30,0,57600) keyReader.start(@playFreqs, @playPress) repeat waitcnt(clkfreq/20 + cnt) DDS.start(playFreqs[0]*10000/322,playFreqs[1]*10000/322,playFreqs[2]*10000/322,playFreqs[3]*10000/322,playFreqs[4]*10000/322,playFreqs[5]*10000/322)The playFreq calculations for each parameter are there to calculate the frequency tuning ratio for the following code:
VAR long cog 'cog id PUB start(M1,M2,M3,M4,M5,M6) : okay 'M is the tuning word stop 'Stop DDS if it is running, frees a cog M1_ := M1 'Assign passed variable (tuning word) M2_ := M2 M3_ := M3 M4_ := M4 M5_ := M5 M6_ := M6 okay := cog := cognew(@entry,0) 'Start DDS, uses a cog. PUB stop if cog 'If cog is running cogstop(cog~) 'Stop DDS, frees a cog DAT org 0 entry Sine long $80,$83,$86,$89,$8C,$8F,$92,$95,$98,$9C,$9F,$A2,$A5,$A8,$AB,$AE long $B0,$B3,$B6,$B9,$BC,$BF,$C1,$C4,$C7,$C9,$CC,$CE,$D1,$D3,$D5,$D8 long $DA,$DC,$DE,$E0,$E2,$E4,$E6,$E8,$EA,$EC,$ED,$EF,$F0,$F2,$F3,$F5 long $F6,$F7,$F8,$F9,$FA,$FB,$FC,$FC,$FD,$FE,$FE,$FF,$FF,$FF,$FF,$FF long $FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE,$FD,$FC,$FC,$FB,$FA,$F9,$F8,$F7 long $F6,$F5,$F3,$F2,$F0,$EF,$ED,$EC,$EA,$E8,$E6,$E4,$E2,$E0,$DE,$DC long $DA,$D8,$D5,$D3,$D1,$CE,$CC,$C9,$C7,$C4,$C1,$BF,$BC,$B9,$B6,$B3 long $B0,$AE,$AB,$A8,$A5,$A2,$9F,$9C,$98,$95,$92,$8F,$8C,$89,$86,$83 long $80,$7C,$79,$76,$73,$70,$6D,$6A,$67,$63,$60,$5D,$5A,$57,$54,$51 long $4F,$4C,$49,$46,$43,$40,$3E,$3B,$38,$36,$33,$31,$2E,$2C,$2A,$27 long $25,$23,$21,$1F,$1D,$1B,$19,$17,$15,$13,$12,$10,$0F,$0D,$0C,$0A long $09,$08,$07,$06,$05,$04,$03,$03,$02,$01,$01,$00,$00,$00,$00,$00 long $00,$00,$00,$00,$00,$00,$01,$01,$02,$03,$03,$04,$05,$06,$07,$08 long $09,$0A,$0C,$0D,$0F,$10,$12,$13,$15,$17,$19,$1B,$1D,$1F,$21,$23 long $25,$27,$2A,$2C,$2E,$31,$33,$36,$38,$3B,$3E,$40,$43,$46,$49,$4C long $4F,$51,$54,$57,$5A,$5D,$60,$63,$67,$6A,$6D,$70,$73,$76,$79,$7C mov dira, PinMsk 'LSB to PA0, LSB to PA7 :loop add Acc1, M1_ wz 'M $1FF max if literal with #$xxx ror Acc1, #16 'Postion index movs :inline1, Acc1 'Store 9-bit index andn :inline1, #%1_00000000 'Clamp to 8-bits rol Acc1, #16 'Restore accumulator :inline1 if_nz mov outa, 0-0 'Get long value from table add Acc2, M2_ wz ror Acc2, #16 movs :inline2, Acc2 'Store 9-bit index andn :inline2, #%1_00000000 'Clamp to 8-bits rol Acc2, #16 'Restore accumulator :inline2 if_nz mov outa, 0-0 'Get long value from table add Acc3, M3_ wz ror Acc3, #16 movs :inline3, Acc3 'Store 9-bit index andn :inline3, #%1_00000000 'Clamp to 8-bits rol Acc3, #16 'Restore accumulator :inline3 if_nz mov outa, 0-0 add Acc4, M4_ wz ror Acc4, #16 movs :inline4, Acc4 'Store 9-bit index andn :inline4, #%1_00000000 'Clamp to 8-bits rol Acc4, #16 'Restore accumulator :inline4 if_nz mov outa, 0-0 add Acc5, M5_ wz ror Acc5, #16 movs :inline5, Acc5 'Store 9-bit index andn :inline5, #%1_00000000 'Clamp to 8-bits rol Acc5, #16 'Restore accumulator :inline5 if_nz mov outa, 0-0 add Acc6, M6_ wz ror Acc6, #16 movs :inline6, Acc6 'Store 9-bit index andn :inline6, #%1_00000000 'Clamp to 8-bits rol Acc6, #16 'Restore accumulator :inline6 if_nz mov outa, 0-0 jmp #:loop 'Loop again PinMsk long $FF '8-bit DAC, LSB on PA0, MSB on PA7 M1_ long 0 'Tuning word var init M2_ long 0 M3_ long 0 M4_ long 0 M5_ long 0 M6_ long 0 Acc1 long 0 'Accumulator var init Acc2 long 0 Acc3 long 0 Acc4 long 0 Acc5 long 0 Acc6 long 0 {{ ┌──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation │ │files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, │ │modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software│ │is furnished to do so, subject to the following conditions: │ │ │ │The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.│ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE │ │WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR │ │COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, │ │ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ }}Essentially, I need to actively update the frequencies to be produced actively, without stopping and starting the cog again. Any suggestions?
Your FreqControlx values are LONGs.
So they are separated by 4 bytes.
So I think you should be using "add CtrlPtr, #4" instead.
